3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
10 Minute Rocket
10 Minute Rocket
This instructable will teach you how to build a simple, ultra light rocket from household items (and of course a rocket engine)
Here's the supply list:
- 1 tube of superglue
- 1 roll of tinfoil
- 1 straw big enough to fit around your launch rod
- 1 deck of playing cards that you don't mind parting with
- 1 C rocket engine
- several rocket engine detonators + plugs
- 1 electronic detonator (and necessary cables)
WARNING: This is totally dangerous. I didn't die, but you might. It is NOT MY FAULT if you hurt yourself following these instructions.
Step 1Building Yourself Some Fins
  • last photo ←
The fins themselves are pretty simple, the difficult part is positioning them evenly around the rocket. To make a fin, first you'll need to fold a playing card in half hamburger style. Take your superglue and seal the folded halves together, like a sandwich. Glue is going to ooze out the sides and get all over your fingers, but just suck it up and take it like a man. Make two of these sandwiches and let the glue completely dry.
Now you can need to do a little bit of measuring, but nothing too complicated. Take one of the folded cards and put it perpendicular to the other, forming an L. Mark off the edge and cut it away so you're left with one square-ish shape. Repeat with the other folded card and, if you've done everything correctly thus far you should be left with two pseudo-squares.
Take these faux-squares and cut diagonally across from the curved corner to the corner directly opposite. You should now have four fin shapes, congratulations. Now onto the difficult part, attaching them.
97 comments
1-40 of 97next »
May 12, 2012. 10:53 AMShadow13! says:
Great instructable. I've thought about doing this in the past and just haven't taken the time. Clever idea for the nose cone. If you backed each fin up a little then they could help support each other(see diagram). The only problem with a rocket like this is if it maintains a parabolic trajectory towards the ground rather then just tumble because if this happens then it will continue to gain momentum as if falls and can do considerable damage. Hopefully when the ejection charge blows it will blow the nose cone off causing it to tumble rather then follow a parabolic trajectory.
May 12, 2012. 9:56 AMpie R []ed says:
Hello (zach),
I loved the instructable, and it reminded me of rocket I made last summer. By made I mean that I found as many engines as I could, chad staged them, and stuck fins on 'em. Attached is a picture. It flew. Mostly.
Sep 11, 2010. 1:25 PMfrenchie16 says:
HAHA
I saw somebody launch a multi-stage one of these! Just loosely tape a booster engine (something like a B6-0) to a regular engine (say, a B6-5), put a cone-shaped thing on top, and tape the fins to the upper engine, but so that they extend down past the lower one a bit. WHen he launched it, it went up for a ways, we saw the second stage ignite, and then… it just disappeared into the sky.
Mar 5, 2012. 7:19 PMilpug says:
Is the booster engine on top, or on the bottom?
Oct 13, 2010. 9:52 PMflamekiller says:
That's the most awesome thing I've read all day.
May 28, 2008. 4:27 AMjakee117 says:
u get a three good, but I extremely dislike the thought that i could kill my self... but I'd be happy what a hell of a way to die in your own amazing explosion dreaming of bigger ones.... im not emo I just like explosions and you may need to put a little more thought into the disclaimer, cuz it will probably not help you any... good one!
Nov 26, 2009. 5:42 AMColonel88 says:
No, it wouldn't explode, the rocket will probably just fall over, crack your rib if it hits you, and probably make you go to da hospital. If it hits your nuts then you can be just like Justin Bieber, with his girly voice. Stoopid can drive says if we get the most cans in the Tri-State region he comes to give our school concert.
Nov 26, 2009. 7:32 PMjakee117 says:
lol....that'd still hurt though
Aug 20, 2010. 9:26 PMhawkfrost64 says:
But then you'd be able to say, "I've been hit in the chest with a rocket" And Girls would be like, "Oh, wow, he's tough. Or an idiot." It depends, girls are weird.
Feb 16, 2012. 4:59 PMspeedracer425 says:
Good point.
Mar 23, 2009. 12:10 PMchappy789 says:
explosions are nice
Dec 22, 2008. 12:50 PMMattrox says:
lol
Dec 20, 2008. 8:34 PMShut Up Now says:
the only way i could see this killing u is if u lit it and then stuck it up ur...um... anyway, its that or shoving it down ur throat and then igniting it. (tho there wouldnt be enough oxygen for it to stay lit)
Sep 26, 2011. 1:50 PMclazman says:
The fuel contains an oxidizer!!!!!!!!!!!!!!!!!!
Dec 22, 2008. 12:07 PMCyberBill says:
"(tho there wouldnt be enough oxygen for it to stay lit)" Rockets don't need outside oxygen, they have the fuel and oxidizer both in the mixture. That's why we can use rockets in space. :)
Jun 29, 2009. 9:27 AMgreatchrismyster says:
im pretty sure they dont use rockets much in space, most of the time its just compressed air jets
Apr 10, 2011. 1:24 PMdavison112 says:
half right and half wrong.
the main rockets use ignition to produce thrust.
