3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
120,000 Volt Van De Graaff Generator
Step 7The brushes and tuning
The brushes are multi strand copper wire fanned out and mounted approx. 1/4" inch from the belt roller combo at each end. The top brush is connected to the inside of the sphere and the bottom brush is connected to ground, whether an earth ground or power supply ground seems to be irrelevant.
At this point slip the dome on and apply about 6 volts to the motor. You should feel a charge around the dome.
Tuning. Don't allow the brushes to rub against the belt, the deposited copper will make the belt conductive and the generator will stop working. If it fails to work at all adjust the brushes and try again. If all else fails degrease the rollers and belt with rubbing alcohol, grease is death to triboelectric charge separation.
10 comments
Feb 5, 2011. 1:20 PMpeacefoots says:
how small of a motor can you use
Jan 18, 2010. 11:47 AMsheial360 says:
So does the bowl have be cut so the PVC pipe fits in it and the bowl covers  the hole that was made and the roller ?????? ,
And does the sock  have to move or does it stay still ????
Sep 30, 2009. 8:15 PMemeraldamber says:
I really don't get the bottom brush connected to the ground... is it connected literally just to the ground..? and what is it for...? me and my groupmates are trying to make one... we used Teflon for the bottom roller and aluminum at the top but it would just not work. does the motor have to be fast working? what should be the mixing bowl made of? aluminum? stainless? help! :(
Jul 3, 2009. 2:04 AMslipknot rules says:
Van de graafs work best in under 40% humidity :)
Jul 30, 2007. 1:50 AMmetropox says:
Today I finished constructing my very own van de graaff...it was working magnificently, creating miniature electrical arcs across to my hand. I turned it off, did other things, and came back in a couple of hours to give it another go. For some reason it would not charge at all. I checked the brushes to make sure they weren't touching, and the belt (I used a rubber latex exercise belt) seemed clean. I turned on the motor and applied rubbing alcohol to the spinning belt just be sure and it still wouldn't work. I thought maybe the carpet floor was interfering (my ground wire ends by touching the carpet floor), but then again it was working earlier today. Any ideas as to what it could be?
Jul 30, 2007. 2:11 PMmetropox says:
It turns out that humidity was my problem. I had been using the air conditioner to dehumidify the room and didn't realize how fast the room re-humidifies after the air conditioner is shut off.
May 10, 2007. 6:59 PMbsumner says:
how exactly is the wire connected to the inside of the sphere? is it just loosely touching or did you solder it somehow?
May 10, 2007. 7:19 PMbsumner says:
oh ok, thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
257
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
