3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
10 Minute Pressure Canned Tomatoes
No pantry would be complete without home canned tomatoes :) I can "raw pack" and "stewed" for many future meals. If you think you don't need a pressure canner then canning tomatoes will make you change your mind. Processing them in a pressure canner for only ten minutes is so much nicer than 85 minutes in a hot water bath!
Step 1Boiling water
Boiling water
Start out with lots of tomatoes. It doesn't matter if they have blemishes, marks, or whatever, most of them will be used. Wash them up but do get rid of any that are in really bad shape.
Drop them into boiling water for about 30 seconds or so. Small batches at a time.
17 comments
Sep 14, 2011. 7:55 PMamtrudell says:
Using the lemon juice in the tomatoes to acidify them, you can process pints in 35 minutes, quarts in 45. What is not mentioned in this Instructable is that venting time (ten minutes after the water boils in your pressure canner) plus getting your canner up to pressure (another ten to fifteen minutes) plus letting the pressure go down (another 15 minutes or more) brings your real processing time to 45 minutes or more. I'm basing my times on using a gas stove; a neighbor with an electric stove found these additional times were even longer.
Oct 10, 2011. 1:10 PMamartinez31 says:
I tried canning tomatoes for the first time this past week. I use the water bath method and was please with the results. I am looking into the pro's and cons of using a pressure canner instead of the water bath method. I appreciate the dialog in your post, it has been helpful. Do you recommend a particular pressure canner? And if so, why?
I have read that some people prefer weighted pressure control rather than the pressure gauge types, due to have a higher incidence of issues and failures. Do you have an opinion regarding this?
Thanks!
Oct 10, 2011. 4:18 PMamtrudell says:
I have a Presto pressure canner. They've been making them for years and they are considerably cheaper than All American pressure canners. They are made of aluminum and consequently easier to handle than stainless steel ones. If you are only using it for canning rather than any pressure cooking, the aluminum will not pose a food issue (aluminum getting into food). They have a gauge which I prefer. I have found weighted pressure control to be a little more confusing, particularly if you are going from 10 lbs pressure (or 11 lbs, as now recommended by USDA) to 15 lbs pressure. A friend of mine got a weighted pressure control and it didn't work well. If you can, buddy up with someone in your area who does pressure canning and see what works for them. My friend ended up going to a gauge control. It is recommended that you have the gauge checked every few years (or maybe more frequently if you use it a lot) by your extension service to see that it is registering correctly. I run mine on a gas stove and my friend runs hers on an electric. What I like about a gauge is that you can readily see if you have too much pressure -- that causes over-venting and loss of liquid in your jars and as contents over-vent they can make a good seal on your jars impossible if food particles get between the sealing compound and your jar rim.
Oct 11, 2011. 3:54 AMamtrudell says:
I live in Canada and all the Presto rubber parts are stocked in a hardware store I can walk to. However, I do most my preserving by water-bath canning, solar drying, fermentation, so I carefully store my Presto between uses. Every person has to look at their own situation before making an investment decision in domestic equipment.
Mar 3, 2012. 11:17 AMmadmedix says:
Your comment of "Wears out even when not being used" is absolutely true in all respects of hardware that uses rubber. Think of your car. The rubber timing belt is only good for five years whether the car is driven or not.  (if your engine has one: usually four cylinders: think Honda). Check your owner's manual for proof. The miles/Km vs time; always lean to the time.
Helluva risk to cheap out on. Here, the pressure and heat could do severe
damage to human hands/arms.
Thanks for detail on this instructable!
Aug 21, 2011. 6:43 PMsunshiine says:
This is super! Your pics are great! Thanks for sharing. I have never tried this method but I just might consider it next year.
Aug 31, 2011. 5:15 AMjbankston montgomery says:
I've never used a pressure canner in my life and wanted to know what is meant by "up to pressure"?
Aug 18, 2011. 8:22 AMkevinhannan says:
Spot on! I'll be doing this next year with some luck with my toms. Thx for sharing!
Aug 18, 2011. 1:46 AMsaffiertje says:
Great tuto!!! Gonna try this, but does it also work without a preassure canner??? I do not have one. For jamming I always use a pan with watter...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:kansasa(My Photos Facebook Page)
