- Well the reason for this experiment was that the new Macbook Pro 13.3 only has a single audio out/in jack. The Operating System allows you to change it to input or output. After using my nice headphones with a microphone built in I was saddened that I could not use these. I had to sacrifice one or the other.
- Now when I was browsing the apple support forums one user said the Macbook will allow you to use your iPhone headphones and be able to use the microphone as well!! AWESOME! Now I had to find a product that could do just that.
- After obtaining the DLO headphone splitter (because it says it supports mic input), it didnt work.
The problem is in the pin outs of my and most common 3.5mm mic jacks use the tip as the signal and the sleeve for the ground (pic will follow). Apple uses the sleeve for the mic and a common ground in the middle.
Time to change that!!!
Remove these ads by
Signing UpStep 1Tools and Parts
- Soldering Iron
- Solder (resin core most popular)
- Pliers
- Diagonal Cutters
- Small Flat Head Screwdrivers
- Small guage wire
- Helping Hands (not needed but they do help!)
- X-Acto Knife
- Patience
You can get the D-LO adapter from e-bay (for about 15 bucks)
part number: DLZ70003 or DLZ70003/17
Product Link: http://dlo.com/Products/cable_headsplit_Prod.tpl
Pin out reference: http://pinouts.ru/PortableDevices/iphone_headphone_pinout.shtml
However, this design is really good "outside the box" (or is it see what's inside the box :-) thinking!
Any chance you have a link to the ones marketed for the iphone? Are they basically the same thing?
do you know if the DLO splitter has a chip in that tells the macbook it is both and input and output ?
I have tried with just a 4 cable jack and croc clips but it didnt give me anything in system preferences
thanks
i will try and borrow a friends iphone headphones to test if they kick it into thinking it has mic in as well as audio out
Thanks anywho, i now know that it is possible some way.
Using this adpater, I will be able to plug in my own set of headphone and mic for my iPhone right?
