Introduction: 10 Life-Changing Life Hacks - You Can Try Right Now!
Picture of 10 Life-Changing Life Hacks - You Can Try Right Now!
Boost the chances of finding a lost phone, and sleep better starting tonight, with 10 life-changing lifehacks you can use right now.
Also, make sure to check out my other Life Hack videos:
10 Life Hacks For Summer!
10 Life Hacks For Christmas!
Step 1: Watch the Video! :)
NOTE: These projects and results are portrayals of my own personal experiences. Your results may vary depending on your location, experience, and modifications. Use of this video content is at your own risk.
Step 2: Life Hacks in This Instructable
Picture of Life Hacks in This Instructable
Life Hacks are tips and tricks to help make your life a bit easier. Sometimes common sense isn't so obvious until you've seen it.
So, in this video you'll see how to;
- Automatically block ads on smartphone apps and games
- Avoid the "walk of shame" at the gas pump
- Start your grill with potato chips
- Peel a Kiwi the fastest and easiest way
- Boost the chances of finding your phone if it ever gets lost
- Win the battle between hot and cold in the shower
- Effortlessly keep your tie straight and in place
- Keep kitchen rolls in place when wrapping up leftovers
- Get a better nights sleep without the cost of expensive pillows
- Turn your plastic bags into an instant bag dispenser
Watch the video HERE
Step 3: Instant Ad Blocker
Picture of Instant Ad Blocker
This little trick will make it so you can play games on your smart phone without having to deal with strategically placed ads.
Simply try switching your phone over to airplane mode.
This will turn off the phones radio function, and even make your battery last longer, so you get more playing time, without the incessant distractions.
Step 4: Fill Port Finder
Picture of Fill Port Finder
If you've ever rented a car, you know the feeling of pulling in to the gas station, only to realize too late, that you forgot to check which side the fill port was on.
Rather than being caught doing the walk of shame, you can avoid the embarrassment altogether, by glancing at the pump icon on your gas gauge.
There's a little arrow pointing to the side you need to fill up on. So remember this little trick the next time you borrow a car, and you'll be a gas pump hero on the very first try.
Step 5: Tinder Chips
Picture of Tinder Chips
It's the season for grilling, and if you want to switch things up at your next party, why not skip the lighter fluid, and try starting your charcoal with a handful of potato chips?
They make a surprisingly flammable tinder, and will easily burn long enough to light up a stack of coals.
...And this way, you won't get that lighter fluid taste in your meat.
Step 6: Easy Kiwi
Picture of Easy Kiwi
The kiwi fruit. It's so exotic and so delicious, but how do you peel it without hacking it up and leaving so much fruit on the skins?
The solution is so simple you won't believe it. Try using a spoon.
Just cut the ends of the kiwi, then push your spoon inside, making sure the back slides in along the peel.
Now carefully work the spoon around the inside edge, until the entire fruit pops right out.
It really is that quick and easy, and hardly anything gets left behind.
Step 7: Phone Finder
Picture of Phone Finder
Before your phone gets misplaced, take a picture of your email address, or some other contact information written in big letters.
Go ahead and save it as your lock screen photo, and now if your phone ever does get lost, the first thing anyone will see, is exactly how to get it back to you.
Step 8: Shower Setter
Picture of Shower Setter
Every day we face a torturous moment of truth, when we turn on the shower, and get blasted with icy cold water.
If it's not cold, then it's unbearably hot.
But you can easily fix this daily challenge with a bottle of nail polish or white-out.
The next time you find the sweet spot, mark the trim plate and the handle with a couple of dabs that line up with each other.
Now you've got the power to win this epic battle, by hitting the perfect temperature on the very first try.
Step 9: Tie Saver
Picture of Tie Saver
If your tie keeps getting twisted out of place, it's so frustrating to have to keep checking and straightening it all the time, isn't it?
Try rigging up a permanent fix with an old dress shirt, and a pair of scissors.
Carefully cut the front strip so you end up with a piece just a bit longer than two of the button holes.
