Making a Vacuum Bag Connector (Vacuum Port) for $10 With Hardware Store Parts
Introduction: Making a Vacuum Bag Connector (Vacuum Port) for $10 With Hardware Store Parts
In this instructable I'll show you how to make a vacuum bag stem (also called a vacuum breach valve/unit). These are important in vacuum bagging because taping the hose on the seam of the bag is a recipe for leaks and disaster.
This adds on to the excellent guide on vacuum bagging basics
It also goes well with the bicycle-turned-vacuum pump guide if you want to do some hand powered vacuum bagging, or the great tire-inflator-turned-vacuum-pump guide.
Step 1: Gather Your Parts
You'll need:
4 3/8" steel washers
2 3/8" ID, 7/8" OD neoprene washers
1 1/8" F nut (dunno what they're called)
1 1/8" M to M threaded tube connector (the shorter the better)
1 1/8" F NPT to hose connector
Vacuum bagging plastic sheet/film
Step 2: Assemble Everything
You're going to need to assemble the parts in the following order:
Rubber tube connector, M M threaded connector, 3 steel washers, 1 neoprene washer, plastic to be vacuum bagged, 1 neoprene washer, 1 steel washer, nut.
Note: When you put the vacuum bagging material on you will need to punch a hole in the bag to get the tube through. Make sure this hole is smaller than the tube, and stretch it around the tube to help prevent leaks.
Step 3: Done! Enjoy Your Breach Valve
There it is!
On a side note: The neoprene washers should be a tight fit around the tube. This is good because if it doesn't happen, you'll have air leaking around the rubber and killing your vacuum.
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    This isn't very good solution. You need to solder the first washer(s) to the brass hose connector, then you are able to block the air leaking when there isnt any route to pass the gasget(s). This way you need only one gasget.
    I just ordered a valve on amazon with a hand pump. It is usually used to keep whine fresh, but i got 4 "valves" and a small pump for around 10$. They are nearly identical to the ones used by Roarockit.
    solder (or weld) the washers together to make handling it all easier
    great instructable, purpose driven, simple enough for anyone to do.
    If I may ask, would this not be a port instead of a valve? And am I to assume that this is for a short term project use - such as vacuum forming, or impregnating a fluid in a material such as with carbon fiber?
    Would it be possible to create a valve by cutting an extra piece of rubber that opens during the draw out, but closes against the other washer to generate a seal; such as one would find in a blacksmith's bellow's?
    You're absolutely right, it is a port instead of a valve. It should be called a vacuum connector or a vacuum port instead.
    And you're right! It is for short-term project use like vacuum forming or vacuum bagging carbon fiber or fiberglass.
    I haven't given the rubber seal much thought. The trick is that the flap would need to be on the outside, not the inside to let air go the right way.
    how air isn't sucked in through the valve ?
    Does it has a flap inside or something ?
    The hose connector is hollow, no ?…
    Don't get the idea at all !…
    You're right, it doesn't have any sort of one-way valve on it. The trick would be to leave the hose on for the duration of time that you need a vacuum.
    Ah ! OK !…
    Thans for posting.
    What if you place another washer outside and clamp the plastic in middle of them? it should stop any leak...
    //////////// <---- neoprene washer
    ----------------- <- plastic
    It should help for a better tighting...
    Hmm that is a good idea, and what I think I'm doing, if I read your comment correctly. The plastic is held on both sides by neoprene washers, and outside of both of those are two steel washers which distribute the tightening pressure from the three brass fittings.
