12 Volt Battery Hack! You'll be Surprised...
 by Kipkay
Featured
Save $40 with this easy to do hack that takes less than a minute! Pay attention to the battery type as that is important.
This can also be done with a 9 volt battery!
Step 1: It's so EZ!!
I picked up a couple of A23 Energizer Batteries at Wal-Mart for $1.88. What a deal!! If you look carefully at an A23, there is a split in the label/housing. I used a small screwdriver and peeled away the housing revealing a piece of paper.
1-40 of 367Next »
NerdofSteel says: Dec 14, 2009. 10:35 PM
I just attempted this with a Duracell MN 21/23 12v battery and this trick works for it as well. As for the button cells themselves, they have "LR932" written at the top of them. Thanks for the cool tip Kipkay! :)
frenzy in reply to NerdofSteelJun 28, 2010. 9:44 AM
This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
Thanks for using instructables!
http://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Mem/
eyesee says: Dec 21, 2012. 1:24 AM
Creative
jschap1 says: Jul 11, 2012. 1:10 PM
What's the difference between an A23 battery and a AA battery?
qazxsw21000 in reply to jschap1Dec 20, 2012. 9:39 PM
Replying to old posts, FTW.
A23 is small and 12V for certain cameras.
AA is for general purposes and are 1V5 (1.5V)
toezar00 says: Aug 29, 2012. 9:40 PM
Can u give tips on more little batteries in batteries?
I would like to know.
Awesome!
pipsqueakboy says: Jul 13, 2012. 5:17 PM
Okay, so now im confused. before i open a battery and possibly scar myself with battery acid, Is this real?
ktalex says: Sep 22, 2009. 10:52 AM
lol u can get like 8 of those batteries at the 99cent store. good hack though?
doo da do in reply to ktalexFeb 18, 2012. 6:52 PM
Be weary of the dollar store usually they are out dated or very bad performance. Doodado
KingOfCatfish in reply to ktalexOct 4, 2010. 9:07 PM
This is so true! I saw those at the 99 Cent Only Store a couple of days ago and bought a pack, I'm so going back for more!!!
nepheron in reply to ktalexNov 21, 2009. 11:19 AM
The trouble with dollar store batteries is that they work awfully. The voltage on those is not standard 1.5v...and they only hold a charge for a matter of minutes.
KingOfCatfish in reply to nepheronOct 4, 2010. 9:08 PM
The ones that I bought from 99 Cent Only Store are holding up fantastically!!
grharder says: Feb 16, 2012. 7:30 PM
Just tried this the other day (2-16-12) and it was still as described here. It was a generic brand though, so that may make a difference.
minimoto says: Jul 13, 2009. 9:40 PM
LISTEN UP THIS ONLY WORCKS WHITH ENERGISER. I opened up a 1.5v battery up and got 8 button battery's. Than I opened up a 9v battery and found 6 AAA batters inside. Last I opened up a 6v heavy duty battery up and found 32 AA or AAA I forgot !!!!!!!!
sbeltz in reply to minimotoOct 31, 2011. 12:26 PM
HD 6V batteries have 4 F cell batteries. THERE ARE NO AA BATTERIES in 6V batteries.
account3r2 in reply to minimotoOct 16, 2010. 2:40 PM
9v=6AAAA not AAA
account3r2 in reply to minimotoOct 16, 2010. 2:39 PM
32AA or 32 AA batteries as in there are thirty-two batteries
sharlston in reply to minimotoNov 2, 2009. 8:41 AM
no a lantern battery has around 4 d cells
cjmproduction in reply to minimotoAug 14, 2009. 7:39 PM
wrong 1.5 battery is actually a cell not battery 9 volt has 6 AAAA cells in it...(1.5v each) 6 volt has 4 large cells...(1.5v each) if a 6 volt had 32 AA or AAA batteries it would be 48 volts
minimoto in reply to cjmproductionDec 8, 2009. 7:49 PM
shosh up alright thats just what i found and the 6v heavy duty has so got that many batteries otherwise it would last 5min in a torch
account3r2 in reply to minimotoOct 16, 2010. 3:16 PM
do you have a camera for pictures?
