Step 6: Bath oil
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Any bath oil can also be a big problem in the drain. It tends to clog drains. I would recommend running very hot water through the pipes as soon as you are out of the tub so the oil is flushed through the system.
If you think you need more help, try a hefty squeeze of a decent dish detergent and let it sit in the drain over night, then pour a bunch of hot water down the drain.... will help for sure. Do this one first and wait a day or so to use the vinegar and baking soda and only if you don't have a major problem.
