loading
loading
Picture of Pocket 10 watt amplifier
OK , Hi all ..
This my First Project in Instructables ^_^
I am from Indonesia , Here was held 26th SEA Games 2011... GO Indonesia !!!
Ok check this out ,
This is 10 watt amplifier and LoudSpeaker,
Let me tell you how I make this thing
Part List :
# acrylic
# Loudspeaker
# PCB
# Some Wire
# 9Volt battery Connection
# Unbalance Jack Female
# Power Jack Female
# Potensiometer
# Capacitor ( 2.2uF ; 470uF ; 100uF ; 0.1uF ; 1000uF )
# Resistor ( 220R ; 2.2R ; 1R )
# IC Tda2003
# Heatsink
Step 1: Build Loudspeaker Box
Picture of Build Loudspeaker Box
Tools I use :
# Saw
# Drill machine
# Melting Glue
I think the result is not bad ,
Ok its bad but not really , LOL
Step 2: Core Part - Tda2003
Picture of Core Part - Tda2003
The TDA2003 is a cheap amplifier that is designed to run on single rail power supplies. It has many applications (including in car systems if you do not need to show off down the high street with your subwoofers!) and is protected against short circuits in almost every way you would think them possible.
1-40 of 85Next »
Hapis20 days ago
can i use a 4 ohm speaker?
Rfmhz2 months ago
Hmm not bad it worked (high five to you sir .
Soldat710 months ago
Very nice instructable. i only have 1 point of improvement. namely the Cx.
Cx's role is that of a high-pass filter. High-frequency goes trough it to the inverted input of the amp resulting in Treble-Treble=nothing kind of effect (upper frequency limit). 33nf is ok for high-frequency AC testing, but with audio the filter is far too small letting even noise trough and giving the high pitched sounds a almost shriekish sharp end as you become unable to hear it. instead you would want to limit the frequency to be near hearing so it rolls off the treble giving a far greater sounding sound (and little to no noise!)
I myself have settled to using a tiny 4.7uf cap (Positive towards the amp output). It cuts of the frequency just below hearing limit and removes almost all noise i had before. it upgraded my amp from sounding nice to sounding like a classic HiFi speaker.
I big thing i always keep reminding people of is to experiment with these kind of circuits. try different cap vallues and such. oh and if able use metal-film resistors. they do a far greater work then then the generic brown resistors and aren't costly at all.
twyeth10 months ago
making circuit on proto board. um where does the pot go in the circuit, not noted in diagram
Soldat7 twyeth10 months ago
Ah the potmeter is the Volume control. idea is that 1 connection is to the audio source. the other to ground and the wiper (middle) to the Input of the diagram.
Oh if feeling adventurous play around with the vallue of Cx once you got it working. You can alter the audio quality quite effectively trough it as the one used by most isnt exactly the best. i prefer replacing it with a 10uf cap.
Hope this helps.
3dw4rd11 months ago
gan sorry itu diskema nya letak potentio meter nya gk ada potentio meternya ditaruh di output atau input thank gan cuma itu aja bagus karyanya
Ghild.Zero (author)  3dw4rd11 months ago
hi bro, for the potensio you can add it at the input of the IC..
3dw4rd Ghild.Zero11 months ago
thank bro and good and nice job
erikassxx1 year ago
Can i use tda2030?
Ghild.Zero (author)  erikassxx11 months ago
each ICs have different how to use them, to make sure it, you must see the datasheet and make some experiments
iMOD1 year ago
Nice design
DMRPUKU1 year ago
wt abt output den?
Ghild.Zero (author)  DMRPUKU1 year ago
Ooopsss , I am sorry, man ....
j9 is for output (loudspeaker)
j6 is for power input , it has 2 ways : 9v batery (using 9v connector) and adaptor ( using Female jack connector) . They are paralel .
DMRPUKU1 year ago
wats j7,j6 n j9??
j7 for input audio
j6 for input batery 9 volt
j9 for input 9 - 18 volt
Here is it , hope can help you :
The Layout :
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn2/8655_586240588064840_562823952_n.jpg
The Schematic :
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-frc3/501_586240574731508_970148564_n.jpg
The 3D :
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash3/q71/s720x720/1011909_589421264413439_499067393_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-ash4/q71/998252_589421254413440_570515331_n.jpg
yup got it!
DMRPUKU1 year ago
thnx man
DMRPUKU1 year ago
i need the values for evry symbols pls ???
DMRPUKU1 year ago
hey.wat does dose j1 j2 j3 j4 c1 c2 nd ol stand for..........???? help pls...am in really need of dis
j1 j2 j3 j4 j5 is pin of IC tda2003
C mean Capacitor , the value of c1 is 100nF(no polarity) and the value of c2 is 1000uF
DMRPUKU1 year ago
value of potentio meter ????????????
10k
DMRPUKU1 year ago
stil confusin!
nyways how much value does the pot hav?
for the value each component you can look at the schematic picture
DMRPUKU1 year ago
man.........i jst created a new account for myself bcuz of ur dis project......i really need help...can i c snaps of d pcb with ol d solderings nd connections..close up...am a 16 year old boy frm india...i need an understandable schematic circuit diagram? can u? help me pls?
faziefazie1 year ago
beli akrilik yg kaya gitu dimana ya?
Ghild.Zero (author)  faziefazie1 year ago
Acrilicnya saya potong sendiri gan trus nge-lem sendiri juga , hehe...
xwilkening2 years ago
ok, so you said a 12 volt would make this sound better. it sounds interesting but I would need some help, for the power, do you think I could just use a DC wall wart? or would it have to be AC? (sorry if this is confusing, im kind of new to electronics, i've only been working with them for about a year now) and this project seems like a great idea since I love working with speakers and I always get lots of request to build some for people! (i've gotten a request for a mini ipod speaker for $20!)
NatDaGamer2 years ago
Can you please tag which capacitor and resistor are which?? I really want to make this however I can't work out where each resistor and capactior go, and how many of each I need. Good instructable otherwise :)
Ghild.Zero (author)  NatDaGamer2 years ago
Terima kasih NatDaGamer ^_^
Please check this
What resistance potentiometer should i put? 10Kohm or 40Kohm?
Also i seem to have a problem with huge distortions on low volumes. Could it be because of the potentiometer being 10kohm?
Nvm solved it. For anyone wondering i had 2 4ohm speakers wired in paralel. I fixed the distortions by connecting them in series.
klija3 years ago
layout is on What?programma
klija3 years ago
layaut is on what programm
usbg3rd3 years ago
Also that what are Cx and Rx for in the datasheet ? there is no description of the circuit do you have any link ?
usbg3rd3 years ago
nice instructable and easy to build too but i have few questions
can someone help me i built it but the output was distorted not too much but it was enough to annoy some one (when the output is at max volume) at lower volume its fine enough.
CONVERSELY
and when i short the capacitor C2(1000uF) the output gets stable and distortion is reduced (at max volume) but gets distorted at lower volume .
strange but true
anyone who has built it can try himself and what is the solution for low distortion at max and min volume simultaneously.
asmith4333 years ago
can you modify it to run on 12 volts or does it need 18 volts because i would like to use it on a robot that only uses 12 volts also what is the maximum wattage it can run
Ghild.Zero (author)  asmith4333 years ago
12volt supllay is fine ^_^
what is the largest speaker you can run (:
1-40 of 85Next »
