12 volt air conditioner by rowerwet
Featured
Step 4: The body cooler
this is my current design instead of air conditioning in my car, it is a direct copy of this I'ble http://www.instructables.com/id/Too-Hot-Remove-heat-from-your-body-with-the-Back-/ only mine uses pex as the heat exchanger, this works very well, almost too well, I have had to unplug it more than once while driving on very hot days, as I found I wasn't sweating anymore and was starting to feel a little sick to the stomach. a timer circuit or some sort of clip on body thermostat might be a good idea.
 IF YOU HAVE CIRCULATION PROBLEMS THIS IS NOT A GOOD IDEA FOR YOU! IT WORKS TOO WELL AND COULD KILL OR BADLY HURT YOU.
   After my heater core Air conditioner idea failed due to the heat coming in through the window glass, I took the heater core off of the cooler and made a back heat exchanger this way:
-measure the length of the nipples on the T fittings with the tips touching,
-cut a short piece of PEX to cover that length and install it on the nipples with a PEX lock ring.
-crimp the ring in place with the pex crimper.
-continue the string of T fittings with all of the T lower legs pointing up until you reach the width of the seat back it will be installed on.
-for the last pipe you need a 90 degree fitting instead of a T fitting.
-count the number of T's and put another string together that matches the first string you made
-measure the height of the seat back and cut the small diameter PEX tubing to length
-install the PEX tubing to the T legs to connect the upper and lower runs, with the exit for the water at the top opposite the in for the water at the bottom.
-I used two 90 degree PEX fittings at the top to turn the water return 180 degrees behind the headrest of the car seat to lock it in place.
-connect the lower and upper supply/return lines to the flexible tubing coming from the cooler
-run the wires from the cigar lighter plug to the pump. an inline switch might be nice as it would save plugging and unplugging the cigar lighter every time. my cigar lighter plug has an LED in it to let me know it is getting power. The first time I used it I bumped the cord and the fuse inside the plug blew, since I knew my cell phone charger still worked that meant the plug had the open, which turned out to be the fuse.
-fill the cooler with ice and just enough water to cover the pump
-put the pump in the cooler so it is at the back in most cars, as the seat slopes toward the back.
-this design is so efficient that you could easily us a very small cooler, or do all of the seats in the car, and since the pump is rated for 500 gph it would handle all four, just install a simple in line ball valve for each seat back to regulate flow if no one is sitting there.
this set up works great and you really don't notice the pipes as the seat back lets them sink in.
-I like having clear plastic supply lines also as they let me see that water is flowing, however they are not rigid enough to keep from being collapsed by my weight against the seat back, PEX is very rigid, I could probably stand on a PEX pipe, and even if it did collapse it would just snap back.
running the water from the bottom of the seat back to the top ensures that it is always full, if it ran from the top down the water could drain through the first few tubes and leave the last few empty.
jr23 says: Mar 24, 2013. 10:41 AM
caution with pex tubing it is not uv protected if the sun get to it it will degrade
rowerwet (author) says: Mar 27, 2013. 9:45 AM
two years tywrapped to my cars seat during the warm weather, and no issues. of course it is running at just about no pressure, and if it breaks I'll just put more in.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