Now then next time you dress up, simply slip one of these "tie savers" through the keeper loop on your tie.
Fasten it to the buttons on your shirt, and now your tie will always be straight, look great, and fall back into place even when it gets knocked around in the wind.
Step 10: Roller Holder
Picture of Roller Holder
Arg, the frustration that comes when wrapping up leftovers, because the rolls keep pulling up out of the boxes.
Sometimes they seem more trouble than they're worth, but luckily, there's a quick and easy fix.
Just get a knife and cut a downward facing arrow on the ends of the boxes, directly in the center.
Now simply push these tabs inward to secure the roll in place, and keep it conveniently in the box, every time you pull.
By the way, some boxes already have little push tabs built right in. So start using them, and make make your life that much easier.
Step 11: Sleep Support
Picture of Sleep Support
Do you wake up in the morning with a stiff neck and a headache?
It might be because your pillow is cranking on your spine all night long.
But before you spend loads of money on specialty pillows, try lifting your head a bit and tucking the edge of your pillow, under your neck.
Lay back down, with the corners over top of your shoulders, and you've just made an ergonomic support for your neck and head.
This will help straighten out your spine, and instantly make any pillow you're using, feel like it should have cost a lot more.
Step 12: Instant Bag Dispenser
Picture of Instant Bag Dispenser
Plastic grocery bags. They're worth hanging on to, but they can quickly take over your drawer space.
To eliminate the clutter simply flatten them out, and fold the bags in half lengthwise.
Now lay them in a straight line, with the handles overlapping the bottoms of the previous bags, then roll the whole thing up.
You can add as many bags as you want, and in a couple of minutes, you'll have an instant bag dispenser that will take up very little space.
Now if you put this in some kind of container, it will dispense one bag at a time, whenever you need it.
Step 13: More Videos
Well there are 10 life changing life-hacks that you can try right now.
These are all Life Hacks that I personally use all the time, and I recommend you to try them as well.
If you liked these projects, perhaps you'll like some of my others. Check them out at www.thekingofrandom.com
IvanW30 (author)2017-07-28
Most hot water tanks come from the manufacturer preset at 160 degrees F.
Stepping down to 140 F will reduce your monthly hydro bill
Stepping down to 120 F, is a no no, it is not recommended, due to insufficient temperature needed to kill some of the harder to kill bacteria that are in our environment.
Single handle taps can, & should be set to the specific location on the dial, that will be the maximum temperature that the homeowner decides is a comfortable temperature for the whole family.
Regardless on how far anybody turns the handle, it will stop at the preset position, which is the maximum temperature that was predetermined.
This should be on all single handled control taps.
It is a safe guard to prevent accidental burns from turning the handle to far, possibly exposing a child, or non-suspecting adult to the maximum hot water temperature range.
If needed; identify the manufacturer, & then going online to there website.
There you will find the necessary instructions on your make & model, & how to set the position of the handle to the maximum desired temperature.
Accident is just a word until it happens
ccmrry (author)2015-08-21
A better idea for the right temp for your shower, and your whole house: adjust the thermostat on the water heater so that it's no more than 120°. No one will ever get scalded again, and the hot water at the lavatories will be safe for children. Why would you heat water up, only to have to add cold water to it? That's a waste.
RichardS50 (author)ccmrry2015-09-05
The reason for having hotter water in your heater is to avoid disease. If your water is kept at 120F bacteria will be able to grow very quickly. I seem to remember that you should keep your boiler at minimum of 80C (I think that's about 175F).
US Water heaters can only go to 140°F for safety reasons. (Regulated by law.) If you "hack" your heater and get 180°F out of it, stand by for some lawsuits from guests in your home. According to the http://www.burnfoundation.org,
Hot Water Causes Third Degree Burns…
…in 1 second at 156º
…in 2 seconds at 149º
…in 5 seconds at 140º
…in 15 seconds at 133º
And I have mine set at 140°F, and the reason being, I have a large tub, (I'm a large person) and I can't fill it with a sufficient quantity of water to bathe properly. And mixing a cold and hot stream to get the temperature you want or need isn't a waste. If you're arthritic (I am), and need a large quantity of hot [not scalding] (105°F to 108°F) water, you're going to step up the temp, and mix it to a safe reasonable temperature.
