The aim of the project was to make an audio amplifier that can deliver up to 10W R.M.S. power output. input can be given via computer/mp3 player or a mic (mic circuit explanation at the end). there are many different types of amplifiers tda2003 is probably a class b amplifier because its power consumption is quiet low then normal amplifiers and also that its noise is very low.
the purpose for which i chose this ic is that it has very less external components, very low distortion,very low input power and a corresponding high output power.
ABOUT THE IC
TDA2003 is a 10W car radio audio amplifier The device provides a high output current capability (up to 3.5A) very low harmonic and cross-over distortion. Completely safe operation is guaranteed due to protection against DC and AC short circuit between all pins and ground,thermal over-range,load dump voltage surge up to 40V
Remove these ads by
Signing UpStep 1: Things Required
lists of components required to build the circuit
Resistors:
- R1:220 Ω
- R2: 2.2Ω
- R3: 1Ω 1 watt
- Rx: 39Ω See the datasheet paw to alter the value of Rx
- RV1: 10kΩ
Capacitors
- C1: 2.2µF 25V electrolytic
- C2:470µF 35V electrolytic
- C3:0.1µF polyester or ceramic
- C4:1000µF/35 V electrolytic
- C5: 100nF polyester or ceramic
- C6: 100µF 35v electrolytic
- Cx 39nF See the datasheet paw to alter the value of Cx
Semiconductors
- IC1: TDA2003
: connectors (cream shell connectors )
3- 2 pin connectors
Visit Our Store »
Go Pro Today »
the one i used i dont know the exact name or number but it was like
http://www.google.com.pk/imgres?um=1&hl=en&safe=off&tbo=d&biw=1280&bih=930&tbm=isch&tbnid=PCkBoQMeHwIglM:&imgrefurl=http://www.panasonic.com/industrial/electronic-components/audio-components/electret-condenser-microphones.aspx&docid=PgAINLATIM6n6M&imgurl=http://www.panasonic.com/industrial/images/electronic-components/4.8-audio-components/audio-components-electret-condensor-mic-feature1.gif&w=144&h=104&ei=8ZLpULPjO4aD4ATQroHoDg&zoom=1&iact=hc&vpx=907&vpy=415&dur=3311&hovh=83&hovw=115&tx=87&ty=32&sig=109102747932937238433&page=2&tbnh=83&tbnw=102&start=33&ndsp=37&ved=1t:429,r:56,s:0,i:255
its too dificult to manage all of the transistors and even then all u get is a 1w or max 4w gain ..
if u have any link to discrete amplifier with gain greater than 10W do tell me i want to try one in summer.
only four partsin circuit ;D
but the IC works at 14V typically and delivers 44W output power which means that it will draw 3.2 Amperes current .. the transformers that are capable of supplying such amount of current are costly ..
B.T.W. it could be a very nice project for a music Lover ; )
it will provide a lot of power on 12v
but still u can use that ... i will soon upload another supply circuit without transformer and rectifier circuit .. it will be quiet cheaper and efficient too..
