$100 Hardware Store Sailboat
29,411
439
22
Posted
Introduction: $100 Hardware Store Sailboat
Best weekend project ever!
Build a sailboat for $100 with easy-to-find parts!
http://threefeetofair.wordpress.com
Step 1: Grab Your Notepad and Take Notes, This Video Instructable Is Information-dense!
Here's the list of things to buy/find/scavenge (parentheses is where I got the item)
  1. One Inflatable twin size air mattress (Target)
  2. One 10' x 12' polyethylene tarp (Target)
  3. One 8 foot long 2x4 (Home Depot)
  4. One 2'x4' plywood Project Panel (Home Depot)
  5. Four Schedule 80 gray PVC conduit pipes, 1-1/4" diameter, 10 feet long (Home Depot)
  6. 100' poly rope, 1/4" or 3/8"
  7. Marine-grade #8 phillips head screws, such as stainless steel, 12@ 2-1/2"and 4@ 1-1/4" (Home Depot)
  8. Outdoor paint, acrylic or synthetic enamel, from the customer reject color shelf (Kelly Moore)
  9. Craft thread or Dual-purpose thread (JoAnns)
It's a bit of a challenge to get all these materials together if you buy them all at full price. But if you have paint leftover, or can find the air mattress or the tarp on sale, your sailboat will cost under $100. Sweet!
The tools you'll need:
  1. Drill with a 1/2" bit and a phillips head driver bit
  2. Hole Saw
  3. Circle saw (And perhaps a chisel or a keyhole saw)
  4. Scissors
  5. Sewing Machine
  6. Needle
  7. Lighter
  8. Sanding block and sandpaper
  9. Paintbrush
Step 2: Corrections and Clarifications to the Video, and Upgrades
The keel has a notch 1-1/2" tall and 6" wide if you are going to screw it directly to the 2x4. If you are going to make the keel removable for easier transport, then make the notch taller at 3" so you have room to screw in the keel stays.
Since circumference = Pi times diameter, make sure your pole pockets for the battens, gaffe and boom are sufficiently large to accommodate the pvc. If your pockets are 8" around they will be more than adequate. For the battens, simply sew rectangles of tarp material to the air mattress' tarp sack. I cut strips 6" x 26", hemmed the ends to make pieces 6"x24" and then sewed those rectangles to the sack. I folded the edges under and held everything in place with small bits of masking tape. The battens are equally spaced, about 16" apart.
Make your sailboat feel a bit more stable by adding wings. You'll rest your feet on these tiny trampolines and gain a little better control of your boat. Make two of the battens 4 feet long instead of 2 feet long, and instead of sewing simple pole pockets, make a big sleeve 16" wide and 45" long. Replace the two small sleeves at the rear with this one big sleeve. Loop rope through each batten and create a tension structure by tying the rope through a hole in the 2x4 and cinching it up really tight.
Most cars can fit an 8' length but 10' is more challenging. If you plan on taking the sailboat car camping, consider cutting the gaffe from 10' into a 2' section and an 8' section. Spray the end with silicone so you'll be able to take it apart again. Some lubricants will eat the pvc. I haven't made a big sail for this little boat yet, but by splitting the gaffe into two parts, you could make a sail with a 16' gaffe that would probably work well.
Use a real paddle as a rudder.
Add metal pulleys, cleats and use an oar-lock for the rudder
Use a better grade of tarp.
Use Dacron fabric instead of tarp. Get Dacron here: http://gaboats.com/
Step 3: Safety and Liability
Boating can be dangerous. Be smart. Wear a PFD, and make sure someone knows what you are doing.i
Printed directly on the air mattress is a warning that it is NOT a floatation device. You are making a choice to intentionally misuse this product when you use it as the bladder for your sailboat. If you get into trouble with a sailboat made from these instructions, it is unlikely that you or your heirs will be able to recover any sort of settlement against me, the air mattress manufacturer, or Instructables. You assume for yourself all responsibility for your choices, whether you can foresee the consequences or not. Furthermore, I specifically assign to you the responsibility for communicating to your heirs that you entered into the building of this sailboat freely and that you accept any and all consequences that could arise from your participation.
Step 4: Further Exploration
Is there a way to make an air mattress windsurfer?
If the gaffe, mast, and other long parts were collapsible and lighter, is there a way to make a sailboat that is back-packable?
Step 5: Check Out Some of Our Other Projects
  • Sew Warm Contest 2018
  • Gluten Free Challenge
22 Comments
Excellent work on this instructable.
Thank you! Three years on, I recall the making of the video with greater fondness than the making of the boat.
Haha, that's my buddy Moses, but I bet he could help me out.
Haha thanks Captain. This is really an amazing project.
Thanks, Noah! If I challenged you to a race, would you part the sea ahead of me and force me onto dry ground?Or would you let me beat you fair and square?
Haha Cap'n, when I said tack, it's method of sailing at a 45 degree angle into the wind, then switching sides so your sailing zig-zag through the water but into the wind. If you haven't had problems with capsizing, then consider my idea as a later project for something more stable.
Ah! This boat heads into the wind reeeeaaally well (what with having the keel in front and all). Here's what happens when you tack using this boat: it spins around and you go backwards until the sail fills. In any case, it sails into the wind quite well.
I think a future project will be a multiple float experiment, with a much larger sail! :)
When I say "too light" I mean it might not weigh enough to oppose the force of the wind, which could tilt you in to the drink. If you get leaning, the extra support of the plastic jugs prevents you from possibly losing your ship by capsizing.
The second upgrade I made to the sailboat was the wings (noted in the drawings in "Upgrades"). Being able to put my feet out on a wing really improved my ability to control the boat's roll.
I've gone fast enough to leave a pretty good wake and feel the water rushing under the boat (perhaps 5 or 6 knots) and I didn't feel like I was about to capsize. But I did get plenty wet.
