100% Homemade Lathe by catwood
Featured
Step 17: First Tests
For the first pieces, I decided to try making tops. I started with a piece of pine 2"x2" about 5 inches long. I tightened it in very tight (the screws on the chuck need to dig into the wood to hold it well), and supported it by the center. After roughing out the circular shape from the square wood, I removed the center and shaped that end into a point. Then I shaped the shaft and lightly sanded before cutting it off from the chunk still in the chuck.
After a few tops, I tried to make a chess king, but after the crown broke off, it became a queen. I made this in a similar way; supporting both ends of the piece until the rough shaping was completed, then sanding.
The first picture shows the wood blank ready to go. The second picture shows the queen being carved. The third picture shows the remains after the queen is done. The last picture is 3 of the 4 tops and the chess queen (my dog ate one of the tops).
0087adam says: Aug 1, 2010. 11:59 PM
what did you use as a tool rest?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
