loading
Step 11: (8) Mount it on a photographic tripod
There are two advantages from doing this: a) The photo-tripod is more simple and stable and b) I carry it most of the time in the car anyway for the camera.
The modification was simple. I used a piece of scrap aluminium plate and substituted the two screws of the dovetail base with new ones terminating on the plate.
The handle of my tripod helps me orient the scope with small movements. With a little practice one can regulate this fairly well even in large magnifications.
<p>I just bought a cheap one and find your instructions very useful, will try with the tripod first. Thx a bunch!</p>
<p>I am glad that this instructable was helpful. </p>
thanks, I came to know were the things goes wrong
If I have two telescopes and one has the smaller lens holder and one has the larger one. Can I swap the smaller lens holder for the larger one? The telescopes I have are both mirror reflectors. One is a 4&quot; the other I believe is a 5?<br> <br> Sorry I can't be more specific as I can't get to either right now as the weather just went bad here and I keep them both in my trailer in my back yard (it is <a href="http://img153.imageshack.us/img153/5933/p1010021id.jpg" rel="nofollow">a long way away</a>). I have <a href="http://i.imgur.com/IpCXj.jpg" rel="nofollow">a picture of the one</a> (I buy a lot of junk at garage sales) I want to put the bigger focusing mechanism on. But no picture of the one I want to pull the focusing mechanism off.<br> <br> They look a lot alike to me except for the diameters. You know the flanges that connect to the tubes, rack and pinion etc. But is there anything that would stop me from doing something like this that I should know about?<br> <br> Mainly I want to change them because I have the lenses for the larger diameter focuser, but not for the smaller one. Thanks.
By &quot;lens holder &quot; I think you are referring to the focuser.<br><br>If you mean can you swap the smaller focuser for the larger one, it is possible, but you would need to make sure that the secondary mirror (the small oval diagonal mirror that reflects the lightpath into the focuser/eyepiece) is large enough to take advantage of the larger eyepiece diameter.
I want to swap the bigger one I have lenses for for the smaller one I don't have any lenses for. I'm not sure but the mirror might go with the whole focuser unit. Though the arm it is attached to might be too short, forcing me to modify it. Would be a tricky weld.
You are probably referring to the 45 angle secondary mirror. If the focuser is welded on it you should remove the complex and separate it. Probably a Dremmel with a ceramic disc would do depending on the thickness. Otherwise remove the rack and pinion and the internal tube of the focuser and make another support yourself. <br>I do not know the condition of you 4&quot; criterion. However if the two mirrors are not oxidized or scratched you could restore it. The tube can be cleaned. Forget about the tripod. If the mirrors have even the minimum damage then you can forget about it.
I'm sure I can find <a href="http://www.instructables.com/file/F63VEA6GKGL68FD/?size=ORIGINAL" rel="nofollow">something</a> to cut&nbsp; the little mirror off. The Tasco has an intact tube cap on it so it should be in fairly good shape. The Criterion looks pretty done to me. Maybe if it was the the only scope I had it'd be worth fixing, but it isn't.<br> <br> The tripod will be another issue I need to address. But I figure I'd better get a working scope first before I worry about it.<br> <br> I just remembered I have another telescope and it may even have the right diameter lenses with it. It is complete in the box so I'm not as keen about breaking it apart. Though when I used it I can't say I was too thrilled about it.<br> <br> It is a Meade Jupiter model #60AZ-M I think it has the skinny lenses. I pick a lot of junk up at garage sales. Sometimes I forget what I have. At least I could borrow a lens from that and see what the Tasco is like with it. Can I do that?
Of course you can . This Meade is a 60mm refractor. Probably this has the standard 0.965&quot; size eyepieces and as I saw it has a 2 5mm, 12.5mm, 4mm and probably a Barlow 2x. Test them all. If you cannot focus, this will be because the focuser may need to approach the secondary mirror more. Do not expect much in terms of quality but it is a start.
Great to know thanks! It might tell me if working on the Tasco is worthwhile or not. I can't remember what I didn't like about the Meade, I think it was at higher magnifications where it really didn't work. A common failing I've read about with low quality equipment.
