11 Unusual Uses for Baby Oil
 by wilgubeast
Featured
Have you heard that joke about baby oil? The one that goes something like:
If corn oil is made with corn and peanut oil is made with peanuts, then what is baby oil made with?
The answer: Baby oil is made with mineral oil and fragrance by industrial professionals; babies don't have the fine motor skills or chemistry knowledge to create baby oil, duh.
Baby oil is useful for a lot of things beyond baby bottoms. It'll smooth, soften, lubricate, refinish, clean, and so much more. It also has some usual uses for which it really oughtn't be used. Read on for some tips and tricks that'll help you step your baby oil game up.
Step 1: First, some don'ts
Don't use baby oil as a "personal" lubricant, particularly if you are using a latex condom. (Just look at the next step to see who wins in the latex vs. baby oil battle royale.)
Don't use baby oil to tan. Melanoma looks bad enough without being shiny.
Don't eat baby oil. It has laxative properties and likely doesn't taste delicious. (Mineral oil is safe for human consumption, but only up to around 100 mg. Many of those milligrams come from food-grade mineral oil that's used in baking and other industrial food processing places because it's odorless and tasteless. My guess is that baby oil mineral oil isn't food-grade. Stay safe: don't guzzle a bottle of it.)
Don't use it in your 2-stroke engine.
Don't aim baby oil at helicopter pilots. Wait... that's for lasers. But you should still be careful around helicopter pilots with baby oil. It can be a slip-fall hazard, and pilots prefer the scent of aviation fuel.
Lillfot says: Apr 11, 2013. 1:01 PM
Heh, it ain't winter here in Sweden if it's above -10°C. Tough it out! :)
miles-fisher says: Mar 27, 2011. 6:26 AM
Baby oil is also useful for stopping creaking floor boards. Just trickle a small amount on the joint and hey presto.
eight in reply to miles-fisherMar 27, 2011. 6:37 AM
Talc is far better !
dejure in reply to eightMar 27, 2011. 7:10 PM
While you are generally right, insofar as noise is concerned, it depends on the situation and effects you are seeking.
Creaking is the result of shrinking of the wood caused by loss of moisture. If appropriate, oil can swell the wood and reduce noise. On the West Coast, decks often look horrible in the summer, after they've dried and shrunk back down, revealing cracks and splits. Oil, when it soaks into the wood, has the same swelling effect as water, but without rot problems and it doesn't evaporate at the rate water does.
Similar to with decks, mineral oil is good for butcher blocks. I have restored them by merely slathering on mineral oil (not adulterated mineral oil, like baby oil). After soaking for a few days, all the separations between pieces and cracks from drying disappeared.
Bosun Rick in reply to dejureMar 27, 2011. 9:26 PM
If it's 'Baby Oil', how can it be 'adulterated', wouldn't it become Matured Oil?
I need to go to bed, this is getting to me!!
dejure in reply to Bosun RickJan 22, 2013. 10:24 AM
Groan
KittyF in reply to Bosun RickMar 28, 2011. 6:02 AM
baby oil has added scent, which wouldn't be a good thing for a Butcher block or cutting board where food is going to be prepared. using plain mineral oil is a better option in that case.
gloriaflower in reply to KittyFMar 28, 2011. 6:31 AM
using any petroleum based product near food is a bad idea.....walnut oil, etc. better for wood surfaces that are used for food.
KittyF in reply to gloriaflowerMar 28, 2011. 4:36 PM
well, that's very true and I'd never thought of walnut oil. I was only commenting on the inadvisability of adding baby oil scent to food. LOL next time I have trouble with a cutting board I'll find some walnut oil rather than tossing it.
static in reply to KittyFMar 30, 2011. 9:51 PM
Vegetable oils can turn rancid (and generally does in time), that's why mineral oil is recommended for wood surfaces that come in contact with food. Mineral safe for human use can be found at the pharmacy.
gloriaflower in reply to KittyFMar 28, 2011. 6:15 PM
good idea, I sometimes refinish wooden bowls, and walnut oil while somewhat expensive is really worth it, you really don't need much, just let it dry and buff it with a soft cloth
dejure in reply to KittyFMar 28, 2011. 5:22 PM
Just for reference, be aware walnut cooking oil is a hardening oil, whereas mineral oil is a non hardening oil.
Hardening oils include oils like tung oil and boiled linseed oil. While both would be poisonous to ingest. "Boiled" linseed oil is flax seed oil with heavy metals added to speed hardening (polymerization). It tends to darken wood. Tung oil often has heavy metals added too, but would be toxic without them. It and walnut oil do not darken wood like boiled linseed oil.
Hardening oils take time to harden. If they are pre-polymerized and have hardeners added, they will dry quicker. In any event, all excess hardening oil should be wiped off, or it will orange peel, and will take longer to dry.
Many people use olive oil to treat wood food preparation surfaces. However, olive oil goes rancid (lots of free radicals) from exposure to air. You can usually smell a breadboard treated with olive oil.
When any standard finish (e.g., shellac, polyurethane, lacquer, hardening oil) hardens, it is considered safe for food grade finishes.
While I agree mineral oil probably isn't something we should be drinking, the amount you would get on your food, after treating a butcher block or bread board would not be significant. Too, after treating with mineral oil, you can put a hardening oil or other oil compatible finish on to seal in the oil.
flamesami in reply to dejureDec 12, 2011. 11:24 AM
linseed oil does not have to be "boiled" to harden, it will just take longer (a few weeks instead of a few days) and therefore penetrate further. An example of a vegetable oil that stays liquid is sweet almond oil...almond and walnut oil can be toxic if not pressed a certain way though
dejure in reply to flamesamiSep 1, 2012. 4:17 PM
Linseed oil is not actually boiled. It is said it got its name because it appeared to be boiling, as air was blown through it to speed up polimyerization.
Linseed oil is made from flax seed. After it is put through a process, which often includes adding heavy metal driers, it is called boiled linseed oil.
flamesami in reply to dejureSep 13, 2012. 3:00 AM
huh, I didn't know that. Are you sure? I would think that if you blew air through the oil, it would harden pretty fast and would therefore not keep well. It was my understanding that heating the oil changed it so that it reacted faster with oxygen, but as long as it wasn't exposed to air, it would keep, without polymerizing (setting).
