This is a 10 cell tetrahedral kite, based on the bendy straw design by emilyfis.  http://www.instructables.com/member/emilyfis/
Materials: (Most can usually be purchased at a dollar store)
Bendy Straws
Straight Straws
Packing Tape
Scotch Tape
4" mini zip ties
Mylar wrapping paper.
Yogourt container lid
Step 1: Straws
Connect 3 bendy straws to make a triangle. Tape is not needed. Build 20 triangles.
Step 2: Make basic cell
Tape 2 triangles together with scotch tape at about 80 degrees to make a cell. Make 10 cells.
Step 4: Bottom Row
Join 3 cells together with zip ties.
Step 7: Braces
To keep the kite as light as possible, straight straws are used as bracing, instead of wooden dowels. Tape the straight straws together to build 3 braces. Zip tie the braces to the back of the kite.
Step 8: Bridle
Tie a bridle loop from the top to the bottom of the first cell. Optionally  for greater control, the bridle can go from the top of the first cell to the bottom of the last.
Use a paper punch to make a hole in the lid of  a yogourt container and cut a circle around it to make a soft plastic washer. This washer will let you quickly adjust how the kite flies. Thread the bridle through the washer and attach with a simple loop. Tie your kite string to the washer.
General Rules:
To make the kite more stable, slide the washer up. To make the kite catch more wind, slide the washer down.
Kiteman says: Apr 14, 2012. 1:54 AM
I like the bridle-adjuster.
This must look amazing on a sunny day, or flown over a well-lit area at night.
(This is also a cool kite to make with a whole bunch of kids - each one makes a cell, and you fasten them all together. Even better, if you have more than 10 kids, you just make a bigger kite. Be aware, though, that tetras have more lift than you'd expect, so be safe.)
Mr. Matt in reply to KitemanSep 7, 2012. 10:04 AM
Great idea for the kids project. I'll get right on it and see how well they work together.
tizart7 says: Apr 15, 2012. 11:57 AM
real nice work !!!
rimar2000 says: Apr 14, 2012. 9:49 AM
10 cells? I counted only 9.
Unless you count the whole set as one cell.
Anyway, nice kite!
yapoyo in reply to rimar2000Apr 15, 2012. 6:38 AM
there's one hidden that u cant see....
rimar2000 in reply to yapoyoApr 15, 2012. 8:02 AM
Oh, yes! Now I see it. Thank you, I lost another chance to remain silent.
orviseatsapples says: Apr 15, 2012. 12:43 AM
Brilliant!
TheScienceMan says: Apr 14, 2012. 6:36 AM
Cool, good
idea.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
