100-Yard Paper Rocket Launcher
 by WYE_Lance
Contest WinnerFeatured
PVC paper rocket launcher designs are a dime-a-dozen. So why another one? Because I've tried many other designs found on Google and YouTube, and none of them are 1. fairly easy to build 2. perform spectacularly and 3. easy for kids to operate. I have finally come up with a design that fulfills all the criteria for an amazing rocket launcher after conducting the paper rocket project with my engineering class countless times.
This Instructable also outlines how to make a high-performing rocket, which is just as important as having a great launcher. The students in my engineering class have made rockets that can fly over 100 yards from this launcher - it's rather mind-blowing to witness.
The video doesn't quite capture the sheer distance that these rockets can reach, but I think you'll get the jist of it.
Step 1: Make the launcher
I work with elementary-school aged children, so making the launcher is something I do as part of my prep. Older kids (with a generous budget) can try to design their own launcher. View the last step for a complete list of materials.
This launcher works up to 60psi. You can wire in a second 9V battery to get the launcher up to 100+psi. 60psi is enough to achieve spectacular results. Pressures above 60psi dramatically increase the risk of exploding the rocket, and in my experience, most student-built rockets cannot withstand the speeds produced by 70+psi.
(and by the way, you might want to protect your work surface a bit better than I did)
Step 2: Make the rocket
All you need is cardstock, tape and scissors.
It's easy to build a rocket that can reach a distance of 50 feet. However, making an ultra-high-performing rocket is actually quite challenging because all aspects need to be designed to near perfection. At high speeds, tiny imperfections are quickly blown out of proportion because the forces acting upon the rocket are intensified. For example, a nosecone that leans slightly to one side may not significantly influence the rocket's performance at 40psi, however at 60psi that nosecone may create an imbalance of friction created by the air rushing by, causing the rocket to turn sharply and tumble to the ground.
For this reason, take your time while creating & attaching each part of the rocket. And with that in mind, here's how to make a high-performing rocket:
Step 3: The lesson (for teachers)
Learning Objective
  • Fundamental concepts in aerodynamics such as stability, drag, and propulsion are experientially explored and applied as students build and test their rockets. The comprehension of these concepts is further strengthened as students redesign and retest their rockets while observing the differences in performance.
  • Students will acknowledge the value of teamwork as they work in pairs to design and build their rocket. Students who choose to work individually will quickly observe the value of teamwork during certain steps.
  • Basic rocket anatomy vocabulary (fuselage, fins, and nosecone) will be understood and utilized during the teacher's lecture and during rocket construction.
  • Fine motor skills are developed during rocket construction.
  • Optional: students will experientially comprehend the values of different materials as they apply their material choices to their rocket design, as well as by observing the performance of different material combinations.
Lesson Plan
I usually start by explaining how the launcher works because it catches the students' attention right away. I just explain the basics: the chamber is filled with air, creating high air pressure, and when the button is pressed, the air is allowed to escape through the launch tube, which provides propulsion to the rockets. For a more technical understanding, view the video at the bottom of this page (credit to the YouTube user Hubb017).
Next I show the class how to build a rocket from start to finish. I usually work a little fast and imprecisely since I'm just outlining the steps, so be sure to encourage them to take their time and build with precision. As I build the rocket I explain the important aspects of each part:
  1. The fuselage must fit the 1/2" PVC perfectly. If it is too tight, it will not fit, or it will explode upon launch. If it's too loose, propulsion (pressurized air) will escape out from the bottom of the rocket. The fuselage should slide onto the launch tube with little wiggle room.
  2. The fins provide stability for the rocket - this is enough explanation for younger students. Older students may benefit from knowing this: when a rocket is pushed off course by a gust of wind, the angle of attack (direction the air is moving) relative to the fins changes, which causes the fins to generate a small amount of lift. The lift immediately forces the rocket to return to it's original trajectory, which also restores the angle of attack to 0, thus stabilizing the rocket. If the fins are too large or not straight, it may generate too much lift and cause the rocket to turn during flight. If a rocket begins to turn because of the fins, the center of pressure (the point at which all forces are acting upon the rocket, including momentum and lift) surpasses the center of gravity, meaning the rocket will try to turn around, causing it to tumble out of control. Basically, make your fins precisely and tape them on straight!
  3. The nosecone reduces drag (air pushing against all sides of the rocket) by offering minimum aerodynamic resistance. In other words, the nosecone helps the rocket 'push' its way through the air without allowing the air to push back against the tip of the rocket, instead flowing smoothly around it. Demonstrate how to build the nosecone a few times since it can be challenging. The nosecone can be difficult for young students to build, so an alternative (though less effective) design is to simply pinch the end of the rocket and close it with tape. Be sure to tell the students to secure their nosecone extremely well because the air pressure can blow the cone off of the rocket.
