Introduction: $10 Dog Backpack
Dog packs are insanely overpriced. A dog pack is basically two fanny packs attached to a dog harness. Why not make your own? You can reuse existing material instead of making something new. This pack is greener, cheaper and totally awesome.
Step 1: Closet Check
Check your closet for any old laptop cases, purses, backpacks, camera cases, etc.
Some things to look for:
Check thrift stores for purses and pouches that can be used as saddle bags. See the Step 3 for qualities to look for during bag selection.
You will also need:
- Velcro
- Zippers
- Buckles
- Snaps
- Nylon Strap
You will also need:
- Needle
- Thread
- A dog willing to wear a pack
- Very basic sewing skills
Step 2: Harness the Beast
I won't give exact measurements, this is a custom pack for your dog.
To make the harness that will hold the pack:
Cut three nylon straps with the following lengths:
- Measure the circumference below your dog's neck, add 6".
- Measure the circumference of your dog's waist, add 6".
- Measure the length between the dog's waist and shoulders, add 12".
- Using the lighter, melt the ends of the straps so that they don't fray.
- Sew the pieces together to create a harness (see photo). Use a buckle for the chest strap and Velcro or another buckle for the waist strap.
- The straps don't need to be tight, weight in each side of the pack will hold it on the dog.
- If in doubt, make the straps longer, they can always be shortened later.
Step 3: How Dorky Is Your Dog?
I didn't have anything suitable to use for the saddle bags at home so I started checking thrift stores. My dog is clownish, so I selected two multi-colored purses with pictures of cats and makeup on them. The two purses cost me $7.
You will need two bags of similar size. Good qualities to look for while you search:
Attach the saddle bags to the harness, sewing to the chest strap and the waist strap on each side of the center strap.
- Waterproof Rating (dogs are not careful about crossing creeks)
- Pockets
- Zippers
- Length (should be similar to the distance between the neck strap and waist strap)
- Height (use common sense)
Step 4: Test Drive
Kona's has already traveled 40 miles with her pack on! I wouldn't change a thing about it.
Please post pics if you make a custom pack for your dog!