Colonel88 in reply to cjmproductionNov 3, 2009. 5:40 PM
If it is wired in parallel then it is more current not voltage so it will be like 6 volts and a lot more mAh. But it does have 4 D cells...
mikerice126 in reply to cjmproductionNov 1, 2009. 8:12 AM
minimoto right
cjmproductoin partial credit. :)
32 AA or AAA *in series* would be 48 V. (32 * 1.5 = 48). However, 8 *parallel* banks of 4 AA or AAA in series would be 6 V at 8 times the current (amps).
(4 * 1.5) = 6, 8 times. Series connection adds the voltages; parallel connection adds the currents.
*                    * is 6 v, i amps
*                    * is 6 v, 8i amps
brocknessmonster27 in reply to mikerice126Apr 15, 2012. 9:10 AM
what do you mean
dacker says: Oct 9, 2011. 4:30 PM
While it is cool there are button batteries stacked inside the A23 casing, your cost comparison is off. it is like comparing tangerines and oranges.
The Eveready Energizer A23 is clearly marked "Alkaline" whereas you compared it to a single silver-oxide button battery. Two different chemistries with big performance differences and big price differences.
busterbuster18724 says: Sep 23, 2011. 10:18 PM
i tryed a Duracell MN 21/23 12v but acid came out :(
jumpingcat says: Aug 11, 2011. 6:06 AM
yay it works
aweaver4 says: Jul 3, 2011. 7:14 PM
Apparently Energizer saw this instructable and now have "tamper proof" metal tubes to encase the little batts. It has a solid bottom on the positive side and is rolled over the negative end, which is obviously a "watch" battery.
baven says: May 23, 2011. 9:21 AM
I´ve just opened a Sony 12v 23A battery and found this. Sorry for blurry picture I´ve taken it with my phone camera.
WendyLD3 says: Dec 30, 2010. 7:21 PM
does it work on chinese energizers?
account3r2 says: Oct 16, 2010. 3:19 PM
why are there A23 12v batteries when there are 23A 12v batteries? 23A are smaller.
account3r2 says: Oct 16, 2010. 2:27 PM
it would be bad if stores found out... ...probably
Cheezpaper says: Aug 26, 2010. 7:00 PM
Does this only work for this specific kind of battery, or can it be found in other more common batteries like AA or AAA batteries?
camiller in reply to CheezpaperSep 30, 2010. 1:16 PM
No, AA and AAA cells are a single cell unto themselves and are each 1.5 volts. For cylindrical alkaline batteries with a voltage that is a multiple of 1.5 volts it is likely (but not absolutely) true that it is a stack of 1.5 volt cells inside.
warmario says: Jul 19, 2009. 2:05 PM
Are the batteries inside the A23 LR41's?
chi chi chippy in reply to warmarioSep 12, 2009. 11:09 AM
i think there lr44
mikerice126 in reply to chi chi chippyNov 2, 2009. 3:44 AM
Not LR44.
clibanarius in reply to mikerice126Dec 13, 2009. 6:36 PM
 Just opened my first A23 (Energizer, from Target, $4.14 for 2-pack); it had eight button cells, just as advertised. Cool! The batteries Kipkay matched them with are LR45s; elsewhere I've seen them referred to as LR932s, about which I can find no data. I was kinda hoping they were LR41, so I could use them in some finger flashlights, but they seem to be a mm or so too wide.
Paulkartking25 says: Nov 21, 2009. 4:40 PM
this is awsome
BucketBasher says: Sep 9, 2009. 7:09 AM
I have a question: Does anybody know if the info from this instructable is still usable? You know, if you can still find some A23 Energizer batteries a a relatively low price? Cause I noticed the date this was published is August 18, 2007, which was 2 years ago and the batteries could have changed since then.
1-40 of 367Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
