1/3 How to EDIT and CREATE Blocks in Ardublock WITHOUT Eclipse 1/3
Published
Introduction: 1/3 How to EDIT and CREATE Blocks in Ardublock WITHOUT Eclipse 1/3
PART 1/3
Hi,
a lot of people are becoming crazy with the install of eclipse, maven, open block, etc. And all this for Ardublock.
I show you how to EDIT (2 ways) and CREATE blocks without the crazy world of eclipse.
EDIT
  1. download ce2.23 class editor
    http://sourceforge.net/projects/classeditor/files/...
  2. download HXD hex editor http://www.bleepingcomputer.com/download/hxd-hex-..
  3. download java editor
    http://javaeditor.org/doku.php
  4. download SOURCE CODE for ardublock (this we wil used for create blocks)
    https://github.com/taweili/ardublock https://github.com/taweili/ardublock
A . the fast way
Open ardublock with WINRAR and go to com\ardublock\translator\block\duinoedu
you see many .class files.
Drag and drop any class file OUT of ardublock example "Partie_Emetteur.class"
open Arduino with Ardublock and play sketch with Emetteur
1. now open ce2.23 folder and run ce.jar
2. In ce class editor open and find Partie_Emetteur.class
(out of ardublock)
3. TURN modifymode(Off) to (on) -up and right
4 go to Menu Constant Pool you will see all the parameter of class file.
You can do anything you want the file but becareful with the values , but for correct result
ONLY CHANGE string value utf8 type.
you have access to line 52,55,59,61,64,65 and other but dont touch them . Together work with arduino to view code and make change.
Let's add line in class file
example : go to line 55 Value : //libraries at http://www.duinoedu.com/
and add _#include _#include
total value : //libraries at http://www.duinoedu.com/ _#include <LCD.h>_#include <TFT.h>
modify (down button) save .
goto line 61 you see value (down) " ); " .
write );_Serial.begin(9600);
modify
goto line 65 you see value " ); "
change );_Serial.println("hack ardublock") ;
modify and save.
"Open HXD hex editor and load Partie_Emetteur.class file
Look carefully in right side for //libraries at http://duinoedu.com/ _#include
When you find do that :
The symbol "_" in RIGHT side has value in hex (left side ) 5F .
change 5F to 0A .That means next line "\n" you see symbol "." point at the right side
change and the other symbol "_" after .It will be RED.
do the same and for other 2
Save and exit .
Close arduino
Drag and drop the class file back to ardublock to the same directory .
open arduino and ardublock .Make sketch in ardublock with Emetteur
finished first way.
Step 1:
Hi,
EDIT
download ce2.23 class editor http://sourceforge.net/projects/classeditor/files...
download HXD hex editor http://sourceforge.net/projects/classeditor/files...
java editor http://sourceforge.net/projects/classeditor/files...
download SOURCE CODE for ardublock (this we wil used for create blocks) http://sourceforge.net/projects/classeditor/files... http://sourceforge.net/projects/classeditor/files...
Step 2:
A . the fast way
Step 3:
2. In ce class editor open and find Partie_Emetteur.class (out of ardublock)
Step 4:
You can do anything you want the file but becareful with the values , but for correct result ONLY CHANGE string value utf8 type.
Step 5:
example : go to line 55 Value : //libraries at http://www.duinoedu.com/ and add _#include < LCD.h>_#include
total value : //libraries at http://www.duinoedu.com/ _#include <LCD.h> _#include <TFT.h>
modify (down button) and save .
Step 6:
modify
Step 7:
modify and save.
Step 8:
Look carefully in right side for " //libraries at http://duinoedu.com/ _#include etc.... "
When you find do that : The symbol "_" in RIGHT side has value in hex (left side ) 5F . change 5F to 0A .
That means next line "\n" , you see symbol "." point at the right . Change and the other symbol "_" after <LCD.h>, It will be RED.
Do the same and for other 2
Save and exit .
Step 9:
Close arduino
Drag and drop the class file back to ardublock to the same directory . open arduino and ardublock .Make sketch in ardublock with Emetteur
finished first way.
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    2 Comments
    Hi, thanks for posting other ways to edit Ardublock.
    I'm a teacher for kids age 10 - 12 and would love to simplify Ardublock for them: remove all blocks they'll never use. I only have some Seeed Grove Starter Kits. Is there a very simple way to remove the blocks? I edited the ardublock.xml-file, but I can't figure out how to compile that xml-file back in Ardublock. I miss the basic and most important stuff; how does it work? Do we need to edit some openblocks-scripts and put it in the master script or vice versa? Isn't there a really simple way? It would be so amazingly cool if this program would only contain the easy blocks.
    I've never done anything with ardublock. I'll need to look into it!
