10 Simple Lifehacks With WD-40
22,775
79
7
Published
Introduction: 10 Simple Lifehacks With WD-40
About: Hi there! I started this profile to share my DIY creations and to inspire you to make cool stuff. Here I will publish my DIY creations, videos, tips and tricks, secrets of fixing stuff. http://inspiretomak...
Step 1: Light a Fire in a Rain or Any Wet Contitions
WD-40 is very flammable. you can youse it as a fire starter.
Step 2: Remove Grease or Wax From Any Surface
You can use WD-40 to remove your kids crayon drawings from any surface, it's very easy
Step 3: Get a Pice of Gum Off the Carpet
If you step on a gum on your favourite carpet, no problem. You can separate it from the carpet with some WD-40. Same method works if the gum stuck in your hair.
Step 4: Remove Stains
WD-40 is a good stain remover. If you spill some ketchup on your carpet. No problem. Soak the stain for 5 minutes with wd-40 and the stain will be easy to remove.
Step 5: Cut Through Stuff Easily
lublicate your scissors and they will easily cut trough tough stuff
Step 6: Clean and Waterproof Your Leather Shoes
Step 7: Clean Stainless Steel Apliences
Step 8: Remove Stuck Dirt, Rust or Glue
Clean up your stove from those dry and hard to remove spills.
Step 9: Got a Tight Zipper
Lubricate your metal zippers for a smooth motion
Step 10: Remove Stikers
Step 11: Subscribe to My YouTube Channel =)
Subscribe to my YouTube channel for more cool tips like this!
https://www.youtube.com/inspiretomake
    • Pets Challenge
      Pets Challenge
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    7 Comments
    Really good lifehacks! Thanks a lot :)
    SPELT
    • removes : Rust / Goo / plant sap / paint rub off on cars
    • lubricator alternative for fine machine oils
    •force dirt out of those tight corners crevices
    Some good tips there, be careful spraying them on fabrics like your shoes..... Unless you don't mind smelling like wd-40 everywhere you go.
    nice I would not have thought of the carpet ones working
