Introduction: 12-Hour Digital Clock Using ARM Cortex-M4
Picture of 12-Hour Digital Clock Using ARM Cortex-M4
This is a breadboard based project which uses ARM Cortex-M4(Texas Instruments EK-TM4C123GXL) to make a 12-Hour Digital Clock. The output of 12-Hour Digital Clock can be obtained on 16x2 LCD Screen.
We can set and modify time using two Toggle Switches. Two Toggle Switches are used to adjust the Hours and Minutes. During the setting of Hours and Minutes or the normal operation of 12-Hour Digital Clock, an on boardRGB LED continuously shows the status of ARM Cortex-M4(Texas Instruments EK-TM4C123GXL).
This RGBLED continuously blinks with one second period to show different active modes of 12-Hour Digital Clock.The whole circuit is powered by +5V(VBUS) and +3.3V of EK-TM4C123GXL.
.bin file of c99 code is attached with the provided link at the end of this tutorial. .bin file can be uploaded to the microcontroller using LM Flash Programmer.
Step 1: Requirements
The following things are required to get this project done:
1- Texas Instruments EK-TM4C123GXL
2- Potentiometer (eg 5K)
3- LCD 16x2
4- Two Toggle Switches (3-Pins)
5- LM Flash Programmer (software on PC)
=> If you don't know how to use and install LM Flash Programmer, then please check out my previous Instructable, or click on the following links:
Downloading LM Flash Programmer
Upload .bin or .hex File Using LM Flash Programmer
Step 2: Pin-outs & Wiring
Picture of Pin-outs & Wiring
The Pin-outs & Wiring of ARM Cortex-M4(Texas Instruments EK-TM4C123GXL) and other peripheral is attached with this step and also given following:
TM4C123GXL => LCD
VBUS => VDD or VCC
GND => VSS
PB4 => RS
GND => RW
PE5 => E
PE4 => D4
PB1 => D5
PB0 => D6
PB5 => D7
+3.3V => A
GND => K
TM4C123GXL => Potentiometer
VBUS => 1st pin
GND => 3rd pin
Potentiometer => LCD
2nd pin => Vo
=> You can set contrast using Potentiometer
TM4C123GXL => Toggle Switch 1
VBUS => 1st pin
GND => 3rd pin
PA5 => 2nd pin
TM4C123GXL => Toggle Switch 2
VBUS => 1st pin
GND => 3rd pin
PA6 => 2nd pin
Step 3: Upload the .bin File
Picture of Upload the .bin File
Upload the attached .bin file with this step to ARM Cortex-M4(Texas Instruments EK-TM4C123GXL) using LM Flash Programmer.
Step 4: Get Your Output
After uploading .bin file to ARM Cortex-M4(Texas Instruments EK-TM4C123GXL), you can get your 12-Hour Digital Clock output on 16x2 LCD Screen.
Also, you can set or modify Hours and Minutes using two Toggle Switches. An on board RGBLED continuously shows the status of ARM Cortex-M4(Texas Instruments EK-TM4C123GXL).
About This Instructable
190views
1favorite
License:
Bio: I'm Electrical Engineering Student, Coffee Lover, Automated System designer, Programmer and Security System Designer.
More by Adeel Ijaz:Traffic Light Controller Using ARM Cortex-M4Traffic Light Controller Using ArduinoLaser Tripwire Using ARM Cortex-M4
Add instructable to:
