3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$10 Removable Wall Art
Step 4Layout & Apply
Layout & Apply
It helps to layout the design on a table or on the floor so you won't get confused. Once the pieces are cut, they can look similar enough to drive you crazy.
Use your design idea sheet to guide you in the placement of each piece or if you want to get specific, measure and mark where the pieces should go.
When applying your design, start at the center or main focal point of the design and work out from there. This keeps everything balanced and straight.
As you place each piece, smooth it out with your hand to make sure there are no air bubbles or pieces that are sticking up.
Every few pieces, stand back and check the design for proper position. Reposition the pieces as needed.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:VeggieBex
