1 Pin & 6 Buttons - Analog Keyboard
158
Posted
Introduction: 1 Pin & 6 Buttons - Analog Keyboard
How to connect six keys with one pin to the microcontroller. It often happens that our circuit is missing free pins. The method to solve this problem is many, for example:
This article can also see here:
1 pin & 6 buttons - Analog Keyboard
Step 1: Components
Step 2: Schematic
Connection of analog keyboard to Arduino.
Step 3: Software
The method to read the key is very simple. Each key gives different output voltage so using the analog-digital converter recognize which key was pressed. Because reading from the analog input may be slightly different, it is safe to check whether the value is in the range.
#define CHECK_KEY( __v0__, __v1__) __v0__ >= (__v1__ - 10) && __v0__ < (__v1__ + 10)
byte GetKeyNumber(int key){
  byte num = 255;
  //0, 90, 170, 236, 293, 340
  if( key < 10 ){
    num = 0;
  }else if( CHECK_KEY(key, 90) ){
    num = 1;
  }else if( CHECK_KEY(key, 170) ){
    num = 2;
  }else if( CHECK_KEY(key, 236) ){
    num = 3;
  }else if( CHECK_KEY(key, 293) ){
    num = 4;
  }else if( CHECK_KEY(key, 340) ){
    num = 5;
  return num;
Download source code: AnalogKeyboard.ino
Step 4: Testing the Keyboard
wwwGoogle pluseTwitter
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
