Hi this is a way to make 12v led lights that can be used on any standard 2 pin 12 volt light for example your cars lights, inside your motorhome, boat or 12v home lights(like those for your desk or to light up your paintings or photos).. these are very common so you can replace them almost anywhere and are also very very cheap easy to make and you will be saving lots of electricity since they bearly consume any electricity..
you can make these of 4 or 2 leds or more if conecting them in parallel depending on size and how much light you will need
it pretty much ends up beeng the size of a small 12v car bulb
Remove these ads by
Signing UpStep 1: Parts!!!
the parts for this project are as following
you will need (in picture)
1---- 100nf capasitor
1---- ln4007 diod
1---- 150ohm resistor **
4---- super bright white leds (i will be using some bright orange LEDs) *
solder
soldering iron
pliers
* this is to make the 4 led version... if you want the 2 leds you will need a 348 ohm resistor instead
** the value of the resistor will also very with the input Voltage, the type of LED you buy and the Diod...
my led has a Forward Voltage of 2V (the white ones are 3.5V or somthing like that) and a max of 20 miliAmpers and my diod of 1.1V and i think a max of 1amp
so if you would like to calculate the exact value for your components you will need this information..
In the images i leave you a formula to calculate the resistor depending on your components..
in this formula (in the image)
V--------- is the voltage you will use to power the led
Vfled---- is the forward voltage of your led
Vfd------- is the forward voltage of your diod
Imax---- is the maximum voltage that your circuit can take so that would be your LEDs operation current
nºleds-- is the number of leds you will be conecting(if the resistor gives a negative number you passed the limit of leds)
Visit Our Store »
Go Pro Today »
Also, while car batteries are 12 volts, the charging system runs a bit higher. You should do your calculations based on 14.4 volts when designing for automotive use to insure you don't supply too much current and shorten the LEDs life.
Its a Really Nice Design!!
I will make this & FWD it around.
HOWEVER! you need to redoo the blue ink diagrams/Schematics in BLACK ink! & PRINT bigger.
can't read the blue, even zooming in in other software ,its too faint & lo RES.
Mr. Steve
Your ideea with diode and a capacitor is great but how do i calculate or what models can i use?
Drawing the schematic wsa very help full.
How nessacary is the capacitor or diode in the build?
Well done again on making it!!!
