Introduction: 100 000 Volt Flyback Setup
Picture of 100 000 Volt Flyback Setup
so i am one of those people who want's high voltage but don't have the buck's to buy one of those expensive neon sign transformers so i stumbled on to one of this guy's idea on how to build a simple flyback driver with a cfl ligt i hope he will forgive me for kind of steeling this idea but with his idea i have upgraded it to be a lot more powerful tanx
Step 1:
Picture of
what you will need is a flyback transformer a cfl ligt and thats it
Step 2:
Picture of
that's what  we want but be careful when you remove it it might have a bit of a charge that will kick you
Step 3:
Picture of
now you must find a cfl light the bigger the better but a small one will also work but poor results
Step 4:
Picture of
you will also need 2 florecent tubes any type will do
Step 5:
Picture of
ones you have the electric ballast you will see there are 4 wires connected to the tube you can remove theme so that you only have the ballest
Step 6:
Picture of
connect these 2 to one tube and the other to the other tube. then the 2 pins at the end of the tub becomes one
Step 7:
Picture of
so now that you have 2 wires they must enter the flyback i will show you what pins is in and what's out. the only reason why i use these tubes is because they prevent spikes
Step 8:
Picture of
those are the 3 input pins the output pin is easy to find just swoop over the other pins with the thick red wire it will arg. so now you will ask how the fu`k can that be 100 000volts you must now put a nother  flyback on the output of the first with a spark gap good luck
RedstoneM (author)2015-09-13
It looks like 20kv in the first image (1kv = 1mm in air)
Jan_Henrik (author)2014-05-05
Sparkssss :3
SpectrHz (author)2014-02-03
I think this instructable needs a little work. First off I don't think your system Is producing 100,000 volts. Even with zvs drivers the most I have (reliably) seen is 50,000 volts, and some credit in the format of a link to the author or instructable would be recommended. Also, if you could be more concise and cut out some of the swearing? (last page)
Magnetron (author)SpectrHz2014-02-03
This is hard for me as I don't have my own computer and it was my first instructble. Yes that's not 100 000 volts I know, only hade one flyback if you do this with 3 flyback's it wil be over 100 000v (pleazzz) try to understand that I only had 1 hour to do this tanx)
Eisad (author)2014-02-03
now100 000volt there are not ther are like 30 000 volt from the arc length
Magnetron (author)Eisad2014-02-03
Yes that's true but I only have one flyback on and I don't have any way of testing that kind of volage
francisdsa (author)2014-02-03
is this an instructable? no circuit diagrams nor link to credit the initial authors idea? where are pinout markings??
Magnetron (author)francisdsa2014-02-03
Dude chill it's my first instructable and I don't have my own computar (but tanx)
About This Instructable
2,758views
21favorites
License:
Bio: Oooo man I hat people who judge's before they know anything
More by Magnetron:100 000 volt flyback setup
Add instructable to:
