We had an old 10 HP Briggs horizontal shaft electric start engine from an old riding mower that looked like it would fit the bill. We bought the plans for their UH10F craft. We liked it because it only uses one motor. Most hovercraft use a separate motor for lift and thrust. This one directs approximately 1/3 of the thrust air to provide both lift and inflating the skirt. Most of the materials could be found at the local builders supply.
The only parts we needed to buy from Universal Hovercraft were the Plans, propeller, propeller hub, and the skirt material. Although it busted our $500 budget we decided to purchase their materials kit which included all the epoxy,fiberglass , screws, and glue. The skirt is the heart of this thing and we didn't want to save penny's on something this critical. It was a fun project for the both of us. It would be a great Father and Son project.
Remove these ads by
Signing UpStep 1: TOOLS AND MATERIALS LIST
Tools required
Table saw to cut 4 X 8 Foam and plywood
Keyhole saw or saws all to cut openings for air ducts
Scroll saw for plywood duct and body peices
Shop vac for vacuum blanket
Two to four saw horses
Several plastic squeegees
Basic hand tools
Materials list
From home depot cost about $80
For the hull
1 sheet 1" white Styrofoam
4 sheets 2" blue construction foam 4 x 8
4 sheets 1 /8" plywood (doesn't have to be marine)
2 12' lengths 1 x 2 lumber( pine is fine)
Hardware kit from Universal Hovercraft $349
This kit contains every little thing you will need to complete this project including
Plans, fiberglass, skirt, glue , skrit screws,epoxy, and a 24' steering cable
DRIVE KIT from Universal Hovercraft $159
Includes propeller, hub, and bushings
MISC. $20
Small roll plastic sheeting 2 to 4 mills
Paint
Total cost of the project was around $600 plus the cost of a new or used motor.
Visit Our Store »
Go Pro Today »
Mickydee
This is a great project for Father/Grandfather and Son/Grandson. Universal Hovercraft http://www.hovercraft.com/content/ is a great company for DIY hovercraft projects. I build a UH12T4 with my high school soon back in 2002 -2006. We have had a great time with it and now belong to the http://www.hoverclubofamerica.org/ Hoverclubofamerica. The club has great resources for recreational hovercrafting throughout the USA. Most of the members have either built or operate a homebuilt hovercraft. If you and your Grandson get into this hovering more be sure to check out the HCA. We sponsor over 20 events a year at many locations around the country. http://www.mapquest.com/?version=1.0&hk=7-HQDmHdt9#dd126f889ef3d31a8d5316c6 Here is a map of the locations for the 2013 season. Hope to see you at out hovering this year!
Scott Hull
mickydee
I can get most parts here
Can you tell me a ratio to increase the size to accommodate 2 people or 180 more pounds
It is a lot of fun Mickydee .
My grandson and I had a great summer working together.
We really got to know each other.
We both learned some new skills. That's what these instructables are all about.
Mickydee
mickydee
mickydee
Two people can easily lift it onto the trailer. It could be easily winched on if the motor was left idling to provide a little lift.
article
be traveling about.
Looks liks a blast to ride in, too! I only hope I can succcesfully built it!
Quite entertaining and instructive, and one of my top ten favourites!
Thanks!