Like I said before, pure linseed oil will still harden/oxidize/set, but a lot slower than boiled linseed.
d_j_h in reply to eightMar 27, 2011. 5:38 PM
I second that talc is better. So is graphite.
While oil works perfectly well enough, in a floor it also attracts dirt and eventually becomes sludge whereas the dry lubricants do not.
The same goes for lubricating door lock keyholes.
dejure in reply to d_j_hSep 1, 2012. 4:37 PM
Talc works extremely well to stop squeaking resulting from two wood surfaces moving against each other. The most common example might be oak flooring. The squeaking could be from the flooring moving on the subflooring or movement against an adjacent board.
If the squeaking is from subflooring moving against the support beam, talc will do nothing to solve the problem, since the talc could not get to the trouble spot.
dejure says: Mar 27, 2011. 7:31 PM
For those of you interested in treating your furniture with lemon oil products, be aware the "lemon oil" products you purchase downtown are just mineral oil with a lemon scent. Using straight mineral oil will give you the same effect.
If your furniture isn't coated with wax, whether from Pledge or some other product, you can apply "tung oil finish," pure tung oil (polymerized is preferred) or boiled linseed oil. The latter two may emit an odor longer than the finish, which is just thinned linseed oil with resin, thus, a wiping finish. These will harden and, if thinned for application (the finish is already thinned), will soak in just as the mineral oil would.
gnach in reply to dejureMar 27, 2011. 10:48 PM
And the shiny oil attracts and holds dust which accumulates to grime.
dejure in reply to gnachOct 2, 2012. 10:50 AM
A day or so after application, the "shinny oil" finish no more attracts dust than does a varnish, shellac or lacquer finish.
Boiled linseed oil (just flax seed oil with [toxic] driers added, and which has been polymerized by blowing air through it so it appears to be boiling, thus the name "boiled linseed oil") and tung, or Chinese oil, as well as products that incorporate those names (e.g., "Tung Oil Finish") are hardening finishes. Boiled linseed oil and tung oil are common ingredients in high end finishes.
gnach in reply to dejureOct 2, 2012. 8:58 PM
But now you're you're no longer taking about mineral oil but catalyzing finishes. Baby oil doesn't harden and as the solvent evaporates you are left with the oily residue. FIY, back in the day and in the 5 gallon drum, linseed oil WAS boiled, hence the name, which caused the molecule chains to polymerize. We used to use it on wooden ladders, A frame and extension, in electrical service. A warm sunny day would soften the finish and give a little extra "grip".
dejure in reply to gnachOct 3, 2012. 10:19 AM
After more digging, it seems you are also correct, regarding some processes (e.g., boiling). It should be noted those information resources indicate very controlled conditions in the process (i.e., no oxygen). One site (http://www.sydneywoodturners.com.au/site/articles/finishing/oils.html) gives details.
gnach in reply to dejureOct 5, 2012. 9:10 AM
Thank you dejure. I wasn't contradicting you in my first reply. I was agreeing that lemon oil is just scented mineral oil as is baby oil. Modern technologies have made great improvements in finishes. It's come a long way from crushed beetle shells or tallow. And getting better all the time. I've been a fan of catalyzed oils for a long time but they still require maintenance to keep it's protection and appearance.
dejure in reply to gnachOct 3, 2012. 10:05 AM
Sorry, since your statement about "shiny oil" didn't make clear which oil referenced in my post would attract dust, I wanted to make clear the fact boiled linseed oil and tung oil, once hard and "shiny," would not.
Since the last of my post talked about hardening oils, as opposed to [non hardening] baby oil, I presumed people would note the difference, The difference in the types of oils is noted several posts down from this.
For reference, below is a quote from.jamestowndistributors site. Other sites can be found that describe the process. Batches could be ruined by overheating, such as by bringing them to a boil. That may be why a finish which would not normally melt "gave more traction when hot.
"'Boiled' linseed oil, though, is not boiled. The actual boiling of some varnish oils changes their drying characteristics. With linseed oil, though, it is the addition of certain solvents that causes linseed oil to dry more quickly, acting as if it were boiled. This makes it a better product for preserving tool handles, decks, and furniture. I suppose they should have named it "sort-of-boiled linseed oil", or "kinda-like-boiled-but-not-really-boiled linseed oil". Boiled Linseed Oil is used as a natural wood finish and preservative, either alone or with other oils and solvents. Mixed with oil based paints and varnishes, it increases gloss and improves leveling and durability. A mixture of 2 parts boiled linseed oil to one part turpentine creates a semi-gloss wood polish for furniture. Can also be mixed with mineral spirits."
As elsewhere noted, the term boiled, when applied to boiled linseed oil, is said to be based on that the oil appeared to be boiling, when air was blown through the oil to speed polymerization.
nax says: Mar 29, 2011. 10:49 PM
Why? Olive oil is much nicer.
dejure in reply to naxOct 2, 2012. 10:35 AM
Olive oil is prone to going rancid. For that reason, products to treat wood cutting boards/blocks and other surfaces use the petroleum based mineral oil.
muldoon man says: Mar 14, 2012. 7:31 PM
I've read that mineral oil is a non-conductive liquid. Because of this unique property I've seen people who have literally dropped a computer into a fish tank filled with mineral oil. Allegedly they work great, it's like poor man's liquid cooling.
rams666 in reply to muldoon manMay 3, 2012. 11:37 PM
it provides better cooling than fans and its noiseless and it has the possibility to be further cooled thus allowing you to overclock your system well above the norm
STCVKR says: Apr 6, 2012. 10:01 AM
Another use: Remove temporary tattoos from skin.
backscan says: Jan 9, 2012. 10:36 AM
A little less common use for baby oil is it's perfect for storing sodium or potassium as long as you make sure it's pure mineral oil (no perfumes)
evilution says: Dec 11, 2011. 3:30 PM
Baby oil is also very good for cleaning silicone "toys" and silicone hoses on your car.
wilgubeast (author) in reply to evilutionDec 12, 2011. 11:05 AM
Nice! I hadn't considered that. Bonus points for showing us a picture of the automotive cleaning use. (And by bonus points, I mean a 3 month pro membership.)
evilution in reply to wilgubeastDec 13, 2011. 2:48 PM
Hopefully this will have worked, it was just a quick wipe with baby oil and a dirty paper roll. Takes the dirt off and gives it the shine back.
Also, to add to the list again (and as unlikely as this sounds it's a good one)...
