3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
120,000 Volt Van De Graaff Generator
Step 6Gross assembly
Gross assembly
The column is mounted to the bucket with the closet flange. The power roller is mounted inside the bucket and the mounting manipulated to make roller perpendicular to the column. The belt is slipped on BEFORE adjusting the roller. The belt is then pulled through the column with a scrap of wire and the top roller installed using small bolts threaded into the PVC with nuts on the inside, as axles.
At this point apply a few volts to the motor and check to see the belt runs true, if it runs to one end, the end of that roller needs to be moved OUT, where out is away from the middle of the machine.
3 comments
May 22, 2011. 10:56 AMhcarmona says:
how well does it work compared to the teflon and nylon rollers?
May 12, 2008. 8:55 PMsikick111 says:
How important is the aluminum foil to the overall outcome?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
257
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
