123D Secret Chamber Knitting Needles
23,496
83
43
Posted
Introduction: 123D Secret Chamber Knitting Needles
Autodesk 123D Design Challenge
First Prize in the
This instructable shows how I made this 3D model of my own invention made with 123D design. The following text explains what it is and what you can use it for. I hope you like it! (This is the first time I used 123D design, so it is possible this instructable doesn't show the fastest way to create this model, it shows a way)
So, what is it?
They are hollow knitting needles with fitting caps. Also shown is a crochet needle that fits in the hollow knitting needle.
And why would you use it?
This model gives a solution to a strange problem I sometimes have: what should I take: knitting needles or a crochet hook. When I take  knitting needles, I feel like crocheting. When I take a crochet hook, I feel like knitting. When I take both, I lose my crochet needle. When I take none of them, well, that won't happen.
The 3D model can be found in the last step.
If you like the idea, I would really appreciate a vote in the autodesk 123D contest.
Step 1: 123D Design
First, get 123D design. I made this in the online version. You can find it here.
The directions for the crochet needle are shown step 2/5
The directions for the hollow knitting needles are shown step 7/8
When you have done this, open a new file.
Step 2: The First Cylinder
From the primitives basic shape on the right side, choose the cylinder. Drag it from the column to the left.
When you select it, you can change the size. Make the height 14 cm.
Step 3: Cone, Resize, Fillet and Tweak
From the column on the right side, choose a cone. Put it on the cylinder.
Select the now created shape. Using one of the four small white dots, make the cylinder smaller, but keep ratio. When L and W show the same decimal number, change both of them to 0,4 cm.
Using the fillet option (where to find it is shown in the pictures), click the join between the cone and the cylinder. Change the radius from 0 to 1.
Next choose the tweak option (where to find it shown in the pictures) and select the upper part of the cone. Just experiment a bit until you reach the right shape. The numbers I ended up with are: L: 0,01; W:-0,058; H:-0,1
Step 4: Add a Dome
From the right side, choose the dome. Using the white dots, change the length and width to 0,5 cm.
After that, place the dome on top of the other shape, position it as shown on the picture.
Before going to the next step, turn your view to bottom view, so you can see the underside of the dome you just placed.
Step 5: And Another Dome
Again, take a dome. Change the size to:
L: 0,25
W: 0,25
H: 0,20
Place it on the flat side of the other dome and position it as shown in the pictures.
It can be helpful to look at the other side too, just so you know it looks good on every side, not just on one.
Step 6: Finished Crochet Needle
So, now your crochet needle is finished!
Oh, and DO NOT forget to save!!!
To make sure it is one piece(not pictured), select the complete model. Then, at the bottom of the page, it says how many objects there are. If it says 1 object, you don't have to do this. If it gives a number other than one, go to the symbol with two cubes, on the left of the T, and choose group. Now it will say it is one object and you will be able to move it like one object.
Step 7: The Knitting Needles
Open a new file. Take the tube. Change the height to 34 cm. Then, take a cone and put it on top of the tube. Select the cone and change the height to 2 cm.
Use the fillet tool to select the join between the cone and the tube. Change the radius from 0 to 8.
This is the base of your hollow knitting needle. Next step will show you how to make the caps.
Step 8: The Caps
Choose the cylinder. Use the white dots to change the size to: L: 1,5; W: 1,5. The height stays the same.
Take a second cylinder. Change the size to:
L: 0,6
W: 0,6
H: 1,25
Place the smaller cylinder on top of the first, bigger cylinder. Using the arrows, put the smaller cylinder down, so it extends above the bigger cylinder.
Again, check if it is one object, if it is not, group the selected objects.
Step 9: Done!
In this step I've included some different material and colour options.
This is the link to my model:
http://www.123dapp.com/FullPreview/Index.cfm/ID/1635865
    • Space Challenge
      Space Challenge
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    39 Comments
    This is great! I need a replacement for part that was lost and cannot be purchased any longer. If I found someone online who still has such a part, how would I go about finding someone who could duplicate it?
    this is brilliant, i hope you win the contest.
    What a great idea. You need to get these made :)
    This is great - when you knit, you always need a crochet hook handy for dropped stitches, weaving in yarn tails, etc..... this way you have one with you at all times. Now to figure out how to put row markers, and stitch markers in maybe the other needle...
    Great job
    ADDENDUM TO 'SNAP AND TWIST' IDEA... Don't try to go into manufacturing on your own. PATENT PEND your idea RIGHT NOW - it can be done in a day or so. THEN - contact the knitting needle manufacturers with your idea, offering it for sale. Before you do that - contact someone in the industry to try to get an idea of the VALUE of your idea - so you don't sell a million dollar idea for a few thousand dollars. Go to legitimate sources - like big-time patent attorneys and/or manufacturing groups in this arena. Call a local attorney who handles patents, and see what he/she suggests - and they might 'handle the deal' for you. PUSH TO GET IT DONE SOLD NOW - before Thanksgiving at the latest. There is very little time left, but if I told you what's getting ready to happen, you'd think I was a 'conspiracy theorist'... aka TRUTHER. Good luck!
    Patents are killing Innovation/Invention in the USA.
    Also, he released the design files under a CC License--he, nor anyone else for that matter, cannot go and get a patent for it.
    Stop. Pushing. Patents. Start pushing innovation.
    If seems though that the idea (snap and twist) is yours, not the author's.