Don't be ignorant, LOOK IT UP!
ccmrry (author)John T MacF Mood2016-05-17
I don't quite understand the "don't be ignorant" remark, as it's never my goal. Obviously, no suggestion works for everyone, and mine is intended for the average person's showers and lavatories. The needs of large arthritic people did not occur to me, and was not a consideration. I can sympathize with your arthritis, as I suffer a bit from it myself. I do hope you can find ways to relieve it. If my suggestion doesn't work for you there's no need to defend your own practice. But, if you still have to mix cold water with your hot you've probably heated it too much. Some experimentation might yield a lower setting that could work. I realize that saving energy is not important to everyone. Take the suggestion or not.
John T MacF Mood (author)ccmrry2016-05-17
It's been proven you can fix ignorance, by education. You can't fix stupid. Setting a water heater at 170°F to 180°F as suggested by some contributors, well, that's just way beyond safe. It's dangerous.
As to the 140°F setting on my water heater, if I use it at the suggested lower temperature(s) then I CANNNOT mix to a comfortable use temperature. With my water heater set to 120°F, it will not render a tub full of water at a temperature over 98.6°F. It's a large tub.
I also do not feel comfortable washing my clothing and dishes with water that won't help sanitize them.
Saving energy, good idea. I have a heavy insulating jacket on my water heater. I use it for hot water during off hours (our power provider has a higher price for power used during peak hours), and I use what I need, and don't over do it.
I've tried the lower temperature, and it doesn't clean my clothes, dishes, or myself as well as sanitary rules require.
The Canadian standard (very similar ti US standards) for hospitals is:
For use in cleaning hands, etc and preventing any growth of bacteria in plumbing the standard is 60C (140F) for hospitals. This is a minimum requirement for infection control, etc.
Typically for laundry and commercial dishwashers the temperature standard is 82C (approximately 180F) again by hospital standards.
(Alberta Health Services construction standards for new hospitals).
thormj (author)John T MacF Mood2016-10-11
That's my favorite thing about my tankless heater: hot showers forever (as long as I pay the gas bill)!
I keep it at 140F because we have dogs and you have to get above 130F to kill fleas that they might bring in and put on the laundry my son leaves strewn about. Any lower and there is a low black cloud in his room, despite me using Frontline.
MatthewN32 (author)thormj2017-04-17
Same, but mine stopped working and we could do a warm load in the washer or take a shower warm enough for me to be comfortable with for days
I recently moved into a new home where the previous owner had the thermostat set as high as it would go. I had neglected to check it first and it ruined my new DISHWASHER AND SEVERAL LEAKS IN VARIOUS PLACES. It literally melted the workings on my dishwasher and expanded all gaskets in the faucets. It's extremly dangerous.
Seriously...you need to upgrade your water heater to a greater capacity, or get a smaller tub. Those high temperatures are dangerous in a domestic situation. I hope you dont have children. I have a peripheral nerve problem, and am advised to regulate water very closely as far as temp goes, though I never use a bath.
I am sorry about your physical disability, but you need to be safe. I never use hot water in my washing machine...and a dishwasher heats its own water.
I totally agree with you, 175* is very dangerous. 140* is plenty hot enough.
JimmyM92 (author)RichardS502017-01-24
175* is extremely hot. No need to say about the chances of a major explosion if it ever overheats. 125* to 140* is very adequate, I do plumbing and have seen major burns from even 140* hot water.
