1.25 TO 25VDC POWER SUPPLY
3,144
13
Posted
Introduction: 1.25 TO 25VDC POWER SUPPLY
Hi,just an easy instructable to show you how to make a 1.25v dc to 25v dc power supply.
Step 1: Epuipment
We will be doing a lot of soldering for this project,so get a full roll of solder at least!So, with all that,we need
Soldering iron
Desoldering iron
Solder
Lead trimmers
Wire stripper
Helping hands[unfortunately i didn't had them,but still a recommendation]
Step 2: Parts
As you can see from the schematic, there are plenty of parts to this circuit.
So, lets get started with the parts
Load switch[120vac,6a]
3a fuse
28vac transformer
2a bridge
1000µf electrolytic capacitor
10µf electrolytic capacitor x2
LM317T IC
TO 220 Heatsink
0-5k potentiometer
240 ohm 1/4W resistor
Prototyping board
Step 3: Final Step
Solder all the parts and you are done.
If you power supply works without LM317T smoking,then you re successful. If not,there is something wrong.
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    3 Comments
    Would be bad for low voltages with higher currents, because the regulator will become hot.
    It doesn't, I have tried it many a times
    Sure it will become quite hot... Let's say the input voltage to the linear regulator is 10V and the regulated output voltage is 2V and the current is 1A... Than the linear regulator will have to dissipate 8V*1A =8W of power....
