11 LED Adjustable Chaser With 555Timer
3,413
73
6
Posted
Introduction: 11 LED Adjustable Chaser With 555Timer
Parts:
Leds: Pack of 25 Can use Purple Ones
IC: 555 timer, CD4017
Capacitor: 10uf, 100nf(104)
Potentiometer: 10k Linear Mono
Resistors: 1k, 10k, 120ohm
Breadboard + Cables + Battery Clip
Step 1: Place Base Components
The 555 timer and Cd4017 are placed along with the leds and the wires connecting to power and ground.
555Timer:
Pin1 to Gnd
Pin4 to Pwr
Pin8 to Pwr
Cd4017:
Pin8 to Gnd
Pin13 to Gnd
Pin15 to Gnd
Pin16 to Pwr
Step 2: Add the Rest of the Components
The capacitors, resistors and potentiometer as well as the last led are added.
Capacitors:
100nF(104) Pin5 to Gnd
10uF Pin6 to Gnd NEGATIVE SIDE to GROUND!
Resistors:
10k Pin7 to Pwr
120ohm Pin3 to Extra LED leg
1k x10 LED leg to other side
Potentiometer:
10k at edge
Step 3: First Wires
Right Potentiometer leg to Pin5
Middle Potentiometer leg to Pin7
Left Potentiometer leg to Pin7
Pin6 To Pin2
Step 4: Alittle More Wires
Pin14 to LED leg
CD4017 to Resistor (LED)
Pin3 to LED1
Pin2 to LED2
Pin4 to LED3
Pin7 to LED4
Pin10 to LED5
Pin1 to LED6
Pin5 to LED7
Pin6 to LED8
Pin9 to LED9
Pin11 to LED10
Pin12 No connection
Step 5: Its Done
Potentiometer Varies the Speed.
DC 5-10V
The circuit can be soldered and then included in a robot to give a cool effect.
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
  • Science of Cooking
    Science of Cooking
4 Comments
Can I add a strip of 5-10 LEDs instead of each single LED , and will be there a necessity to change the resistors or input voltage?
Thanks in advance
In the original, each led is controlled separately so if an led strip was added to one output it would only light up for that output (each led is connected to a different pin of the cd4017). If you wanted to connect an led strip to each separate output you could but it would need 12V (12v standard for led strips, some run on 5V). Looking at the data sheets it looks like you could but you would need to make sure the rest of your components can handle 12v and probably around 1 Amp (depends on length and number of leds). The resistors going to the leds could then possibly be removed if the led strips can handle the current. Transistors or MOSFETS could also be used at each output so the higher current isn't being drawn through the other components.
I will try this with an led strip as it would give a nice effect and then later reply.
http://www.ti.com/lit/ds/symlink/cd4017b.pdf
http://www.ti.com/lit/ds/symlink/ne555.pdf
You don't need all these resistors, one is enough because there's only one 4017 output active at a time.
A schematic would be extremely helpful. And I don't know if you know, but they sell resistor DIP chips exactly for this type setup. It makes a PC circuit board a lot easier to setup. JMHO! Otherwise seem like a nice circuit.