Avoiding disease with water temperature has more to do with food rather than showers. As a veteran chef I just figured I would attempt to cure your fear of bacteria. Also, to truly avoid this bacteria that seems to concern you, use boiling water via your stove or microwave, which in effect uses less electric than setting your water heater at a specific temperature. Obviously you wouldn't be soaking in a tub of boiling hot water, right? I know it certainly would never make it's way through my shower head. Just information for the weary...or should I say worried?
Don't forget that most houses only have one water heater that is not only used for bathing and cooking, but also for washing clothes and dishes. High temps are good for making sure said clothes and dishes are cleaned. Personally I would rather turn up the temp to my water heater just so that I can get a good shower and not worry about the dishwasher or laundry machine ruining said good shower. This applies even more so when you are in a house with 4+ people or that one roommate that loves making the bathroom into a sauna whenever they shower.
ClintM11 (author)Phantom55822016-02-24
The suggestion to keep the water temp lower is not just one of safety, but for the environmentally concerned. Washing clothes in hot water is a practice many discontinued long ago. Modern detergents work very well with cold water. My comment was not directed toward people who would turn a bathroom into a sauna, or who think only of themselves. I wouldn't know how to address that kind of person, or say anything that would get them to change their wasteful behavior. Having said that, I offer this from the NY Times:
"About three-quarters of the energy use and greenhouse-gas emissions from
washing a load of laundry come from heating the water--a practice
that, scientists say, is often wasteful and unnecessary."
doxiepoo (author)ClintM112016-04-19
The key word here is "often". I an not a stickler on msny things, in fact it would be better if i upped my game where i eould keep things s little more organized. But i am a believer in hottest wster i can stand to do my lsundry and cleaning. I even have to wait about 15 minutes before i can put my hsnds into dish wster ( yes. I actuslly hand wash most if my dishes becsuse i never hsve enough dirty at the same time to use a dishwssher.)
Katie5757 (author)doxiepoo2016-07-24
#doxie.. like you I dont have a dishwasher. However, my hot water is 60C and way too hot to put my hands in it for hand dishwashing...I use a delay and dishbrush for the majority... research today's technology with regard to laundry products....very few instances of requirement of high temperatures, unless you are dealing with "medical" laundry i.e soiled bed linen, reusable bandages, etc.
Occasionally I will put some towels through a hot wash, but only if there has been some infection around, and there is a recommendation that shared items be given some special attention.
Anne46 (author)doxiepoo2016-05-17
I thought most washing machines (for clothes) were cold fill only now. Certainly new ones in the UK are as far as I'm aware.
Great tips btw, KoR.
blueye81 (author)ClintM112016-03-30
A little bit late maybe, but talking about bacteria, you mean "legionella"?
Legionella [...] [are] common in many environments, including soil and aquatic systems, with at least 50 species and 70 serogroups identified. The bacterium, however, is not transmissible from person to person:[2] furthermore, most people exposed to the bacteria do not become ill.[3]
Moist heat sterilization (superheating to 140 °F (60 °C) and flushing) is a nonchemical treatment that typically must be repeated every 3–5 weeks.
Risk factors for infection include older age, history of smoking, chronic lung disease, and poor immune function.[6]
It is recommended that those with severe pneumonia and those with
pneumonia and a recent travel history be tested for the disease.[7]
Katie5757 (author)Phantom55822016-07-24
Dishwashers apparently dont use hot water, they heat the water in the machine. You too need to upgrade the capacity of your water heater, and maybe instal a sauna...that is so wasteful. A friend of mine has a timer on the shower to limit the luxury of steamed up bathrooms. His family doesnt like it, but unless they share the electricity bill, that is the way it is....soon learn to have a quick and vigorous shower.
Katie5757 (author)RichardS502016-07-24
60 C
if you set your boiler anywhere near 175F, you have a VERY serious scald/burn risk. DON'T do it!
DaveM185 (author)ccmrry2016-05-17
Because if you don't keep your heater over 150• your tank can easily start breeding things that you don't want
doxiepoo (author)ccmrry2016-04-19
The ptoblem with this is that 120 degrees is not hot enough for dishes.
ccmrry (author)doxiepoo2016-04-19
I agree, 120° is not hot enough for dishes. I use an electric kettle to heat my water for dishes. I too wash dishes by hand.