If you eat something really spicy and your mouth is burning and you can't stand it, if you swill some baby oil in your mouth and spit it out it will take the burning away.
This is because the capsicum is usually an oil so it's hydrophobic. Water has no reaction, doesn't suspend it so doesn't lessen the burning. Swilling baby oil suspends the capsicum, "waters it down" and allows you to spit it out.
thinkiam says: Mar 28, 2011. 7:14 AM
My mom used to put warm honey in my ear when I had swimmers ear. The honey, which was denser than the water, would "push" the water out. I have no memory of how she got the warm honey out of my ear!?!
bryan3141 in reply to thinkiamDec 11, 2011. 9:46 AM
old diver's remedy for swimmer's ear: grab a bottle of rum, a shot glass and a thimble. Pour rum into the shot glass and the thimble. pour the shot down your throat, the thimble full in your ear. Repeat till no pain is felt.
wilgubeast (author) in reply to bryan3141Dec 12, 2011. 10:56 AM
That sounds like it would absolutely work over the short term. Until the rum's gone. Or until it gets too difficult to pour rum into a thimble.
MissCindel in reply to thinkiamMar 28, 2011. 9:01 AM
That's pretty cool = I have a version of Swimmer's Ear that water = a worse mess. And so far I see to be allergic to the commercial ear cleaner on the market. I use to go to the doctor's to be "flushed, and vacuumed" but that is really spendy. I switched to ear candling but that takes at least two people and makes a smokey mess.
All that to say: if you find out what cleaned out the honey = I'd sure like to know! :*)
Javin007 in reply to MissCindelMar 31, 2011. 7:02 AM
I would strongly, strongly, strongly recommend against ear candling. Ear candling is a farce. The physics alone make the concept that it "draws" ANYTHING out of your head completely and physically impossible. The wax found inside the cones after they've burnt is the wax from the candle itself, not from your head. Normally, I'd say, "If you wanna blow your money on a pointless, useless, hoax 'remedy' then no harm, no foul" except that many, many people have been permanently damaged by ear candling, have gotten severe burns INSIDE their ear canals, and have even ruptured ear drums when scalding wax manages to hit them directly. Ear candling has not only been completely proven that does not work, but it's even dangerous. For this reason, you can't even purchase ear candles (legally) in Canada.
http://www.hc-sc.gc.ca/hl-vs/iyh-vsv/med/ear-oreille-eng.php
MissCindel in reply to Javin007Mar 31, 2011. 11:06 AM
Thank you for your strong warning.
I have personal experience with ear candles and can say honestly that the draft created does remove wax from my ears. Once, out of curiosity, I purchased some just to unwind them and see if all the junk that I was seeing at the end of a session had already been snuck into the ear candle. None of the wax that appeared to have been removed from my ears was pre-existing in any of the four I disemboweled.
Do I think they are dangerous? I think anything involving fire has the potential to do great harm. The candles I've used do not contain excess wax, I know this because there have never been wax droplets after/during their burning. When I run the tip of my finger on the inside of the wide end of an ear candle I feel the material only because the wax coating is on the outside.
cjmills in reply to MissCindelMar 28, 2011. 12:08 PM
I've also used peroxide to "boil" my ears out when faced with swimmers ear/severe sinus infection that settles in my ears. It seems to have worked well with no ill effects thus far.
thinkiam in reply to cjmillsMar 28, 2011. 3:18 PM
Mix one third H2O2 (peroxide) one third 70% rubbing alcohol and one third vinegar. I use a dropper to put in my ears after every swim. I did get this recipe frop my doctor. Still doesn't feel as nice as the honey!
thinkiam in reply to MissCindelMar 28, 2011. 9:27 AM
Honestly, I think since the honey was warm, it flowed well, so she just had us lay (honey + ear) down on a warm damp washcloth. I remember it felt really really soothing. The most important part is to make sure the honey isn't too hot, that happened once, ouch! I'm also thinking a drop of tea tree oil afterwards would be really helpful. Ears. Ya don't really think about 'em till they hurt, then ya can't think about much else!
wilgubeast (author) says: Dec 6, 2011. 12:04 PM
After having a significant cebum compaction due to extra waxiness and some in-ear headphones, I highly recommend all the hydrogen peroxide recommendations here.
Best method? Hydrogen peroxide + needle-less syringe. The hp will break up the wax, and water from the syringe flushes it out. (You don't need a lot of water pressure. Nor do you want it. Unless you want to see if you can brainwash yourself via your auditory canal.)
SIRJAMES09 says: Dec 6, 2011. 11:58 AM
needle-less syringe = catheter tipped syringe.
This is another type of syringe without a needle in it...in fact, the way this syringe is made, there is no way a needle can be attached normally. I'm not for sure, but I think you can buy Catheter tipped syringes at your local drug store...check with the Pharmacist for sure.
I know this because I use these every day.
BUT, any syringe that does not have a needle will do just fine.
Annaaziza says: May 4, 2011. 2:56 PM
I use baby oil right before the show ring. We smear it around my Arab Quarter Geldings eyes and muzzel to make him stand out. Their is the option of buying Face Goo, but baby oil works just as well. (Although, Blaze dosent really appreciate it...... :/ ) The one bad thing about it is, if your horse is white, or has white markings on his/her face, (Like my horse, who has ALOT of white) they can get sunburned. So on those hot horse show days, wipe it off with a baby wipe (HA! A theme!) to reduce the chance of their tender muzzes getting crispy fried.
hosborne1 in reply to AnnaazizaDec 5, 2011. 5:58 PM
Try using plain mineral oil instead of baby oil on Blaze! I used to fight my Egyptian Arab Godiva constantly until I realized she just didn't like the scent. if your horse is not head-shy usually but acts up when you approach him with the oil that may be it. You could also try purchasing a different type of baby oil; I've used Johnson's baby oil with shea and cocoa butter and that seems to be preferable for Godiva as well. Plus, it smells really nice and you can put it on your hands after bathing your horse to ward off dry skin!!!
mrsthursday says: Sep 22, 2011. 8:04 PM
you can use baby oil to clean a stainless steele fridge, it gets rid of the finger prints and a little goes a long way- so just use a dimes worth- put on with a soft cloth and buff up with another soft clean cloth.
evacooper says: Sep 19, 2011. 12:31 PM
i tried this, and it totally didnt work. i have bad stretchmarks, and my mom doesnt have and neither did my grandmother apparently, and i also didnt gain weight too quickly (the only way to avoid stretchmarks, except it isnt)
ameece says: Aug 9, 2011. 12:55 PM
On behalf of northern Russia, all of you can shut up and suck on a binkie :p
you bunch of babies. Hah!
Bosun Rick says: Mar 27, 2011. 9:13 PM
Yeah, but who wants to go through life with rough, crackley eyelids? I hate it when that happens!!
ameece in reply to Bosun RickAug 9, 2011. 12:49 PM
Hey, there ARE people out there that go through life with "rough, crackley eyelids" lol- I'm one of them, and the red, irritated, rough patches around the eyes are caused by eczema, come on now :(
I can take a joke, but baby oil and Vaseline work wonders for us who have messed up, sensitive skin :)
ginny2221956 says: Jun 16, 2011. 8:10 PM
My mom always used sweet oil for ear aches.
nutsandbolts_64 says: Mar 30, 2011. 8:44 PM
YES!!! STEP 4 TO THE RESCUE!!! At least now I don't have to pay a lot of money just to remove a clog down my ear. Thank you!
janettetsmith says: Mar 27, 2011. 6:15 PM
Actually, you're never supposed to put mineral oil on your face, especially the eye area.  Only noncomedogenic products for the face.  :)
rejectcarp in reply to janettetsmithMar 30, 2011. 3:55 PM
Purified mineral oil really isn't bad for the skin in this application. It shouldn't be used as a leave-on barrier, but for removing eye makeup before another cleansing step it's cheap and works well.
http://www.futurederm.com/2007/12/21/is-mineral-oil-really-bad-for-your-skin/
http://thebeautybrains.com/2006/11/28/the-top-5-myths-about-mineral-oil-part-1/
julesbean27 in reply to janettetsmithMar 29, 2011. 8:31 AM
I've used baby oil to remove my eye makeup for over 15 years now. I've found it to be more effective than any commercial eye makeup remover I've tried and it's never caused a problem with breakouts or blemishes.
SeaLion says: Mar 30, 2011. 7:21 AM
I heard years ago that another good use of baby oil is to shine up that old cooker area...haven't tried that out though...
bullfrogs says: Mar 28, 2011. 8:40 PM
After cleaning your stainless steel sink or appliances, or dishwasher etc, use baby oil on a soft towel to cover and prevent fingerprints. Wipe on with the grain Looks good to.
bullfrogs
usr817smith says: Mar 28, 2011. 3:28 PM
I'm just wondering what YMMV means......
kitchallis in reply to usr817smithMar 28, 2011. 4:59 PM
Your milage may vary.
piemonkey46 says: Mar 28, 2011. 2:05 PM
Hydrogen Peroxide works pretty well for this. I haven't tried the oil though, it seems like it would be messier...
Probasco says: Mar 27, 2011. 7:41 PM
I wanna know why someone's necklace is growling at them. I have never heard of snarl in this context. Snag maybe? Knot?
rhonethesilver in reply to ProbascoMar 28, 2011. 10:22 AM
No, the word snarl can indeed be used to indicate a tangle as well as a growl. The OP is not in the wrong.
macruadhi in reply to ProbascoMar 28, 2011. 1:00 AM
You've never heard of a traffic snarl? Must be regional.
Probasco in reply to macruadhiMar 28, 2011. 1:16 AM
A traffic snarl? C'mon. It's a traffic jam. Everyone knows this!
Javin007 in reply to ProbascoMar 31, 2011. 7:06 AM
snarl    
[snahrl]
–noun
1. a tangle, as of thread, hair, or wire.
2. a complicated or confused condition or matter: a traffic snarl.
3. a knot in wood.
mz anne thrope in reply to ProbascoMar 29, 2011. 4:01 AM
snarl also has a definition of knot or tangle.
katzpawz in reply to ProbascoMar 27, 2011. 11:39 PM
I think that this use of the word "snarl" might be a regional-cultural use. It was used in this manner quite a bit, instead of the word "snagged" when I grew up in Upstate NY. Of course that was waaaayyyy back when dinoaurs roamed the earth! Now I'm in my 60's - no longer live in NY and I have NO idea how homogenous the verbal culture has become back there. Just sayin'!
Katzpawz
crak-a-bottle in reply to katzpawzApr 3, 2011. 12:50 AM
Maybe it's reigonal, altho I live in the UK and people use the word where I live. Although not usually in the sense of a 'traffic snarl'.
Smoothmachines says: Mar 27, 2011. 1:26 PM
Mineral oil has nothing to do on or in your body, it´s something for your car.
Baby oil is not even food-grade...
It´s a nasty petrochemical containing neurotoxins which damage the nervous system, it´s a well known carcinogen that´s clogging your pores and most of the time olive oil will generally be as good or better, even for removing sticker remains.
The mechanical lubricant ability of baby oil is very poor, olive oil would do as good a sharpening job on the oil stone.
I melt bee´s wax in good olive oil to make the face -15C protection (or worse, this is Sweden and we do get -20C during winter) and skin balm , same goes as lip balm casted in empty glue stick cases, this is actually cheaper, less greasy and a lot better for your skin/health than mineral oil.
Please make a search on mineral oil and it´s dangers before you use it on anything near/on you, it may seem harmless and neutral but it is documented dangerous by stately organs worldwide.
AR10NZ in reply to SmoothmachinesMar 28, 2011. 10:03 AM
My wife & I totally agree ! Many practises from years gone by, are now known to be very bad choices, from a health point of view.
Cheers,
Dian & Denns
thinkiam in reply to SmoothmachinesMar 28, 2011. 7:07 AM
Yes. Absolutely. Mineral/baby oil should not be put anywhere near your body, and especially not a baby's body. If you like the thin viscosity of mineral oil as opposed to olive oil, then grape seed oil will do ya just fine. Also try mixing the oil with baking soda rather than flour to clean jewelry, knives, and other shinies.
dejure in reply to SmoothmachinesMar 27, 2011. 7:15 PM
Hear, hear. One should no more put mineral oil on a baby's butt than they should the oil with which I would fill the crank case of my work van. They are both petroleum products.
While it may be claimed it will not be absorbed into the skin, you might want to investigate the longevity of individuals who work with petroleum products day in and day out. Many leave this earthly coil too soon.
Smoothmachines in reply to SmoothmachinesMar 27, 2011. 2:56 PM
And i know we are not talking motor oil, we talk baby oil allright.
Swedes and europeans are using just the same and so did i before i got to know about it....
TheWelfareWarrior in reply to SmoothmachinesMar 27, 2011. 1:41 PM
There's two types of 'mineral oil', there's mineral oil engine oil (as opposed to synthetic) and there's another type for cooking and such (see this entire instructable)
We 'murrikans are stupid, but not that stupid.
amnartist in reply to TheWelfareWarriorMar 27, 2011. 7:33 PM
True TheWelfareWarrior! Food grade mineral oil is also used to lubricate cutting boards(as in 'food' cutting boards) everywhere...not that it has anything to do with baby oil :-)
dejure in reply to TheWelfareWarriorMar 27, 2011. 7:20 PM
There is no such thing as mineral oil for cooking. Nor have I found "mineral oil" for engines, though they are brothers, or sisters, if you'd rather.
TheWelfareWarrior in reply to dejureMar 27, 2011. 9:15 PM
http://annadannfelt.files.wordpress.com/2010/11/a051204_001_mineral_oil.jpg
It's sold as a laxative and is often used in lubricating machines that handle food.
The original post didn't mention that it can also be used to cool oil-submerged computers.
nurse1 says: Mar 28, 2011. 9:40 AM
I know that your intent is to be helpful. Thank you for adding some "don'ts" - especially about mixing baby oil (same for Vaseline) and condoms. As a nurse, I feel compelled to inform everyone that whatever you use on your skin is absorbed by your body; your skin IS an organ of your body.
Beyond that, baby oil IS mineral oil (see the label) - whether or not "food grade" - AND is a petroleum product just like gasoline and oil for your vehicles, mowers, etc. Same goes for Vaseline and WD-40. Would you use gasoline on your baby's skin?
Consider using vegetable oil, olive oil (preferred), or butter (including cocoa and shea - also preferred) to remove paint on your skin. I would consider trying these on your tip about unkinking jewelry since it rests on your skin - I've not tried that!
Beware of industry since they will say anything to get you to buy...
PS I really enjoyed the humor that you added to your instructable!
I also enjoy reading the comments that are posted with the all instructables too.
MsJaxFla says: Mar 28, 2011. 7:50 AM
ROTFLMAO........... exactly Turboelf....... funny, still laughing, but then I don't have or have yet to have Athlete's Foot..... thank you God.
thinkiam says: Mar 28, 2011. 7:24 AM
Baby oil + face = zits :-(
gecko_girl3 says: Mar 27, 2011. 6:35 PM
Oil does not get absorbed into the skin. It merely lubricates the top layer, giving the illusion of moisturizing. The best way to avoid stretch marks is not to get pregnant, if that's no longer an option then pick up some aloe Vera gel. The best aloe is clear and odorless. Apply it to your entire body daily, after bathing is best, and it will help your skin remain soft and supple helping reduce the chances of stretch marks. One must also take into account that your ability to get stretch marks is heridetary, if your mother & grandmother got horrible stretch marks when pregnant, chances are you will too, no matter how har you try to avoid them. :(
KittyF in reply to gecko_girl3Mar 28, 2011. 5:54 AM
unfortunately the skin does absorb stuff, from poisons to chemicals of all types. so anything you don't want running around in your circulatory system you shouldn't put on your skin. try olive oil, or coconut oil for a food grade oil for your skin.
gloriaflower in reply to KittyFMar 28, 2011. 6:32 AM
Kitty is right..........
emerson.john says: Mar 27, 2011. 9:27 AM
Good solvent for removing gummed labels, price stickers, etc. from non-porous surfaces. WD40 is even better.
Bosun Rick in reply to emerson.johnMar 27, 2011. 9:24 PM
WD-40 is Fish Oil, also good for arthritis stiffness
emerson.john in reply to Bosun RickMar 28, 2011. 6:30 AM
Horsefeathers, Bosun Rick. I do not doubt the arthritis benefits. WD40 is good for many things you won't find on the label.  There is no fish oil in WD40, that's another urban legend (a fish tale?).
Here's another WD40 use I have tried successfully: restoring noisy carbon potentiometers. I feel safer using Caig Deoxit, but WD40 sure seems to work as well.
KittyF says: Mar 28, 2011. 5:56 AM
this does help, I've used it before.
missyE says: Mar 28, 2011. 3:49 AM
yep i agree with Turboelf just send ya unwanted jewellery MY WAY much obliged ...i will pass it on to the SAVE A KITTY FUND honest...
missyE says: Mar 28, 2011. 3:38 AM
On behalf of the UK we can't handle the slightest bit of cold ...were a nation of
" it's too hot! it's too cold! moan, moan, moan :-p
MTherapist says: Mar 28, 2011. 3:21 AM
Baby oil is great as a cleaner and polisher of stainless steel. It shines my appliances up fantastic!
LeechTaMere says: Mar 28, 2011. 1:54 AM
Not sure there is an actual risk of frostbite at this temperature. I would say at least 30ºC below zero could get your flesh frozen. I got a frostnip (1st degree of frostbite) once, and it was probably around -40ºC. It may also depend on the metabolism, as diabetes can be a risk factor.
unionjack says: Mar 28, 2011. 1:37 AM
It's also great for removing finger marks from ceremonial swords and other polished metals, You wouldn't want behead someone with a contaminated sword would you, never know what they might catch.
Honora says: Mar 28, 2011. 1:12 AM
Also, if you get an insect in your ear e.g. a small moth, use oil to get it out. Water may cause the insect to swell. That said, in an emergency my partner squirted water in my ear to flush out a small moth. It flew out to live another day...
katzpawz says: Mar 27, 2011. 11:20 PM
Your suggestions are great and well thought out. Plus your writing style leaves me not only informed, but entertained as well. The photo of you attempting to guzzle baby oil cracked me up! Job well done! My only question is: where can I get a pretty blue necklace just like that one? What a beauty!!! If you're not a writer, I think you should start considering it - you're good!
Katzpawz
Tanamoril says: Mar 27, 2011. 8:24 AM
On behalf of the nation of Canada, I am obliged to inform you that -10 C is not cold.
You get down to -20 and then we'll talk.
That being said, this is a really good way to prevent windburn, much like a good lipbalm, only all ovah ya face.
SewLolita in reply to TanamorilMar 27, 2011. 11:12 PM
On behalf of Australians: .... 20C is pretty cold... i think my legs would drop off at -20C. :D but I suppose you get used to the weather wherever you are, eventually.
Super_pride1146 in reply to TanamorilMar 27, 2011. 12:10 PM
On behalf of Missouri, at least you all have predictable weather. One day we'll have rain, sun for half the next day, followed by snow, all ended nicely with tornado warnings, usually mixed with a little flooding.
KrasH44 in reply to Super_pride1146Mar 27, 2011. 7:42 PM
...or have 80 weather and five inches of snow two days later :)
mrustebakke in reply to TanamorilMar 27, 2011. 10:25 AM
I acknowledge that -20 C is cold, but I'm from Montana. -20C is nothing, it's not strange to have -40F with a wind chill of -70 or 80. That would be about -57C...
lbrewer42 in reply to TanamorilMar 27, 2011. 10:10 AM
On behalf of those who are native to the Great Lake snow belts, -20 Celsius also is not that cold. When you get down to around -30 F (-34 Celsius), and the humidity is high enough that your nose-flesh literally freezes when you try to breathe - this is when its starts to get cold. Standing on the shores of the Lake with it blowing in your face - while the temp is in this range also will make it hard for anyone to say they are "cold" ever again.
And as to wind chill - forget it... -30 windchill "feels like" is picnic weather when comparing it to actual mercury levels on the thermometer.
Now we need someone from Siberia to post and say, -30 is nothing b/c...
alfredhenriksen in reply to lbrewer42Mar 28, 2011. 2:49 AM
I agree. -10C is nothing. -20C is cold, maybe awful. I am glad that I have never experienced -30C! I tried to run in -21C, and I got more tired than usually. Applying vaseline or baby oil on the skin is useful if you're outside for a longer time, but won't these freeze or makes it worser on the longer term?
-10C can even feel comfortable or really awful, it depends on
the wind and humity. I recommend slowly acclimating yourself to the cold weather by going out (shortly) with little clothes, letting oneself freeze and becomes cold to make it easier for the body to accept colder climates. I usually do that at autumn. :)
lbrewer42 in reply to alfredhenriksenMar 28, 2011. 11:06 AM
From experience over many years, here is an even easier way to acclimate in just a few hours...
Go out in the cold all bundled up. Do some back breaking labor - like splitting firewood. As you get warmer start stripping off outer layers of clothing until, Keep doing this until you are in a T-shirt. When you get done with the work, go in the house and take a shower but do not try to cook yourself b/c the water feels good. Also do not have the heat in the house up so it is baking you. And, above all, do NOT use an electric blanket - these cook you all night and your body gets to expecting this kind of heat and then you cannot acclimate.
I used to go to school in SC and would come home during Christmas vacation to the Lake Erie snow belt. The first day I was home I did this very thing and, from then on, just had on a light jacket & hat while still home.
And if I was willing to write a book, one of the most intelligent sayings I have ever heard is an old indian saying: "white men get cold b/c they treat cold like an enemy instead of a friend." I have found this more and more true as I get older. Explore the meaning of this saying and it will be hard for you to be uncomfortable in cooler climates. I also find my immune system is stronger.
alfredhenriksen in reply to lbrewer42Mar 28, 2011. 1:46 PM
> "white men get cold b/c they treat cold like an enemy instead of a friend." .....
True, beautiful said. Thanks. The Western have lost a lot compared to the ancient tribes living in harmony with the nature. Look at the animals and birds, do you actually see somebody resisting the cold weather?
They seems to shrug it away, it seems that they're listening more to the body, it's older and more developed than the brain. Where does the resistance most people have comes from?
The modern world seems to have that attitude that everything unknown/uncomfortable is a enemy to one's welfare. I wonder why.
bryan3141 in reply to alfredhenriksenDec 11, 2011. 9:56 AM
Discomfort and pain are your body's way of telling you "something's wrong, fix it or I'll keep annoying you."
laferte in reply to TanamorilMar 27, 2011. 9:25 AM
I was going to comment on this, but you basicly nailed it!
-30 a couple of nights a year in these parts, colder happens... I was happy when my car started at -34 C .. :-)
unlock in reply to laferteMar 27, 2011. 4:51 PM
On behalf of the people of Hoth ...
lbrewer42 in reply to unlockMar 28, 2011. 11:07 AM
My pet wampa agrees
aekjysten in reply to unlockMar 27, 2011. 6:27 PM
LOL.
lukeyj15 in reply to laferteMar 27, 2011. 1:44 PM
Well try 45 C. For half a week on end.
HAL 9000 in reply to laferteMar 27, 2011. 11:24 AM
</pissing contest>
the_kcar in reply to HAL 9000Mar 28, 2011. 2:21 AM
Florida, here. 2004 saw hurricanes Charley, Frances, and Ivan. Mineral oil was great for getting camp gear unstuck during the blackout, keeping the native "no-see-ums" at bay, keeping the watermarks on the hardwood floors from gaining any permanence, and keeping various tools from becoming rusted and inoperable.
Vacation seasons often see vacationers trying to substitute baby oil for suntan oil or afterburn oil...which, by the way, is an excellent way to develop blisters in a sunburn - but not so great for "tan acceleration", contrary to vacationers' expectations. It's also great for getting the fans unstuck after a season of storage.
Baby oil is also excellent at removing Kool Seal from hirsute homeowners' forearms, as, yes, it breaks down the latex.
Yes, it also makes for a great bath oil - but only in moderation, and - as with all oils - always be certain to clean the oil out afterwards, as the tub can get quite slick for the shower-taker afterwards.
Kalindidur in reply to HAL 9000Mar 27, 2011. 7:56 PM
Try Northern alberta. Minus 50 withoutany windchill. and winnipeg where its regularly in the minus 40's
lbrewer42 in reply to KalindidurDec 11, 2011. 12:06 PM
And I thought the song said:
Almost Heaven... West Virgnia.
And here you have been hiding it up there all this time!
BTW - beautiful country up there!
mOrloff in reply to KalindidurMar 28, 2011. 6:58 AM
HA!!
I've got you ALL beat.
Try sitting on a warm sunny beach with a light breeze, your favorite drink, and favorite person/people.
