$1 Touch Screen Stylus
Published
Introduction: $1 Touch Screen Stylus
Hate using your fingers to draw on your phone/tablet? Have you ever wanted to use a stylus on your iPhone or other device with a touchscreen? Well here is a cheap effective way to build a touch screen stylus com. This DIY will show you exactly what you need and how to build the fully compatible stylus, I'll show you how to make a touchscreen stylus with cheep material.
Step 1: Materials
1 - Pen
1 - Q-tip
1 - Pair of scissors
1 - Electrical tape
1 - Tin foil
Step 2: Building
Start off by taking a pen of your choice and removing the inside ink and pen tip.
Then take the Q-tip and cut it in half at a slant making it easier to lodge into the pen tip with the scissors
Step 3: Building
Insert Q-tip into the pen firmly through the tip.
Step 4: Building
Wrap the pen outsides in tin foil. Secure with Electrical tape. Make sure to lightly dampen the Q-tip before each use.
Step 5: Finished
Now that your pen is done, it can be used with accuracy and is applicable with any touchscreen device.
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    8 Discussions
    she really should ad a picture if it really does work i think you should
    Wow this really works! Thanks!
