Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
It needs a sealer of some form. Because the house is curved, therain will run off, but if it rained for a week, it will obsorb thewater, and sooner or later the saturation point will be reached andwater will run through.
It has tiny fractures throughout, over time if not checked, they grow,turning into hairline cracks, then big cracks. Any wire insidewill rust, and expand the cracks more. etc etc.
Sealants are required. Just do a test, try it yourself.
Even cement walls on a house must be sealed on the outside if you wantan fha loan. Why? because they will do the same thing, absorb therain, water from sprinklers and then transfer it to the inside.
And in the case of a sprinkler? It doesnt take days, lol. I tried this one too. It was fun to watch and see that thepattern on the inside was the same as the outside. I nice curve.
I would like to get/build one, but I don't have the resources :?
Cement structures take time to really dry out and some peolple compain of humidity for several years. I would think in SW USA this could be a lucky good thing, in Manitoba maybe not.
Jest fer fun you could, with a small dome use bottles (blue green or flint) with the ends exposed to the light so internally you have illumination. A design even, say a constellation if it is a shed type building. In a small structure like for the dogs you could make a two layer bottle wall (no tilt, then put your ferro cement screening and maybe 2-3 in a cluster at the top as a skylight. If you use small bottles like mini juice things or ginseng bottles, you could do constellations and being a dog house do , errr do SIRUS, (Cannis Major).
The final coating can vary but the stuff they use to lay ceramic tiles is water proof on drying . Big bro waterproofed an entire basement with it, filled cracks and space too, so it is like hydrocement in that it filled cracks and stayed waterproof (over 10 years, no leaks). When we did the facade onhis bar/club we used it there as well.
It pays to add something to the cement mix that makes it water proof over a final coating of paint which peels. It would be great to paint over it anyway.
A structure as small as this dogigloo might be better made with Struclite and then a finish coat of water proof cement with lotsa bonding agent. Structite is a cement mixture with styfoam and pearlite (perhaps) mixed in. With your wire mesh it should be self supporting and will be cooler in summer warmer in winter.
seeya in the funny papers
http://cementamericas.com/mag/pca-honor-green-efforts/
When I say "green" I also mean resource efficient. :)
http://cementamericas.com/mag/cement_cement_concrete_environment/index.html
Have a good one. :)
You should be able to squeeze the mixture in your hand without having it fall apart, or having water drip off it when squeezed.
Hope this helps.
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=85517856
I never thought I would ever see a dog that resembles mine.
