3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$10 Tactical weapon light
          This Instructable will cover how to modify an inexpensive flashlight with a pressure switch and mount to a weapon.  You will have to already have a mounting point on the weapon like a weaver or Picatinny rail.  It's cheap enough you can even give your Airsoft or paintball gun a little tactical bling.
Step 1Tools and supplies
Tools and supplies
You will need the following
Flashlight (see note)
Wire
Male spade electrical connector
Heat shrink tubing (1/4 and 1/2 inches)
Double-stick mounting tape (the kind with the foam core)
1 inch Scope rings (make sure they will fit whatever base you will be using)
Tools
Soldering iron & solder
Crimper
Knife or razor
Hole Punch (not pictured)
Note: I'm using a Miraclebeam 9 LED flashlight.  It's about $3 at Fry's Electronics or Harbor Freight.  It's cheap, bright and perfect for this specific modification.  If you want to use another flashlight just make sure it's 1 inch in diameter, but you're on your own as far as modifying the switch.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:uglymike
