Projection output.
This instructable has been removed by the author.
83 comments
1-50 of 83next »
Apr 1, 2010. 5:46 AMshowup says:
I like the simplicity of your projector. Can you please post the link from where you purchased your new high resolution (640 by 230) LCD? Apart from the numbers in the specifications of these LCD do you actually see a difference in performance? What i mean is your 640 by 230 better than your old 480 by 240 one? if so, what is the actual difference in the bench? Can you compare the projection size (without any pixelation) of 480 by 240 vs the projection size of 640 by 230 one? Thank you.
Apr 2, 2010. 8:52 AMshowup says:
Thanks for your reply. It was useful. I have one more quick question. Do you connect your PC with the projector using  a converter box like this or just a cable like this? I am in the process of ordering them. I would appreciate your answer. Thanks.
Showup
Apr 5, 2010. 7:01 PMshowup says:
I too noted that once i posted here. The converter box is the better option for me.
One more thing. The ebay LCD is not 620 by 240. The seller was misrepresenting the facts. I asked the package manual and pointed out his/her fault before ordering. To the best of my knowledge the 640 by 480 resolution is only available at 3.5" size not in 2.5". If you know it is available at 2.5" let me know. Thanks for the support.
Apr 26, 2010. 3:02 PMshowup says:
I suppose we should ask and check the package insert before buying such items. Because the specks what they mention are not true at lest in few products that come from China. Apart from the one you purchased from the ebay i also had similar experience. I got this one which is mentioned to have 480x234, but in reality it is just half of that. Have a look at the post by Wkter here. We have to be doubly careful before  we purchase them. Also it may be worth to go for bigger panels (>2.5")  which has higher resolution if we have to spend this much money for a 2.5" high resolution LCD.
Apr 6, 2010. 7:23 AMshowup says:
This is (558 x 234 in 1.8") slightly better one but not 640 by 480.
Apr 6, 2010. 3:07 PMshowup says:
I am just ordering this one to see how it goes.
There is one at 640 by 240 resolution. But costs $$. (94.71+Shipping??)
Apr 6, 2010. 6:46 PMshowup says:
Not like complete building at this moment. I just got a old slide projector for $15. I will replace the slide compartment  with this LCD and see how good it goes. This is my first step. My next build is going to be a high resolution projector using 7-9" LCD and high intensity lamp.
Mar 20, 2010. 7:53 AMoli1122 says:
 one thing will improve it. Im using a 12V 100W in my projector. If you get aluminium foil and make a better reflector by rapping foil around your bulb. you can make it much brighter. Look at the pics they will explain what i mean better
Mar 20, 2010. 7:54 AMoli1122 says:
 I find it makes the bulb 1/2 as bright .
Mar 2, 2010. 5:47 AMCom6491 says:
I'm curious as to what you found the difference to be between the 50 and 100watt light bulbs. Was the 100 watt much better? Or was it too bright?
Jan 17, 2010. 6:11 AMdangeross says:
 nice! that thing is a monster! i need to build my own .
Dec 4, 2009. 10:59 PMelpana22 says:
look l got one go to http://www.lightbulbemporium.com/eiko_81184ek_sp105_41_med.asp
Oct 28, 2009. 1:07 PMnewtonn2 says:
 Hi there again, I was watching your recent videos, and I noticed there is a lo of light getting out at the back of the projector, that will make the room brighter and more difficult to see the screen properly. Try to cover it with something and see the difference.
The image is very good and a lot brighter know!!
Oct 29, 2009. 11:22 AMnewtonn2 says:
 Ok tell me how it goes.
Oct 30, 2009. 3:21 PMnewtonn2 says:
I'm glad it worked better!
Sorry the ear the PSU and light stopped working.
That's a good idea $25, it's not bad at all.
Sep 28, 2009. 6:51 PMslimguy379 says:
hey in the video whats the cartoon your watching? i used to watch it alot and forgot the name...
Sep 4, 2009. 6:31 PMV-Man737 says:
5 stars and favorited. Nice ingenuity.
Apr 28, 2009. 6:17 PMDIY Dave says:
Could you hack a slide projector into a movie projector with a small LCD like that?
Jul 16, 2009. 1:34 PMabadfart says:
there cheep now
Jul 18, 2009. 12:03 PMabadfart says:
i got one for $85 cus it is old but this means that it doesn't have all the stuff that stops you from moding the lamp
Jul 14, 2009. 12:24 PMabadfart says:
nice i have an old projector that they don't make bulbs for any more so i might try this when im out of bulbs
Jul 16, 2009. 1:29 PMabadfart says:
ya i like this one. its old "around 1995" but i got it for $85 USD so ya
Jun 11, 2009. 12:53 PM12V says:
did you know that those bulbs can explode (under normal power even more likely @500w) and smash the screen! also don't not to touch the bulb with bare fingers as this also can cause an explosion!
1-50 of 83next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:mcastles(Marlon Cairenius)