The MMU's (manned-maneuvering units) use small amounts of compressed air to move the astronaut in certain directions.
Dec 31, 2009. 3:05 PMtemp says:
have u ever seen a rocket launch. there is a lot of fire coming out and that is not from compressed air and that continues to happen in space
Sep 24, 2009. 5:37 PMdla888 says:
Compressed air wouldn't work in space because... There's no air in space! The gas that was rushing out wouldn't work cause there's nothing for it to push against. They use rocket engines in space. Basically they have fuel and an oxidizer. The oxidizer provides the oxygen and the burning oxidizer and fuel provides the thrust.
Sep 26, 2011. 1:54 PMclazman says:
Compressed air would still work!
The physics behind rockets is that "mass" be it air or other molecules. are exhausted from the nozzle. "Equal and opposite reaction"
The only problem with compressed air is that to achieve a sufficient mass flow rate the volume and pressure would be HUGE!!
Please take a physics class.
Sep 26, 2011. 5:10 PMCyberBill says:
Instructables has a policy: "We have a "be nice" comment policy. Please be positive and constructive with your comments or risk being banned from our site."
The comment you responded to is 2 years old, and the information you posted was already covered in other comments. You posted 3 comments on this thread, and I would say that none of them followed the 'be nice' policy. People are here to embrace knowledge and to help each other, please don't talk down to them.
I know that it can be hard to humanize some random post on the internet, but remember that there is a person on the other end.
Sep 24, 2009. 7:28 PMCyberBill says:
Compressed air works exactly the same way that rockets in space work. You don't have to "push against something". All you have to do is throw something off of the back really fast and for every action, you get a reaction.
Feb 14, 2010. 9:01 PMMathias Re'eh says:
newtons law " for ever action there is a equal and opposite reaction"
Feb 15, 2010. 10:34 AMCyberBill says:
In the case of rockets, the rocket is "pushing against" the gas that is being expelled.  Or, perhaps more correctly, the gas is "pushing against" the rocket.
There are two equal forces - one force is pushing the rocket one way, and the other force is pushing the gas the other way.
Imagine a mouse trap in space that is loaded with a marble - so that when the mouse trap triggers the marble goes flying.  What will happen is that the marble goes one way and the mouse trap goes the opposite direction.  There doesn't need to be a third thing (air) to 'push against'.
Since the marble has less mass than the mouse trap, and since the forces are equal, it means that the acceleration/velocity will be different for the two items - remember that F = mA (Force = mass * acceleration) and K = mV (Kinetic energy = mass * velocity).  If the marble is half the mass, it will be moving twice as fast.
This is exactly what happens when you expel compressed gas or use a rocket - the tiny particles of gas have very small mass, but they are moving incredibly fast.  This gives an appreciable amount of acceleration to the rocket.  This is why you always have to take into account that a rocket loses mass as it accelerates.
Feb 14, 2010. 10:33 PMdla888 says:
True, but that law was made on Earth. I'm not sure if it would apply to space.
Sep 26, 2011. 1:57 PMclazman says:
Now, I've heard everything. Please take a physics class!!!!!!!!
Feb 15, 2010. 10:25 AMCyberBill says:
Newtons laws apply everywhere, even space.  :)
Feb 17, 2010. 11:19 PMzottffssen says:
They don't apply at the quantum level.  :)
Dec 12, 2010. 4:54 PMBenjicg says:
and on the quantum level you do not exist untill I observe you, which since i have not done, renders your argument invalid
Jun 14, 2011. 5:48 PMtheCheez says:
I love literalists. :D
Sep 17, 2011. 10:28 AMBenjicg says:
literallists like you but dont think they know you well enough to say they love you ;)
Jun 19, 2011. 10:45 AMMathias Re'eh says:
I just realized how bad my spelling is xD
Feb 15, 2010. 11:05 AMdla888 says:
I did not know that. I thought that gravity affected them a lot, but it's been awhile since I looked at Newton.
Sep 2, 2009. 6:26 PMShut Up Now says:
whered u get that fact from??
Sep 2, 2009. 5:43 PMdagenius says:
disagree
Dec 25, 2008. 11:15 AMShut Up Now says:
forgot that. thx lol
Jan 4, 2009. 2:47 PMNetReaper says:
boom
Jun 18, 2009. 7:19 PMqballcat says:
and boom goes the dynamite
Dec 21, 2008. 6:09 AMjakee117 says:
...lol
Nov 19, 2009. 8:24 AMPyre says:
Ditch the
Way too complicated all  you need is a 5 cent birthday cake sparkler. Set the rocket down on it so the tip is in the engine, light the bottom of the stuff with a BBQ lighter, stand back. Lit off a lot of rockets this way and never had a problem.
1-40 of 97next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:(zack)
