A chance encounter with a 100-pack of green LEDs inspired my daughter and me to make an wreath totally out of LEDs. We wound up using 96 of the green ones, plus 5 red LEDs left over from a previous flea market visit, for a total of 101 LEDs.
It can be twisted together without tools, but soldering makes it sturdier and a pair of needle-nosed pliers and a third hand jig will make it easier.
ROHS LEDs (about a dollar more per pack) and lead-free solder is always an option, or just wash your hands and don't stick your fingers in your mouth.
Remove these ads by
Signing UpStep 1Parts and Tools Required
100 Green LEDs
5 Red LEDs
A few feet of solid tinned hook-up wire, small gauge such as #26.
Use tinned wire, as plain copper wire would be a distracting color. You may also find special-purpose "bus wire" but don't use a gauge that's too big as it will be hard to sew.
Also Starring
You'll need a power supply or batteries capable of delivering about 0.6-1 amp at 8-10 volts, but that design is not included in this Instructable. Instead, you might like this Super-Simple LED Driver Instructable. Or just use a 9V battery.
For testing the LEDs during construction, If you don't have a power supply, you'll also need one slightly-depleted 9V battery or one fresh 9V battery and a 330 Ohm resistor.
The Tools
To finish the job, you'll need the following tools:
Solder and iron if you wish to solder (recommended but not necessary)
Needle-nosed pliers with wire cutter
Third hand jig (or make your own
Alligator-clip test leads
i hope you enyou it.
http://www.youtube.com/watch?v=lJtLA7EfgGQ
If you want to do something to show in a video, a PWM power supply like this might be fun: http://www.instructables.com/id/SKGS2GVFOVX0VOK/
For the red LEDs, they are 5 in series. Voltage drop for red LEDs is about 1.7v, which is lower than for green (~2.2v), so 5 red in series is a little brighter than 4 green at the same supply voltage. See http://www.instructables.com/community/Green-Led-voltage/
If your 5 red LEDs are too bright reduce the current by putting in a small resistor (10 ohms, 1/8th watt or more) in series with the 5 red LEDs.
Connect the left end (+) to the inner ring of the wreath.
Connect the right end (-) to the outer ring of the wreath.
In my wreath design, the red LEDs are always on, and do not blink. You could use a timer circuit to blink just the red ones together. If you want the red ones to flash individually, you will need a more complicated circuit.
Does this help?
i think that i now how to coneckt them now :)
