iImage Information
Everyone knows Powerbooks have terrible wi-fi reception. Unfortunately, only 15" and 17" Powerbooks facilitate adding your own external antenna. With just a few quick cuts you can modify a 12" Powerbook to take an external antenna as well.
Step 1Size up your existing antenna hookup
iImage Information
Airport Extremes use the MC Card connector. You could use any antenna you want as long as you get the right pigtail for it (and the impedance matches, which I think is 50 ohms here). I opted for a 5.5db flat blade antenna ($15), but there are many other options over here:
http://sharperconcepts.zoovy.com/category/24ghzantennas/The connector coming off the existing internal antenna is going to have to be pushed back into the notch it comes out from. You'll quickly realize it doesn't go back far enough and obstructs the little metal flap from closing back. We'll cut part of that flap off.
Thats what Im doing now - Now that Ive got a longer cable!! not the 1m patch used for setting up
The $10 USB wireless stick:
- is slower than the internal wireless
- sticks out
- is shitty hardware that probably has shitty drivers...and escaping from that is the whole point of getting a Mac.
