3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
120,000 Volt Van De Graaff Generator
Step 5The Base and column
The Base and column
The base is an old laundry bucket , inverted. Lay the power roller and motor on top of the bucket and mark the location of the mounting holes and roller location. Using those markings locate the closet flange and mark it's mounting holes and the area inside to be cut out. Cut out the hole to match the closet flange and drill out all the locations for assembly bolts.
The column is easy, simply mark down one end a distance equal to the height of one mixing bowl, now mark four points equidistant around the pipe at that location. Drill a 2" hole through the pipe through two opposite points and a pair of 1/8" holes through the other two points.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
257
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