Measuring from the photo the internal diameter of this focuser is probably 0.965&quot;, an older size. Do not bother at all to find eyepieces for this, they have lower performance and are harder to find, you cannot set up a collection with this diameter. The standard sizes are 1.25&quot; and 2&quot; reserved mostly for larger catadioptric scopes. So 1.25&quot; is what you should be looking for. Check the eyepieces of the other scope on this. The standard mirror diameters are 4&quot;,4.5&quot;,5&quot;,6&quot;,8&quot; and so on.<br><br>From the photo I deduce that the this scope is about F5 to F6 (ratio of mirror diameter to length). A possible problem when dealing with short F numbers is that when you change the focuser you may need to approach the secondary mirror more in order to focus, that is to move the focuser more into the tube (a few mm). I have met this problem. The solution is to shift the rack lower , or to change/modify the internal tube of the focuser. It can be solved. <br><br>The important thing is to decide which telescope is actually better. This is what I would do. I would remove the focuser from this one and substitute it with a temporary plywood base with a hole and a tube PVC , plastic cardboard or whatever to hold the eyepieces. Then I would setup both scopes a clear night and perform these three tests:<br><br>1. Compare the image with the same eyepiece (10-12mm, ~100x). Check for diffusion , chromatic distortions in the center of the field for both. Focus and defocus to see which distorts less (usually the larger F).<br><br>2. Find the field of view. Select a middle eyepiece 10-12mm , center a star and try to determine when distortions start to appear as the star moves to the edge. The ratio of the two diameters is the FOV number. 80% or larger is good.<br><br>3. Try to resolve double stars. A good test is the double-double epsilon in Lyrae (high during summer). It is a pair that can be resolved with binoculars but each of them is a pair distant 2.3 and 2.6 arcsec apart. It is a standard test for telescope evaluation. Your 4&quot; with a 1.2&quot; arcsec limit should be able to resolve this easily.<br><br>The size of the mirror is not the only criterion. There are also other things to consider, the quality of the mirror coating and the quality of the mounting (tripod or single pilar). Learn to use the equatorial mount. <br><br>Thry to find the manuals or more information on the specific scopes. Check the &quot;Sky and telescope&quot; for more information for Newtonians. There you ill find how to collimate the mirror , another thing to check.<br><br>Spend a year or so with the eyepieces you have and there star thinking about better ones. <br> <br><br><br>
Thank you for your very informative reply! I'm saving it in a file as I'm sure everything you said is going to help me get something up and going here.<br><br>I just got back from hiking down to my trailer where I have both scopes stored now. The white one in the previous photograph is a Tasco, my much older, and in poorer condition scope is a Criterion Dynascope. The lenses and focuser I have go with it. the Criterion is a lot longer and skinnier than the Tasco is so maybe this focuser change won't work?<br><br>I don't know anything about those F numbers you mentioned. I guess I need to find out.
I looked around for the criterion 4&quot; , it looks OK but the tripod I saw was very mediocre. This is an F9 (That is 36&quot; length and 4&quot; mirror diameter.) If this Tasco is shorter and it is 4.5&quot; or 5&quot; this means that this must be between F5-F7. When the mirror is larger they make them this way. <br><br>Don't worry about the eyepieces, they are universal they do not depend on the F number, in one extreme case you may have to do a small modification on the focuser to increase the travelling distance. <br><br>My main point is that before doing any changes you have to evaluate them first as I discussed in the previous letter. The tripod or other mount should contribute 50% to your decision to select a scope.
My old scope was in pretty tough shape when I got it. It didn't get any better with age either. When I looked in it today it looked like stuff had been living in the tube. It was all full of fuzz and stuff. I think it is safe to say its done.
<br>Instead of tranferring the focuser from the other scope why not make a simple construction like this for testing the tube: <br> <br>http://www.instructables.com/id/Simple-wooden-Crayford-style-focuser/ <br> <br>This is called the crayford focuser and is based on friction instead of the rack and pinion mechanism.
Mostly because I have the focuser kicking around already. I'm never going to use it on that other scope. It's shot.
Great write up with some very nice fixes. Thank you. <br> <br> I had a problem with my spotter scope moving off center and as such spent a good couple of minutes realigning it before being able to start searching. I found a bicycle puncture repair patch (the big rectangles 150mm x 100mm not the preformed patches) were perfect, you remove the spotter, place the patch (cut to size) replace the spotter and tighten the screws. Obviously you have to align it but it is far more robust. :)
Thanks.
Thank you for this timely instructable! My son's Scout troop campout last week included a stargazing night with the local astronomy club, and he has definitely caught the bug. We bought him a scope a couple of Christmases ago that moves like Jagger if you even glance at it funny. I will be looking at stableizing it with some of your suggestions soon. Probably will make it mount to my camera tripod, which is of much better quality.
I am glad that it was useful. I also use the photo tripod more than its own.
Great post and very useful tips! And that is a nice little scope. A few comments:<br><br>1) when building the eyepiece, it may be a good idea to blacken the edges of the lenses to reduce scatter.<br><br>2) zoom lenses are nice, but the downside is the restricted FOV when zoomed out. It is indeed useful to have the zoom to locate objects and then observe at higher magnification, but you'll still want to have that larger EP in your pocket for observing galaxies, open clusters, etc.<br><br>3) for someone as handy as you, you might consider replacing the tripod legs with wood. It will be heavier for transport, but more stable.