Well...I'm not saying that's where I am, but it'd SURE be nice :)
lbrewer42 in reply to mOrloffDec 11, 2011. 12:10 PM
Seriously - I know most people like this... but to me that environment (except the people!) is one of the worst situations I can find myself in.
I much prefer if it never gets above 30F. I'm just different.
lvidal-1 in reply to TanamorilMar 27, 2011. 8:31 AM
Hear Hear Tanamoril!!!!
janettetsmith says: Mar 27, 2011. 6:18 PM
Ooh, no, no ... same reason as for eye makeup remover. This locks in the oils and produce blemishes, blackheads or whiteheads on some. :)
Turboelf says: Mar 27, 2011. 3:29 PM
Anyone got any broken or damaged gold, platinum or silver jewelry, that they're gonna throw away? Send it to me (I won't even insult you with a stupid valuation like some of the companies you see in commercials, I'll just keep it, if ya don't want it ;-) LOL
MsJaxFla says: Mar 27, 2011. 11:59 AM
Be sure you don't have Athlete's Foot first........ grin.
Turboelf in reply to MsJaxFlaMar 27, 2011. 3:24 PM
Be sure the last person who used the bottle didn't either ;-)
kea says: Mar 27, 2011. 11:34 AM
Being a tight wad I use cooking oil its a lot cheaper.
Great for your hands if u r doing concrete & out door work that may dry your hands.
Also good for the car dashboard as this stops the sun from spliting it.
Add some flour & it can clean & protect metal.
Thats my 10 cents. Cheers Kiwi
gingertux in reply to keaMar 27, 2011. 3:16 PM
Cooking oil is an organic substance that will attract insects and will dry sticky when used on heated surfaces such as waffle pans, etc. Mineral oil is non digestible and will not attract insects or 'bugs' and is therefore useful for coating cutting boards and wooden knife handles. It is also non flamable, which is why chemistry labs in schools use it as a heating bath for things to be safely heated at higher temps than in water.
cherylpeterson1 says: Mar 27, 2011. 9:20 AM
Be very careful using baby oil in the bathtub. It will be VERY slippery!!
Any bath oil can also be a big problem in the drain. It tends to clog drains. I would recommend running very hot water through the pipes as soon as you are out of the tub so the oil is flushed through the system.
Turboelf in reply to cherylpeterson1Mar 27, 2011. 3:16 PM
Lol! I can 2nd the 'be careful' part of this! I stayed in an apartment with 3 women for a few weeks, a number of years ago. Having a bath was a bit like Russian roulette (only with 5 bullets in the chamber!) - I ended up cleaning the bath out every time I wanted to take one!
dseitz says: Mar 27, 2011. 1:25 PM
Apply BEFORE painting to your face, arms and hands! It'll really help removing paint speckles after.
If your going to be doing heavy duty painting then use petroleum jelly instead.
Super_pride1146 says: Mar 27, 2011. 12:51 PM
Lol, for some reason "Before you throw away your diamonds and gold in frustration.." just got me in a giggle fit. Thanks!
NRen2k5 says: Mar 27, 2011. 12:29 PM
Baby oil is good for extending the life of leather jackets. Work a little bit of baby oil into the leather at the beginning or end of the season to keep it from drying, fading and cracking.
YakAttack says: Mar 27, 2011. 8:23 AM
It's true, I do prefer the smell of JP-5 in the morning! Thanks for keeping us laser-free in the skies and slip-free in the hanger, wilgubeast! Helicopters are dangerous enough without worrying about falling around them!
Great I-ble,
-Yac
(resident helo bubba)
aje127 in reply to YakAttackMar 27, 2011. 9:01 AM
I had a bucket of jp5 dumped on me once. The guys in the squadron weren't very impressed with the smell. nether were the guys at medical when I had to get checked out. but then, we were a c9 squadron. completely different. hahaha
YakAttack in reply to aje127Mar 27, 2011. 12:28 PM
Yuck! A whole bucket! Hope nobody was smoking nearby!
A bucket of baby oil definitely sounds/smells more pleasant (I assume--can't say I've ever seen a whole bucket o' baby oil).
MsJaxFla says: Mar 27, 2011. 11:55 AM
Also, it is a good idea to clean your 'already' free flowing drains once a month with about a cup of baking soda and followed with with a cup of white vinegar. Wait over night and pour a lot of hot water down the drain...... should be good.
If you think you need more help, try a hefty squeeze of a decent dish detergent and let it sit in the drain over night, then pour a bunch of hot water down the drain.... will help for sure. Do this one first and wait a day or so to use the vinegar and baking soda and only if you don't have a major problem.
alanstarkie says: Mar 27, 2011. 11:47 AM
Squirt this stuff using co2 onto a heated block to make a cool smoke machine.
ashmantech says: Mar 27, 2011. 8:12 AM
Also an economical stainless steel appliance cleaner.
pamgotcher in reply to ashmantechMar 27, 2011. 9:00 AM
baby wipes (which contain baby oil, I'm sure) are absolutely the best for this.
ashmantech in reply to pamgotcherMar 27, 2011. 10:53 AM
Sounds like a great way to pamper my Viking range (pun intended), but they're not just mineral oil (if they have any at all) which is what does the job so cheaply.
pamgotcher in reply to ashmantechMar 27, 2011. 11:13 AM
LOL, yes, ashmantech - mineral oil will be much cheaper than baby wipes. I like the fact that baby wipes remove all the oil that I get when I fry, etc, and leave the stainless looking like new with no fingerprints (and are already on a towelette). I actually use it on everything stainless in the kitchen, even my coffee maker. But, baby oil would definitely be cheaper.
Warren.Sensei says: Mar 27, 2011. 11:09 AM
Apply directly to the foreh.... um.. belly...?
zuclo says: Mar 27, 2011. 11:02 AM
I find the mineral oil is cheapest as baby oil for cleaning and maintainiong my swords and knives
mrmuskrat says: Mar 27, 2011. 10:52 AM
As a kid, my mom and grandma would use warm olive oil to deal with earwax and ear aches.
sdtacoma says: Mar 27, 2011. 10:39 AM
Why would you use a petroleum based product to remove latex (water-based) paint? That seems counter intuitive to me; one of the benefits to using latex paint is its easy clean-up. Some warm soapy water and a scrub brush should do the trick just fine.
I worked in a paint store for about 15 years, selling Benjamin Moore paint! Love seeing it in the photo :)
SWV1787 says: Mar 23, 2011. 4:24 PM
Clearly that is a man and not a pregnant woman the shirt buttons are on the wrong side to be a woman's shirt...