  4. Inspect each part of the rocket for straightness and secure placement.
I also encourage the students to work in pairs for this project for two reasons. 1. It is simply easier to construct a rocket if one person holds the parts in position while the other secures it with tape, and 2. Flaws in the rocket design are more easily identified and resolved when two people are examining the design and expressing their thoughts and ideas.
Remember, the objective is to allow students to explore and comprehend aerospace ideas experientially, so allow them to experiment with different rocket lengths, nosecone and fin shapes, number of fins, etc. It's ok if students cannot give you a textbook definition of ideas like drag and trajectory at the end of class. As long as they are engaged with the activity, they will learn these things effortlessly.
Alternative ideas
You can offer a myriad of materials for the students to explore and build with, which adds a new dimension to the project. Experimenting with different materials can add longevity to the lesson.
Video of how a sprinkler valve works
Step 4: Safety, tips, and troubleshooting
Follow these safety precautions regardless of whether the chamber is pressurized or loaded with a rocket.
  • Never allow students to use the launcher unsupervised. Disable the launcher by removing the battery (or pump or launch tube) if you have to leave the launcher unsupervised.
  • Never allow anyone to put their face near the launch tube. Air expelled from the tube, if forced into someone's nose or mouth, is powerful enough to cause the lungs to rupture. This is very serious. Tell your students about this and they will be frightened enough to never get near the tip of the launch tube.
  • Never stand directly in front of the launcher, even if a rocket is not loaded. At point blank, a rocket shot from the launcher can cause serious injury.
  • The student holding the button should keep his/her trigger finger off of the button until the final countdown is initiated. The button is sensitive and can easily misfire.
  • Use a bright rope to define a safety zone that the students may never cross, even while loading their rocket.
  • Have a countdown before each launch as a way to alert people in the area (and to make each launch more exciting!)
Common design flaws
  • Fins that are not attached straight, or the leading tip of the fin is not secured, will cause the rocket to tumble at high speeds.
  • Fins that are too big create too much lift and/or drag.
  • Fins that are too small may not provide enough stability.
  • Fins that extend too far from the fuselage are prone to wobbling in the wind, causing instability.
  • Nosecones that are not secured well enough will explode off of the rocket.
Tips and troubleshooting
  • Rockets tend to explode at pressures above 60psi. If you choose to mod the button with a second 9V battery, have the students tape up every seam many times over.
  • Inspect the rocket before each flight and use your hands to straighten out the fins and nosecone, which will inevitably become bent over time.
  • I usually refrain from interfering with students' designs, however if a student has created a poorly built fuselage I will step in and help them. Making a new fuselage after attaching everything else can be a hassle.
  • Young students (grades 3 and below) may have a hard time rolling a tube of cardstock, so I usually do that step as part of my prep.
  • If you don't have access to a huge open space, you can set up targets like stacked cardboard boxes and aim for those. Be extra cautious here.
  • When storing the launcher, remove the 9V battery, or at least make sure the button is uncompressed or else the battery will quickly drain.
Step 5: Materials list
Here's the complete list of materials and tools for the launcher and paper rockets:
Tools for the air pressure chamber:
Sandpaper
PVC cutting tool
Drill
Mallet
Pipe wrench
Latex gloves
Materials for the air pressure chamber:
PVC Primer
PVC Solvent weld (aka PVC cement)
KwikPlastic (or similar)
Tire valve
6" sections of 2-inch PVC  (x2)
2" slip fit end cap (x2)
2" slip fit T-joint
2" to 1" slip fit reducer
2" section of one-inch PVC
1" threaded male adapter (x2)
1" to 1/2" slip fit reducer
24" piece of 1/2-inch PVC with tapered end (x1)
Modified valve and replacement launch handle from ItsaBlast.com
Bicycle pump with PSI gauge
For the base:
12" cable ties
PVC elbow joints (x2)
12" piece of PVC with two holes drilled about 4" apart (x2)
8" piece of PVC
The total cost is about $70, excluding all tools and solvent weld. In my line of work, it is well worth the initial investment because the paper rocket activity is very cheap, less than $0.15 per student.
For paper rockets:
Cardstock
Masking tape
Scissors
1-40 of 48Next »
legoman111 says: Apr 4, 2013. 4:29 PM
Cool! Exploding rocket!
bhavesh1440 says: Feb 13, 2013. 7:55 AM
what is the difference between modified valve and air actuated valve? and which we use in doing this paper rocket lancher?
Fast React says: Dec 25, 2012. 4:38 PM
If i use a bigger persure chamber and more presure whould i go farther ?