Thank you!<br><br>1. Blackening the edges is indeed a good idea. Specially because the field in low magnification is very wide. <br>2. I hesitated before buying the zooming lens. The big advantage is that its perfect for a spotting scope and in some cases when I do not want to carry the full bag of accessories , not even the finderscope, its the only lens you need. Normally i use the full range of eyepieces. <br>3. This is valid tip because the support is OK, the legs are not good.
Great post!<br>I really like adding a wwight to the tripod for stability. what a simple idea.<br>I also like adding zip ties to the spotting scope to help keep it from being knocked out of alignment. I do have that problem when I transport my scope so gonna have to do that one.<br><br>here are some things that i've done to my scope.<br>replace the standard finder scope with a red dot finder. I was always frustrated using the standard finder scope. looking thru it you would see a white dot, but on a clear night with a sky full of white dots, i could never tell exactly which one i was looking at. with a red dot finder you can use 2 eyes and easily tell exactly what your looking at.<br>I added a clock drive motor to my equitorial mount. i found one for $20 on bay. it really works well. it's not perfect so i the one i use wouldn't work if your doing long photo exposures but it's not bad. i think it's more a problem with my tripod than the drive.<br>to help with set up i attached a small bubble level and compass to my tripod. makes alignment much easier.<br>I have small red led's which stick with velco to the bottom of the tripod legs. keeps you from accidently bumping the legs. mine are homemade which i got at a star party but i'm sure you can rig something up using some keychain lights.<br>with my tripod the equitorial angle set screw has a tendency to work loose after a while so I cut a wood block that is set for my latitude (42 deg). the wedge takes the strain off the set screw so it stays in place. i need a better way to clamp the wedge in place but it does pretty well.<br>this really isn't an accessory, just somethign that helps me. on my ipod i have the &quot;Star Walk&quot; app. I can hold it against the telescope as i move it around. it's pretty good at identifying what i'm looking at. it really helps my find dimmer objects.<br>one of my next projects is to make a custom transport box for my telescope. i often have the problem of my finder getting bumped and knocked out of aligment so I want to make something to keep that from happening.<br>I did make a custom box to hold all my eye pieces. it's just a small tool box with a piece of rigid insulation that has holes for the eye pieces.<br><br>for what it's worth those are the things that have helped me.
<em>'on my ipod i have the &quot;Star Walk&quot; app. I can hold it against the telescope as i move it around. it's pretty good at identifying what i'm looking at. it really helps my find dimmer objects.'</em><br> <br> I actually created an app for this, called <a href="https://market.android.com/details?id=com.lavadip.skeye" rel="nofollow">SkEye</a>, but it's for Android. You can attach the phone to the scope and then align it (within the software) with a known star. It then guides you as you move the scope around.<br> <br> And the scope being mostly plastic helps in this case as it doesn't interfere with the magnetometer :-D
Glow in the dark paint is a good thing to put on things you don't want to hit at night. I use it on tent stakes, but same principle with the tripod.
Good idea. Actually one needs a few marks on the tripod for the equatorial mount and other things. Bresser has included two such marks for aligning the scope to Polaris. When I use the scope on the terrace of my building I place the tripod on white paint marks to direct it to the north without using a compass.
Thank you for sharing this information! All the things you are describing are useful hints. The bubble level is useful indeed I should add one. My photo tripod has one and I use it when I take photos with my improvised barn door star tracker (see my other instructable). The red dot finder is indead a little easier to use however I do not like them too much. I also carry &quot;Pocket Stars&quot; on an ipod.<br>Thanks again!
That that you have done is the best option, I think. Cheap products are usually excellent designs submitted to manufacturing constraints, and is relatively easy to replace or correct defective parts, or add what is missing.<br><br>GOOD WORK!
I'm going to remember that, &quot;Cheap products are usually excellent designs submitted to manufacturing constraints&quot; Good one!
Yes, Fred, that's an &quot;Osvaldo's papal truth&quot;. Rarely it fails
Although this may not be true all the time in this case it is. Bresser is a known telescope manufacturer with a large collection of products. In this case they tried to realize a good design at a low price for the needs of a large department store. The result is a scope that is basically good but a) contains some plastic parts where metal should be used and b) provided three mediocre eyepieces in order to keep the price down. One decent eyepiece costs at least twice the price I paid for the scope. Fortunately I had read some reviews before getting it.
Thank you! You already know that I am a follower of your original work.<br>
Nice instructable! I started work on one similar to this a while back, then decided I wasn't qualified. Yours is much better! Thanks for sharing your knowledge, I'm sure I'll be able to make use of some of these tips!
It is a pleasure sharing this kind of experience. Most of us amateurs, have faced problems.like those included in the instructable.<br>
About This Instructable
116,641views
226favorites
License:
Bio: I am a physicist working in research, Making things and sharing the experience with others, helps me in many ways.
More by tholopotami:Tabletop bench and Moxon vice How to digitize slides and film negatives with  a DSLR 12 improvements for a cheap telescope
Add instructable to:
