3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
100% Homemade Lathe
Step 15Tailstock Finishing
Tailstock Finishing
It is a good idea to use the finished headstock to help finish the tailstock. I removed the chuck, so the end of the shaft was now exposed again. On the tailstock, I mounted two pieces of UHMW vertically. Two pieces because they should keep whatever tailstock accessory aligned better than just one piece.
I tightened the tailstock down so it was just barely movable, but not wiggly. By pushing the tailstock against the headstock while the empty shaft is spinning, I made an imprint of exactly where the hole should be drilled so it lines up with the headstock shaft. Then I used the drill press to drill the hole precisely, but accidently drilled the holes 5/8" instead of 1/2" so I fitted some bronze bushings into the holes to reduce the diameter. Double check that the main lathe shaft is correctly lined up with the new holes, and then reattach the chuck to the shaft.
The picture shows the completed tailstock.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:catwood
I believe that a person can do just about anything within reason as long as they try hard enough.
