3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
100 Ways to Reduce Your Impact
Step 2Up 2 degress in summer, 2 down in winter
Heating and cooling is responsible for a large percentage of a household's energy consumption.
Turn up your thermometer in warm weather. An average thermostat temperature for warmer weather is at around 78 degrees Fahrenheit. If you are not at home most of the day, you can turn the temperature up to reduce the cooling that your house makes during the day.
The opposite goes for cooler weather. 68 degrees Fahrenheit is about average where you should have your temperature. Each degree below the 68 mark reduces 3% - 5% more heating energy consumption. Just wear an extra sweater if you feel a little bit colder than usual.
Don't worry, my mother does not turn on the heat until half way through the winter. And even then, the temperature is still low. The temperature in my house is currently 63 degrees. I got used to it, and I feel great!
4 comments
Mar 2, 2012. 8:01 PMnDR01d says:
For everyone else who are not living in Burma, Liberia or the USA, 78F is about 25C and 68F is 20C.
Aug 1, 2011. 6:12 AMtinkerist says:
our policy is that my wife controls the thermostat in the summer (and i walk around wearing little to nothing). i get to control it in the winter (while she's wearing 2 of everything, plus a robe). saves quite a bit!
Mar 28, 2009. 3:56 AMmstark77 says:
Will fans draw as much energy as an AC? If not, try leaving the AC off.
May 5, 2009. 8:37 PMFooGlacticon says:
My big box fan from Wal-Mart draws 80, 100, or 120 watts on low/medium/high. So definitely.
Buy a $6 lamp timer and switch the fan on at night. Put it in the window blowing *out* and it will pull air through the entire house. Close the windows in the day, and it'll stay anywhere from 10-15 degrees cooler than outside.
Apr 11, 2009. 8:13 AMbelcat says:
Fans definately draw less energy than the A/C. A fan may draw 50 watts, the commercial extra-strong ones draw around 240 watts. A house A/C unit is usually wired to a 4800 watt breaker (doesn't actually consume that much, but it is close to it), and the smallest (6,000 BTU) plug-in A/C unit usually 6 amps (720 watts). Some furnaces state the temperature should not be dropped below 16 C (60.8 F), but I doubt that is really a problem.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
129
Author:Brennn10
Brennn10 is now at college studying Electrical Engineering. He is also currently researching nanotechnology applications for solar cells.
