The heart of this project is the STCS1 from STM Electronics:
http://www.st.com/stonline/products/literature/ds/13415/stcs1.htm
Warning: Some parts of this project were designed and fabbed using professional software and hardware. However, all aspects of this design could be done using open source products or some perf board and wire wrap.
Remove these ads by
Signing UpStep 1Read the Data Sheet!
http://www.st.com/stonline/products/literature/ds/13415/stcs1.pdf
From this we can easily see some of the key features of this chip:
■ Up to 40 V input voltage
■ Less than 0.5 V voltage overhead
■ Up to 1.5 A output current
■ PWM dimming pin
■ Shutdown pin
■ LED disconnection diagnostic
i can kinda read schematics but im confused is their a way you could post a schematic with pics of the parts in their spots or a pic of the board that is easier to see the traces
additionally i would want to run this at max voltage would i use the same resisters
Simple. If your prototyping one device to see if it works, 99.999% of the IC Manufactures have a sample program. The few that don't you most likely request a few samples... The only thing you agree to when ordering samples is, you can't resale any parts you received for Free. If you make money on something, you have to buy it.
And yes I know it's an old post but thought i'd add my two cents... =)
Also, the schematic shows C1 and C3 as 4.7uF and the BOM lists them as10uF and 1uF. Which should I use?
Thanks
I think a 100watt incandescent bulb =1750 Lumens and my 3 watt leds are about 100 Lumens.So I guess I only have a brightness of about 51 watt incandescent right?
oh well its fun anyway. Now I just have to see what different type of cap,I could use that would be smaller the the ceramic .01 cap.All the other parts i got are small and the cap,.now is too big.
well have fun.
Johnny
TKS
Johnny
I connected it in your or the DIY. dia. and it works fine.I didn't disconnect it to see if that would have any effect.
I want to wire up one useing the STCS2.but don't know either to connect it or not.
Tks
Johnny
Is that being used to regulate the voltage? I don't know.First time using these chips.
tks
Johnny
RF=VFB/ILEDS=100mV/700ma=142mOhms
I glad the other cir. works very good.
Thank for the reply and have a nice day.
Johnny
TKS
Johnny
reason is ,that it is a little bigger to solder with the pre made pc. board.
tks again.
very nice cir.
www.st.com/stonline/products/literature/ds/13968.pdf
Tks for the CIR.
Would the STCS2PR driver work using the same pin connection?This one has 10 pins as the STCS1PHR only has 8 pin connections.Just the STCS2PR is bigger to work with.
TKS
Johnny
could you make them larger?
Any chance of putting this up on a blog entry (or elsewhere) on your website...?
tkx
You should drop me a line at sales(at)ohararp.com . As a teaser I do alot of low power stuff and think you best bet would be to use a single li-ion setup with a 12V tolerant charge setup. I would recommend using this buck-boost led driver for good efficiency and best use of the available power of a li-ion battery (see page 9 figure 10 http://www.st.com/stonline/products/literature/an/10232.pdf)
Ryan O'Hara
As an alternative to this instructable, I would highly recommend option 6 of Dan's great instructable http://www.instructables.com/id/Circuits-for-using-High-Power-LED_s/?ALLSTEPS. The FQP50N06L is a great TO-220 package that also gets hot, but is designed to deal with the generated heat. It is also a lot cheaper and easier to work with unless you have a specially made aluminum heatsink with a printed on power SO-8 pad footprint and SMD equipment readily available.
