3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
12 Volt Battery Hack! You'll be Surprised...
12 Volt Battery Hack! You\
Save $40 with this easy to do hack that takes less than a minute! Pay attention to the battery type as that is important.
This can also be done with a 9 volt battery!
Step 1It's so EZ!!
It\
I picked up a couple of A23 Energizer Batteries at Wal-Mart for $1.88. What a deal!! If you look carefully at an A23, there is a split in the label/housing. I used a small screwdriver and peeled away the housing revealing a piece of paper.
363 comments
1-40 of 363next »
Dec 14, 2009. 10:35 PMNerdofSteel says:
I just attempted this with a Duracell MN 21/23 12v battery and this trick works for it as well. As for the button cells themselves, they have "LR932" written at the top of them. Thanks for the cool tip Kipkay! :)
Jun 28, 2010. 9:44 AMfrenzy says:
This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
Thanks for using instructables!
http://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Mem/
Sep 22, 2009. 10:52 AMktalex says:
lol u can get like 8 of those batteries at the 99cent store. good hack though?
Feb 18, 2012. 6:52 PMdoo da do says:
Be weary of the dollar store usually they are out dated or very bad performance. Doodado
Oct 4, 2010. 9:07 PMKingOfCatfish says:
This is so true! I saw those at the 99 Cent Only Store a couple of days ago and bought a pack, I'm so going back for more!!!
Nov 21, 2009. 11:19 AMnepheron says:
The trouble with dollar store batteries is that they work awfully. The voltage on those is not standard 1.5v...and they only hold a charge for a matter of minutes.
Oct 4, 2010. 9:08 PMKingOfCatfish says:
The ones that I bought from 99 Cent Only Store are holding up fantastically!!
Feb 16, 2012. 7:30 PMgrharder says:
Just tried this the other day (2-16-12) and it was still as described here. It was a generic brand though, so that may make a difference.
Jul 13, 2009. 9:40 PMminimoto says:
LISTEN UP THIS ONLY WORCKS WHITH ENERGISER. I opened up a 1.5v battery up and got 8 button battery's. Than I opened up a 9v battery and found 6 AAA batters inside. Last I opened up a 6v heavy duty battery up and found 32 AA or AAA I forgot !!!!!!!!
Oct 31, 2011. 12:26 PMsbeltz says:
HD 6V batteries have 4 F cell batteries. THERE ARE NO AA BATTERIES in 6V batteries.
Oct 16, 2010. 2:40 PMaccount3r2 says:
9v=6AAAA not AAA
Oct 16, 2010. 2:39 PMaccount3r2 says:
32AA or 32 AA batteries as in there are thirty-two batteries
Nov 2, 2009. 8:41 AMsharlston says:
no a lantern battery has around 4 d cells
Aug 14, 2009. 7:39 PMcjmproduction says:
wrong 1.5 battery is actually a cell not battery 9 volt has 6 AAAA cells in it...(1.5v each) 6 volt has 4 large cells...(1.5v each) if a 6 volt had 32 AA or AAA batteries it would be 48 volts
Dec 8, 2009. 7:49 PMminimoto says:
shosh up alright thats just what i found and the 6v heavy duty has so got that many batteries otherwise it would last 5min in a torch
Oct 16, 2010. 3:16 PMaccount3r2 says:
do you have a camera for pictures?
Nov 3, 2009. 5:40 PMColonel88 says:
If it is wired in parallel then it is more current not voltage so it will be like 6 volts and a lot more mAh. But it does have 4 D cells...
Nov 1, 2009. 8:12 AMmikerice126 says:
minimoto right
cjmproductoin partial credit. :)
32 AA or AAA *in series* would be 48 V. (32 * 1.5 = 48). However, 8 *parallel* banks of 4 AA or AAA in series would be 6 V at 8 times the current (amps).
(4 * 1.5) = 6, 8 times. Series connection adds the voltages; parallel connection adds the currents.
