loading
Finding the right location for your home cannot be overemphasized. Having your home in a wooded spot in the country is a cool thing, but you need to build away from the natural vegetation. Tearing down the woods to erect a home can be injurious to the ecosystem and end up disrupting the life and the habitat of the wildlife as you set out to set up roads and utilities. More information about green and sustainable building processes
Step 1: Build Your Home in the Path of Solar
You need to ensure that your home is not shielded from the sun at the location that you choose to set it up, at least for the most part of the day. This will ensure that the solar panels that you install have long exposure to the sun and will enable you to cut down your energy bills by about 10 percent. Build up your home so that its façade and most of its windows will face the southern side, including the awnings and overhangs to shield you from the hot summer sun.
Besides, to make most of the sun, you will need to build your house with materials that will absorb and radiate the heat from the sun. Planting trees next to your house on its southern side will provide your home with a natural shade and also help you to maximize the energy from the sun.
Step 2: Do Your Research
The new technologies have brought with it an explosion of information about building a green home. You can quite easily access this information, and this will give you enough guidance when it comes to selecting building material that is eco-friendly, such as the available sustainable, toxic-free, and recycled materials. In this case, research will guide you on the available eco-friendly options for roofing, lighting, insulation, flooring, and painting.
Step 3: Ensure You Minimize Your Footprint
For you to minimize your footprint, you will have to eliminate all the unnecessary wastages regarding the home machines and products that you use at home. Do not buy what you do not need as this will eventually clutter your environment before it ends in the waste bin. You can recycle products such as aluminum cans and plastic bottles instead of trashing them. You can dig a well in your home and avoid buying water in plastic bottles. You can also return reusable bans and packages to their vendors instead of stashing them in your bins, thereby reducing your litter load. All these measures will significantly bring down your wastage and energy consumption.
Step 4: Ensure Your Home Has Ample Insulation
Adequate insulation will help you make a great saving in terms of the cost of energy. With increased insulation comes increased capacity for preventing heat gain and loss through the roof, walls, foundation, and the windows. Proper insulation will aid you in retaining and losing your home’s heat, and this will bring your electricity bill significantly down.
Step 5: Plan Your Roofing
You will need to seriously consider your roofing as it provides protection for your walls. Take note of the roof’s shape and weight since they determine the efficiency of your home’s energy. A proper drainage system will be a boon to your roofing as it will ensure that your home's cooling and heating system is efficient.
Step 6: Install Energy Efficient Appliances
To achieve a green home, you will need to install high energy efficient appliances. These could include tank-less water heaters that do not hold water as they wait to be heated. Besides, using a smaller SD TV for your home will cost you less energy as compared to an HD TV. Consider using laptops, which will use about 85 percent less electricity as compared to the desktop computers. Drying your clothes out in the sun will cost you nothing and is an ideal way of doing it. If you must use a tumbler dryer then, you need to choose one that is rated B to help keep your electricity energy consumption down. In the kitchen, use ovens that are A-rated over the B-rated ones.
Step 7: Use Environmentally Friendly Products
Ensure that whatever you use in your home will not harm your environment either through their use or disposal. This should not just include the material that you use to build your house but also other non-perishable goods you buy for your home. Eco-friendliness should be the criteria that determine the products you buy for your home whether made of granite, concrete, bamboo or recycled glass. For instance, you should consider using products such as clothes made of recycled or organic fabric, rechargeable batteries, reusable water bottles and solar phone chargers. You can also use baking soda and white vinegar in cleaning your home rather than resorting to house cleaners that have environmentally harmful chemical elements. A water-powered clock and a solar lawn mower are the other eco-friendly product you should consider for your home.
A green environment can actually begin with a green home. You have a lot to gain through building yourself one. You will not only make huge savings due to the low consumption of energy, but you also eliminate the chances of spending more on lifestyle diseases such as cancer. Besides, a green home also guarantees that your children and grandchildren will have a safe place to live in.
<p>Good tips</p>
About This Instructable
655views
2favorites
License:
More by LenaW7:10 Mistakes to Avoid When Building a Green Home
Add instructable to:
