100W Inverter Circuit
Published
Introduction: 100W Inverter Circuit
Introduction:-
An inverter converts the DC voltage to an AC voltage. In most cases, the
input DC voltage is usually lower than the output voltage of the inverter while the output AC is equal to the grid supply voltage 120 volts, or 240 Volts.
Let's make a fully functional inverter circuit.
Step 1: Inverter Basics | Watch the Video Bellow
This video is only for understanding inverter's concept.
Step 2: Let's Make a Inverter (Watch the Video)
Step 3: Parts List
4047 IC
14 Pin IC socket
3 *22K Resistor
2 *220 Ohm Resistor
100 Ohm Resistor
0.01uf capacitor
2 *IRF 3205 mosfet
100uf cap
10V Zener
4007 Diode
Varo Board
Step 4: Circuit Diagram
Step 5: Some Pictures After Soldering
Step 6: Transformer Information
I am using 12-6-0-6-12 5 amp Transformer you can call it 120 VA transformer. You can use any kind of 12 -0-12 transformer.
Step 7: Now the Inverter Is Ready to Use
This inverter can handle up to 100w of load but be careful, on the 100w of load you should use Heatsinks with those mosfets.
Step 8: To Support My Work Please Subscribe My YouTube Channel
SUBSCRIBE My Channel Please
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