*                    * is 6 v, i amps
*                    * is 6 v, 8i amps
Apr 15, 2012. 9:10 AMbrocknessmonster27 says:
what do you mean
Oct 9, 2011. 4:30 PMdacker says:
While it is cool there are button batteries stacked inside the A23 casing, your cost comparison is off. it is like comparing tangerines and oranges.
The Eveready Energizer A23 is clearly marked "Alkaline" whereas you compared it to a single silver-oxide button battery. Two different chemistries with big performance differences and big price differences.
Sep 23, 2011. 10:18 PMbusterbuster18724 says:
i tryed a Duracell MN 21/23 12v but acid came out :(
Aug 11, 2011. 6:06 AMjumpingcat says:
yay it works
Jul 3, 2011. 7:14 PMaweaver4 says:
Apparently Energizer saw this instructable and now have "tamper proof" metal tubes to encase the little batts. It has a solid bottom on the positive side and is rolled over the negative end, which is obviously a "watch" battery.
May 23, 2011. 9:21 AMbaven says:
I´ve just opened a Sony 12v 23A battery and found this. Sorry for blurry picture I´ve taken it with my phone camera.
Dec 30, 2010. 7:21 PMWendyLD3 says:
does it work on chinese energizers?
Oct 16, 2010. 3:19 PMaccount3r2 says:
why are there A23 12v batteries when there are 23A 12v batteries? 23A are smaller.
Oct 16, 2010. 2:27 PMaccount3r2 says:
it would be bad if stores found out... ...probably
Aug 26, 2010. 7:00 PMCheezpaper says:
Does this only work for this specific kind of battery, or can it be found in other more common batteries like AA or AAA batteries?
Sep 30, 2010. 1:16 PMcamiller says:
No, AA and AAA cells are a single cell unto themselves and are each 1.5 volts. For cylindrical alkaline batteries with a voltage that is a multiple of 1.5 volts it is likely (but not absolutely) true that it is a stack of 1.5 volt cells inside.
Jul 19, 2009. 2:05 PMwarmario says:
Are the batteries inside the A23 LR41's?
Sep 12, 2009. 11:09 AMchi chi chippy says:
i think there lr44
Nov 2, 2009. 3:44 AMmikerice126 says:
Not LR44.
Dec 13, 2009. 6:36 PMclibanarius says:
 Just opened my first A23 (Energizer, from Target, $4.14 for 2-pack); it had eight button cells, just as advertised. Cool! The batteries Kipkay matched them with are LR45s; elsewhere I've seen them referred to as LR932s, about which I can find no data. I was kinda hoping they were LR41, so I could use them in some finger flashlights, but they seem to be a mm or so too wide.
Nov 21, 2009. 4:40 PMPaulkartking25 says:
this is awsome
Sep 9, 2009. 7:09 AMBucketBasher says:
I have a question: Does anybody know if the info from this instructable is still usable? You know, if you can still find some A23 Energizer batteries a a relatively low price? Cause I noticed the date this was published is August 18, 2007, which was 2 years ago and the batteries could have changed since then.
Nov 21, 2009. 11:15 AMnepheron says:
Actually I meant meijers, not wall mart!
Nov 21, 2009. 11:14 AMnepheron says:
I just picked up a pack of A23's for $3.45 at wall mart.
Nov 3, 2009. 5:42 PMColonel88 says:
FYI in Target i found em for like 4-5$ for a pack of 2 in the battery section. The battery section is near the elctronics thing
Just bought two-pack of A23 for less than $4 at Wal-Mart.
Sep 9, 2009. 7:15 AMBucketBasher says:
"at" a relatively low price. P.S. Since seeing this Instructable, I have only looked at 1 WalMart for those A23s and couldn't find any. I don't mean any criticism by my previous ?, I just would like to find out where I can get some A23s, That's all.
1-40 of 363next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2394
Author:Kipkay(Kipkay Videos)
Tinkerer, hackster and prankster. Hit me up on Facebook: http://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
