3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
12Volt IN, Adjustable output power source!
Hey guys,
I'm learning electronics and have begun my adventures by starting with a GREAT project I suggest EVERYONE tries!
What I'm doing:
I will be describing my way through the process of making a Solar Powered adjustable output power supply! I unfortunately don't know enough to have this as a complete instructable, I am asking YOU guys for help! Here is what I have so far [Basically the first few steps, and the last few, the middle ... and most important... are missing]:
Step 1.
You will need the following:
1. Solar panel, 12+ volts.
2. A 12volt DEEP CYCLE Battery
3. A charge controller
4. A power [12v-110/120v] inverter
5. As many DIFFERENT cigarette lighter adapters you can find
6. A switch having as many settings as # of adapters you have.
7. Various USB/Mini USB/Wall plug outlets.
8. Shottky Diodes ( 4-10 will be more than enough)
9. Solder, wire, etc...
Step 1Getting your grips
Whats going on in this instructable is that we are going to be taking the sun's energy via a photovoltaic cell, and using it to create a battery storage power. That battery will be used to power your phone charger, your ipod charger, re-charging other batteries, as well as powering electronics (be it smaller ones) like a laptop, a lamp, and maybe even a classic gaming system (sega anyone)?
So to start out, there are many instructable on how to do the first few steps:
You may create your OWN photovoltaic (PV) cell by piecing together many small ones:
http://www.instructables.com/id/DIY-Solar-Panel/
OR just buy one (I bought many small ones that I will solder together (however they weren't broken).
3 comments
Feb 7, 2010. 12:09 PMzebratangozebra says:
Great idea but what you are trying to do has already been done.
One good book which covers this is: "Managing 12 Volts by Harold Barre".
Jan 16, 2010. 6:45 AMSubFusion says:
You need a voltage regulator.
Look up on google: LM7805 pdf, it will do 5 volts from anything from 7V to 35V
lots of others are avaliable, like LM780x. x = 10,9,8,7,6,5,3. Look up LM338 i think its a variable voltage regulator. In general, u need at least 1,2 volts more from the source than the output of the regulator, so depending on the volts on your car battery, LM7812 might not work. a regulator usually can supply 1 Amp, but the 78Txx series can supply 3 amps, and its possible to add more in parallel to increase current.
Dec 30, 2009. 2:38 PMlemonie says:
This is theory, put it in a Forum Topic. If you build it, please do make an Instructable.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:GreenD