WYE_Lance (author) in reply to Fast ReactDec 26, 2012. 10:22 AM
I don't think so. A bigger chamber just takes more time to fill up to the max PSI.
Fast React in reply to WYE_LanceDec 26, 2012. 2:02 PM
Tanks for the answer.so il just use the regular chamber
Thekellygang says: Oct 29, 2012. 7:50 PM
I would really like to make this rocket, but cannot find a solenoid. I searched the itsablast website and could not find one anywhere. i also searched ebay and the internet in general, but only found motorbike starters. Please help.
WYE_Lance (author) in reply to ThekellygangOct 29, 2012. 7:55 PM
Hi there,
The solenoid is included when you purchase the modified valve. The valve that I used in this design can be bought here.
Have fun!
Thekellygang in reply to WYE_LanceOct 31, 2012. 8:56 PM
Thanks!
tbrockert says: Jun 13, 2012. 6:44 PM
This is a wonderful project that worked just perfectly! The kids were very impressed by how far the double launcher worked.
I have some troubleshooting I was hoping I can get help with. After leaving the launcher alone for about a month, I tried it out again with some difficulties. Beyond the pressure of 30-40 psi the trigger won't work properly and won't expel the air from the barrel. Only after loosening the trigger from the chamber, will the air escape through the pvc. I don't know if this has occurred before in any of your models, but if so or not, do you have any tips?
WYE_Lance (author) in reply to tbrockertJun 13, 2012. 7:11 PM
Great to hear that! If the trigger won't work as well as before, try replacing the battery. If the battery is low then it won't have the power to activate the solenoid and release the valve.
tbrockert in reply to WYE_LanceJun 14, 2012. 12:03 PM
That was it! The 9v had only 75% of the max charge, which I guess wasn't enough to pull the trigger fully under high pressure. Much thanks! Now I can use this even more!
ryanmudry says: Apr 21, 2012. 2:22 PM
How is the "modified sprinkler valve" different from a home depot sprinkler valve?
WYE_Lance (author) in reply to ryanmudryApr 21, 2012. 3:51 PM
I don't know exactly how to mod a valve, but I do know that the valve is modded to allow the air to escape more rapidly.
minecraftplayer123 says: Apr 7, 2012. 9:33 AM
hm you need this device to shoot the rocket darn!
SoakedinVancouver says: Mar 13, 2012. 12:21 AM
You should try a whistle in the cone...
maintann says: Feb 26, 2012. 1:40 PM
A serious suggestion - put a safety switch in the circuit - perhaps a toggle switch with a flip up cover. This way firing requires three actions ,flip cover, toggle circuit on , press fire button. It's never too early to impress safety on kids
Don
WYE_Lance (author) in reply to maintannFeb 26, 2012. 2:35 PM
That's a great idea! It would be pretty easy to splice in a second switch, perhaps something that only the teacher can control. I like that it allows students to be in control of the launch without the risk of a misfire. Although my safety talk has so far been effective, it is indeed better to be safer than not.
MrPTrog in reply to WYE_LanceMar 11, 2012. 10:59 AM
I like the idea of a second switch in series with the firing switch.
On the idea of teaching safety and responsibility; assign one student as a safety officer for each team. The safety officer would make sure all students are clear behind the safety line before calling range clear and pressing their button to enable the firing button. (does my military background show with this suggestion?)
tbone1906 says: Feb 29, 2012. 8:07 PM
You should also think about wrapping the PVC with several layers of duct tape. Overtime the PVC may weaken and the high pressure could rupture the pipe sending possible shrapnel into the crowd. The duct tape would contain any flying debris in the event of a failure. Or you can use metal pipe for the pressure vessel. With kids its always a good idea to be extra safe. Keep up the good work, I love it when kids get excited about science!
rocklocker says: Feb 28, 2012. 7:23 AM
I have to agree with THAYRAY. Some of those kids were too close to the launcher. Perhaps a line which every one must be behind before launching. It's no fun going through life with one functioning eye, I know.
On the other hand this is really cool and is going into my grandpa projects to amaze the grandkids as soon as my kids make one for us. Maybe they need an instructable on how to make bqabies.
WYE_Lance (author) in reply to rocklockerFeb 28, 2012. 11:32 AM
Thanks for the kind words and your concern for the kids. I'll admit that it is difficult to keep kids at a safe distance - everyone wants a good view of the launcher. I constantly remind kids to back up, but your comment gave me an idea for a better solution: I think it would be easy to use a brightly colored rope to create a safety zone around the launcher. I am conducting this project at many schools this week, so I'll try this out today and let you know how it goes.
