10 Year Led Flasher (Version 2 With Boost Converter)
2,087
32
13
Posted
Introduction: 10 Year Led Flasher (Version 2 With Boost Converter)
This LED flasher will blink for 10 years on a single 1.5v AA cell. My previous circuit used a blocking oscillator to generate the Vdd voltage for IC1. This circuit relies on a BOOST CONVERTER configuration (inductor-diode-capacitor) . Output voltage is high enough to drive at least 5 leds series-connected.
Step 1: 10 Year LED Flasher (V.2) at Work
Step 2: Circuit Diagram
Step 3: Astable (flash Rate)
Step 4: Monostable (pulse Width)
Step 5: Transformer
Step 6: Boost Converter
Step 7: T1 Secondary
Step 8: Start-up
Step 9: Managing Energy
Step 10: Current Drain
Step 11: For More Details and Waveforms, Watch Video
Step 12:
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
  • Microcontroller Contest
11 Comments
Hi!
How to green led high bright more than??? what i should change value resistor?
my circuit is done but led no flash, when i connect jumper then led flash one and end? please help me
post an image of your circuit. See if I can help.
Hi, transformer 12V to (black) connect to???
one of the blacks to battery (+) the other to transistor Collector + diode anode +jumper. The yellow (center tap) is not used.
Please fix, thanks :D
IMG_0359.JPGIMG_0360.JPGIMG_0361.JPGIMG_0362.JPGIMG_0363.JPGIMG_0364.JPGIMG_0365.JPGIMG_0367.JPGIMG_0368.JPG
in video, i see you use 4 capacitors, in circuit diagram: 3 capacitors???
the 4th cap is for decoupling but is not mandatory. (not necessary)
Hi! Can i change transistor BC337 by 2N4401? I don't understand the transformer work by method and create transformer???
Sorry i noob english.
