Step 4: Remove earwax
For the temporarily hearing impaired, there's an easy home remedy to handle that waxy buildup: baby oil!
While laying on your side or tilting your head so your affected ear is up, drop five drops of baby oil inside (warmed, if you really want to dissolve the mess) your ear. Let it stay for long enough to dissolve some of the wax, then let the oil drain out onto a clean towel or into the sink. A small amount of warm water can be used to dislodge any last bits with a small bulb or needle-less syringe.
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
All that to say: if you find out what cleaned out the honey = I'd sure like to know! :*)
http://www.hc-sc.gc.ca/hl-vs/iyh-vsv/med/ear-oreille-eng.php
I have personal experience with ear candles and can say honestly that the draft created does remove wax from my ears. Once, out of curiosity, I purchased some just to unwind them and see if all the junk that I was seeing at the end of a session had already been snuck into the ear candle. None of the wax that appeared to have been removed from my ears was pre-existing in any of the four I disemboweled.
Do I think they are dangerous? I think anything involving fire has the potential to do great harm. The candles I've used do not contain excess wax, I know this because there have never been wax droplets after/during their burning. When I run the tip of my finger on the inside of the wide end of an ear candle I feel the material only because the wax coating is on the outside.
Best method? Hydrogen peroxide + needle-less syringe. The hp will break up the wax, and water from the syringe flushes it out. (You don't need a lot of water pressure. Nor do you want it. Unless you want to see if you can brainwash yourself via your auditory canal.)
This is another type of syringe without a needle in it...in fact, the way this syringe is made, there is no way a needle can be attached normally. I'm not for sure, but I think you can buy Catheter tipped syringes at your local drug store...check with the Pharmacist for sure.
I know this because I use these every day.
BUT, any syringe that does not have a needle will do just fine.