WYE_Lance (author) in reply to WYE_LanceFeb 28, 2012. 5:12 PM
I bought some thick and bright yellow rope to define a clear safety zone - it worked very well! Kids were even reminding each other to "Stay behind the rope." I've updated this Instructable with a photo of the rope being used in step 4. Very simple, easy-to-implement solution until I install a second safety switch.
Little Mom on the Prairie says: Feb 28, 2012. 12:06 PM
Yeah...the mom in me cringed when I saw the kids so close but other than that this seems really fun! My munchkin is a bit young yet but someday...someday...
WYE_Lance (author) in reply to Little Mom on the PrairieFeb 28, 2012. 5:08 PM
It does seem quite dangerous, though so far I've conducted hundreds of launches with no injuries. I thought about excluding some clips from the video because it looks dangerous, but showing true footage has prompted concerned members of the community to voice their ideas for safety improvements :)
ajoyraman says: Feb 27, 2012. 8:27 PM
Great Work ! and Excellent use of common PVC pipe fittings.
MTJimL says: Feb 26, 2012. 5:45 PM
I must be a klutz, as I could never get away with handling PVC weld without gloves. Would pipe-threaded joints be another option? Also, creative variations should prevent boredom with this project for about a hundred years. Very well done.
WYE_Lance (author) in reply to MTJimLFeb 27, 2012. 7:01 AM
No, unfortunately if you're making a pressure chamber out of PVC you pretty much have to use solvent weld. One variation that I like is a double launcher tube so 2 rockets can fire at once (you may have noticed that two rockets are being fired at the same time at the very beginning of the video).
Closer says: Feb 26, 2012. 1:34 PM
Rather than use a rubber schrader valve (for steel car wheels), you might consider using a clamp in one (for truck or alloy wheeles). This would eliminate the need for the sealing plastic.
WYE_Lance (author) in reply to CloserFeb 26, 2012. 2:37 PM
I just checked out what a clamp-in valve looks like, and I think you're right - it seems much easier to install and you don't have to deal with KwikPlastic. I'll definitely include this in my next design update - thanks!
schmitta says: Feb 26, 2012. 2:14 PM
The rocket really goes great. Excellent toy.
thayray says: Feb 26, 2012. 11:10 AM
Isn't it kinda dangerous? At 0:35 I thought a kid was going to get a rocket in the eyeball.
WYE_Lance (author) in reply to thayrayFeb 26, 2012. 11:54 AM
It is very dangerous! Please follow the safety advice in step 4. Having a clear countdown is what alerted that kid
Treknology says: Feb 26, 2012. 10:35 AM
For sale: One used model rocket kit.
Free to a good home: Only white mouse to have ever had a bird's eye view of Kensington.
jktechwriter says: Feb 26, 2012. 7:28 AM
I like your design but it is very similar to the design by Rick S. that was featured in Make magazine. There are some subtle differences but if you did base your design off of Rick's design you should credit his design in your write up.
WYE_Lance (author) in reply to jktechwriterFeb 26, 2012. 8:16 AM
You're correct - I did use the idea for a base from a video by Make magazine. Actually, the entire launcher is an amalgamation of several rocket launchers I've built in the past couple of years based upon YouTube tutorials and this very site. With all due respect, it seems unnecessary to credit every person who has influenced this particular design. After all, one could define originality as a new combination of common ideas.
jktechwriter in reply to WYE_LanceFeb 26, 2012. 10:11 AM
Yes, but in this instance, your design is almost 100% identical to Rick's. I just compared my launcher that I built from Rick's kit to your photo above and I can see almost zero difference. I'll be more than happy to post a picture of my launcher if you like. I'm not trying to make a big stink about this, but your launcher shown above is pretty much part-for-part the same as Rick's published design and the design sold by the Maker Store.
jktechwriter in reply to jktechwriterFeb 26, 2012. 7:33 AM
A link to Rick's design
http://blog.makezine.com/2010/07/11/how-to-building-the-compressed-air/
WYE_Lance (author) in reply to jktechwriterFeb 26, 2012. 8:17 AM
This link is useful if you're more devoted to DIY than I am - it shows you how to make the button assembly and modified valve without buying from ItsABlast.com
OrigamiAirEnforcer says: Feb 22, 2012. 8:35 PM
I believe the addition of a streamer or something may improve visual recognition for students and other observers.
WYE_Lance (author) in reply to OrigamiAirEnforcerFeb 22, 2012. 9:35 PM
The rockets are pretty easy to see in real life, though it's really quite challenging to capture a paper rocket on video. Streamers might look fun, but I think it would create too much drag. Perhaps a longer rocket would be more visible (and fun!)
1-40 of 48Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
