Introduction: Wireless Speaker That Connect's in 0.0000000001 Seconds !
Feel Like Pairing Wireless Speakers Is really Time Consuming Process You Need To Make This Wireless Speakers That Connects In 0.000000000001 Seconds (Instantly) , Although It Doesn't Use Bluetooth or Wifi It Works For Every Smartphone, Tablet's etc...
To Build This System Just You Will Need a Audio Amplifier , I Used PAM 8403 its very cheap, transformer coil and speakers of your choise !
Let's Get Started !
Before I Recomend To Watch The Video You will know What i am tallking about !
https://youtu.be/zXQQFXG2uHA
Step 1: What's the Problem With Bluetooth ?
DELAY !
Pairing a wireless piece of headphones to smartphone takes a lot of time .
And Sometimes The Weird pitch shift , and latency is always big NO NO !
Also You Have To Recharge The Small Battery .....
Step 2: So How It Connects in 0.000000001 Seconds !
Every Digital Wireless system has Delay Due to various factors like medium,range,processing,etc...
But This Delay Can Be Reduced by use of analog transmission methods .
This System Works Similar To a Electrical Transformer , Supplied High Voltage is converted into magnetic field this magnetic flux get induced onto secondary coil and generates voltages in proportion to the coil turns ratio .
Here Coil Inside Smartphone Speaker Acts as Primary coil and Our External Coil Recives the Signals
This Signal is very small so we need an amplifier to be able to drive bigger speakers.
You Can Connect Ear buds or loudspeakers , and similarly can extract audio from any speaker source smartphone,tablet,tv, as long as it has speakers !
It Doesnt Require Pairing Since it's Analog and just does the job of Re- Amplification it connect's in 0.0000000001 Seconds !
Step 3: How to Make !
★☆★ Buy Parts from your online local store ★☆★
1. Winding Wire http://geni.us/cljvl
2. PAM8403 Amplifier Chip http://geni.us/neVcO
3. Speakers http://geni.us/PEuk
1. You Will Need a Coil Which you can easily get from an old power-supplies transformers ,or just wound it yourself
2. To Boost The Small Audio Signal Amplifier is required ,I used class D PAM8403 ,But Any Amplifier Will Work Fine ,Even Your Home Theater Also ! (Just Make Sure Volume is Low !)
3. Connect Speakers at Output and Bridge Right and Left Channel Input and Connect The Coil ,Supply The Voltage And Its ready !
4. You May Need to put a capacitor in parallel with voltage source because ,for the higher amplitudes this amplifier will draw more current so to keep it running continuously add a 2200uf capacitor.
Step 4: Can You Get Superpowers With It ?
Yeah !
if Some one challenged you to guess the music they're listening to , You can guess the music by just simply hold the coil over earphones and listen the music clearly !
There's Even More !!!
Listening to the electromagnetic waves is whole New World , You May never experienced this but might be familiar with interference created by calls with speakers ! yeah just try scanning different parts of your smartphone and you can able to listen what going on inside CPU , RAM, Network Chips etc...
See My Video Here
You Can Give Me Superpower's By Voting Me ! Thanks a Lot !
Also Check Out My Youtube Channel !
https://www.youtube.com/user/kedar123456889
Circuits Contest 2016
Amps and Speakers Contest 2016
