12 Gage Zipper Pulls
2,752
49
4
Published
Introduction: 12 Gage Zipper Pulls
About: Awesome Gear I've designed myself.
Here’s a unique way to get a handle on a zipper while showcasing something you like. To remove the plastic housing from the brass heat it with a heat gun until the plastic is soft. The shell will slide right off with a little encouragement. Next drill a small hole in the shell, run some cord through it, and tie a knot to secure it. Follow step 7 from DIY cufflinks to set a picture in the opening of the shell. The image shown belongs to an awesome art gallery in Kentucky.
Use an expended cartridge. That means a shell that has already been shot. Do not under any circumstances use live ammo.
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    4 Discussions
    Can anybody off any EASY suggestions on how to remove the primer stem on the inside of the 12g brass base without removing it?
    I don't understand why you insist to use only expended cartridges... Using live ammo would make the manufacturing process much more fun and interesting (although a little bit unpredictable). And moreover, the heat method of cartridge disassembling would be much faster and efficient.
    ;-p
    BTW: Your DIY jewellery is really, really great!
    You could glue a button compass in the brass base. It will not affect the compass and would look pretty cool.