Lots of interesting stuff here I never would have thought. I will defiantly try the band-aid tip as every time I donate blood the band-aid they give we practically de-hairs my arm... that's the most painful part
phoglite in reply to SWV1787Mar 27, 2011. 10:02 AM
Heh.. see all the photos of the guy? shirt look familiar? :-)
SpaceRat in reply to SWV1787Mar 27, 2011. 7:32 AM
My wife always wore my shirts when she was pregnant.
doo da do in reply to SWV1787Mar 24, 2011. 7:24 AM
Could be a cross dresser, some folks do lots of unique things, look at all the different instructables.
mooster says: Mar 27, 2011. 9:22 AM
Baby oil removes beach tar very well.
lr10cent says: Mar 27, 2011. 8:41 AM
Hmm... Didn't realize the previous comment would show up at the front. Previous comment was for step 8.
Hadn't known about some of those, may try with paint or bandaids.
Another use is when you're sharpening something with an oilstone. Works nicely and price is right, although of course there's always the bad smell of baby oil. An alternative for some of the uses given here is mineral oil from the drugstore. No stench! More viscous, though.
If baby oil acts like mineral oil when used in a bath, it will make the bottom of the tub slippery. Beware. Easy to clean off, though.
lr10cent says: Mar 27, 2011. 8:37 AM
You can use a foam band aid to keep your nose warm. Works great for cyclists with glasses. And then use the baby oil to help get it off, I suppose.
Big Tattoo says: Mar 27, 2011. 8:32 AM
Wipe down shower curtains to help prevent soap buildup.
BGreenHVAC says: Mar 27, 2011. 8:30 AM
I used to work in the jewelry business. Pearls will dry out and lose it's luster. You rub a small amount of baby oil on them about once every 6 months. Your natural skin oils are good for the pearls, but your natural body salts are not. You can rinse them off with water only (DO NOT use cleaners or detergents, just water) then rub a very small amount of baby oil.
The pearls are pourous and will absorb cleaners, detergents, and other things that can stain pearls. The baby oil will prevent or at least reduce the risk of the pearls getting stained.
roccopeterbilt says: Mar 24, 2011. 11:48 AM
In addition to using it after a shave, it works great in place of a shaving cream as well. Especially if you are prone to razor bumps and the like. I'd be sure to wash well after if you are using it on your face though, as I would think this could cause breakouts.
rallen71366 in reply to roccopeterbiltMar 27, 2011. 7:03 AM
I regularly use baby oil *gel* as a lube on my razor blades to extend their usable life. I've actually been able to get a comfortably smooth shave from a normal triple blade razor for 4 months(!!) because I put a single drop on the blade edges before I shaved. I did learn that it immediately dissolves the aloe vera "lube strip" that they put on the blade cartridge, so wait until that's gone to extend the life of your blade.
P.S. I'm not sporting extremely coarse, stiff, facial hair, but it still does a number on a razor.
Biohazard1194 says: Mar 25, 2011. 1:44 PM
You forgot my personal favorite, spread a nice little puddle on your tires and do a burnout. Gets a nice smoke going ;P
eight in reply to Biohazard1194Mar 27, 2011. 6:39 AM
Squirt some in your mate's car's exhaust pipe.
If you can get most of a bottle in there, his car will smoke like there is no tomorrow !
Neon Panda says: Mar 27, 2011. 3:59 AM
I actually went out and bought some baby oil after seeing this Instructable and tried it for the cracked heels step and it works brilliantly =] It's also the best thing to take make-up off with!
Thanks for posting!
X
MicioGatta says: Mar 27, 2011. 3:57 AM
#16 Softens FIMO :)
Kaelessin says: Mar 24, 2011. 10:28 AM
Perhaps that equation at the end is the reason it's called "Baby Oil"
;P
pelobest in reply to KaelessinMar 25, 2011. 6:43 PM
LoL ;)
bill z says: Mar 25, 2011. 2:20 PM
Don't forget the water bed missing sheets with someone wearing wool socks for traction. Oops maybe that's a little T.M.I.
Treasure Tabby says: Mar 24, 2011. 2:06 PM
Also great for making a lava lamp. ;)
Also great for kitties who are suffering with ear mites. Ask vet for instructions.
graywoulf says: Mar 24, 2011. 1:10 PM
One of the best dressings for automotive vinyl dashes and other interior surfaces other than seats and steering wheels, Runs circles around that Armor*** stuff without drying out the vinyl surface and causing premature drying and cracking. If the vinyl surface is really dry, it may take repeated applications to reach a saturation point in which at that time all you need to do if buff the surface with a dry cloth to a shine. I regularly use it or either Formula 2001 vinyl protectant.
17hmr243 says: Mar 24, 2011. 11:31 AM
half b.oil
half dettol
splash eucalyptus
grate mozzie repellent killer.
puyunet says: Mar 24, 2011. 11:22 AM
You can use baby oil to clean and shine stainless steel furniture.
martzsam says: Mar 24, 2011. 11:11 AM
Also add Yoyo lube.
markstutzman says: Mar 24, 2011. 7:43 AM
Good ideas, but baby oil smells terrible. You can get USP grade mineral oil in any pharmacy (or even supermarkets and other places that sell drugstore-type stuff). It's sold as a laxative, and contains no scent. I suppose if you must have it scented, you could add a few drops of an essential oil, like lavender, which would smell much better than baby oil.
My #1 use for mineral oil is combined with beeswax, to create a food-safe finish for wooden cutting boards, wooden spoons, etc. Simply melt 1 part beeswax into 4 parts mineral oil (use a double boiler, so you don't set the mixture on fire), and when it cools, you have a creamy paste which rubs into wood easily. You can get beeswax in craft stores, by the candle-making supplies
dirtdealer says: Mar 23, 2011. 9:16 PM
Works well with a q-tip to clean out a belly button, particularly if you have an inny belly button that collects lint and ick.
CaseyCase says: Mar 23, 2011. 6:03 PM
#14 Removes tar from skin and hair. Learned this one while a student surfing at the Univ. of CA--Santa Barbara (Go Gauchos!)
#15 Removes residual price sticker and label adhesive from non-porous surfaces.
zazenergy says: Mar 23, 2011. 3:57 PM
Another classic.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
