3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
12V Car lighter to USB Adapter for less than 3 $ (1,5euro)
I had a client recently wanted to use USB in his car. He told me that kind of adaptores cost in the stores about 13-15 euro (8-10 USD) the cheap and about 25euro (18USD) the expensive. That was a challenge for me. So i tried myself to do it.
First of all we have to consider what exactly we need to do with a USB as power supply. To charge an MP3, using it as light resource or other genberal power supply of standart 5,1 V DC.
The materials are...
1. A Car lighter adaptor (from 0,50 to 1euro)
2. One 12V lamp or a led and 330Ohm Resistor 1/4Watt (0,02 euro)
3. A USB Sasshi adaptor. (I had one from spare parts) New costs 0,20 euro
4. Two pieces of cable one black 10cm and one red 7cm
5. One resistor 57 Ohm 1 watt (0,01euro)
6. One diode 5V1 (5,1V) (0,01 euro)
7. one Cooler (0,10 euro)
8. Some soldering and a little attention.
Step 1Lets Work!
Lets Work!
First of all we take the Car lighter adapter. All of them have fuse of 3A. We leave like it is.
The Lighter Adapter i got had a trasparent red cover and then i had another idea. To put a small 12 V lamp to define if it's working or not.
The Positive pole is in most cars the central pin.
So we place the small lamp among the negative and the positive pin of the adaptor
Also we Solder the cables in the + and -.
After we close the car lighter. If we power on it shows like this (Image 3)
17 comments
Nov 26, 2009. 12:30 PMvtsnaab says:
Great idea.
I wonder if you would be willing to clarify just a bit ?
1. The word 'sasshi' - does it mean 'socket' as in 'USB socket' ?
2.
The circuit is not drawn out and how you wired the diode is baffling:
What did you do with the open end of it - where does it connect ?
3.
One must presume it is a ZENER diode, similar to:
Digi-Key Part Number: DFLZ5V1DICT-ND - is that correct ?
(Zener diodes usually are used by 'bleeding off' excess as heat or to ground...)
4.
The assembled item hides the resistor's heat-sink somehow; is it all taped up, or hidden inside the 12V plug-in part ?
Please pardon my curiosity.
I haven't used a zener diode for anything in almost 20 years and had forgotten they even exist anymore !!!
Best Wishes, and Thanks.
Oct 29, 2011. 8:19 PMpben says:
I know this is an old post but this schematic is wrong. http://en.wikipedia.org/wiki/Zener_diode has the correct way. You need to put the Zener across the 12V supply with the cathode toward the +12V resistor.
Aug 5, 2010. 10:38 PMszpjbb says:
(removed by author or community request)
May 21, 2009. 10:27 AMWiet Here says:
I think it's "too short through the curve", as we say in the Netherlands. How about safety? I used a voltage regulater from the 78 series, only 60 eurocents at the local electronic store. Thermal and shortcircuit protected. It easely fits in the plug WITH a small glass fuse. And we don't need a light to see if it works, unnecesary lights can be confusing in a car. Otherwise I like this site.
Feb 27, 2010. 1:29 PMscratchr says:
You could use an lm7805. They are dirt cheep on mouser.com. Just wire the positive from the battery to pin 1, negative from usb and battery to pin 2, and positive from usb to pin 3. They will protect your usb device from overload.
Feb 15, 2010. 2:18 AMeddu says:
Just to note that the resistor shown in the pics is a 58Ohm resistor mate.
Jan 5, 2010. 11:06 AMmarke2 says:
It is a great exchange rate you get there like $ is stronger than Euro
Nov 19, 2008. 9:59 AMr3b3l says:
Nice and clear job. 5/5 Some pics are Blur but are clear enough to see what's happening. What if the sasshi usb you connect directly to a USB hub for more USB links? It influence the power???
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:agis68
I like to invent and modify things. When i was 13 i fixed my dad's old Lancia Fulvia motor. I builded my first mod PC in 1991 using a mobo builded in a VCR box. I am first using all my inventions. I l...
more »