Ka G (author)ccmrry2016-03-14
But What About Icy Cold??? Huh?!?
Androgynous14u (author)ccmrry2015-10-25
Nice.
meljon777 (author)ccmrry2015-09-06
Good point. Thx.
amphy777 (author)2017-02-16
Great kiwi hack - thank you! I've tried it and although I couldn't do it as just one scoop the result was great! I do know that kiwi skin can be eaten and is more nutritious but it's also hairy and more sour than the flesh so I prefer them peeled..
PEGinCharlotte (author)2016-11-29
The plastic bag hack is pure gold! Thanks so much.
CRAZYBOUTDIY (author)2016-11-22
Awesome life hacks, definitely gonna try the first one bcs I always get annoyed of ads Thx so much!
Michele Gamer (author)2016-11-15
Awesome video i will make sure to try this some time! :)
Nadine Sundown (author)2016-05-17
Lol, the fire was already burning before you added the chips! Should actually Start the fire when showing a fire starter. One other thing, Eat the ENTIRE kiwi, peeling and all. That is the largest part of the fibre and minerals from the fruit. ;) Like the hacks though.
Katie5757 (author)Nadine Sundown2016-07-24
I live in the land of the kiwi... eating the peeling....ummmmmm. you have no idea what they spray on those things.....do you eat banana skins as well?????
RogerD5 (author)2016-05-24
LOL. For a second I was about to comment that you were plagiarizing(idc about the spelling) Grant Thompson, then I remember you're the king of random
MadeByGloria (author)2016-05-20
Love this! The tie saver and bag dispenser are pure genius!
Tumunga (author)MadeByGloria2016-05-20
I like the tie saver, but they've been making these things for years, and they look good too: http://www.gentlemansgazette.com/tie-clip-bar-prim...
SaraB108 (author)2016-05-17
brilliant
CMLRI2015 (author)2016-05-17
love the tie idea. Brilliant! And the kiwi!!!
OpalF (author)2016-05-17
lots of good ideas and i will be using the plastic bag idea but i cant see the one for lining up the center of dowels, which is the one i was particularly interested in. Clicking next didnt take me anywhere either.
Syx (author)OpalF2016-05-17
If you came in from the email, it's because the dowel centre finder is on a different instructable to this.
Here's the link:
http://instructables.com/id/Dowel-Center-Finder/?ALLSTEPS
JackG54 (author)2016-05-17
Wow! You are the CHAMP!! Was at first only interested in a couple but wound up planning to implement at least 6 right away! In particular, the grocery bags! ??
eatorganic (author)2016-05-17
I really enjoyed this. Great ideas. Oh the beauty of computers!!
Ebensvh (author)2016-05-17
Build a cnc router
pdxlake (author)2016-05-17
Going to use the Pillow Hack tonight as I'm traveling for work and want to have a good night's sleep!
banman11 (author)2016-05-17
WOW! Amazing tips....
Thank you for your lateral thinking....
scarnahan2 (author)2016-05-17
Awesome tips and ideas. I can't wait to share these with my family.
Capt'nA (author)2016-05-17
Good way to use Pringles, 1 would have been enough to light a barbie. Thanks for the pillow trick I'm always waking with a stiffy
taur561 (author)2016-05-17
Wow . Now there are tips I am going to try . I always get headaches while sleeping so that pillow one is a must .. And my wife is guaranteed to try the plastic bag one .
Great . Keep them coming
KerstinL1 (author)2016-05-17
#5: That guy had a wand in his shower. Why don't people take it down and point it away from them until they find the sweet spot? That's what I do :\
About This Instructable
573,649views
1,229favorites
License:
Bio: Random Weekend Projects
More by The King of Random:5 Ways to Start a Fire, Using Water How to make a Batarang like "The Dark Knight"How to Make Ninja Stress Balls
Add instructable to:
