$14 Secret Crawlspace Access Door
102,538
781
53
Posted in HomeHiding-places
Introduction: $14 Secret Crawlspace Access Door
About: I am married and have two daughters. I have owned a house painting company for the last 15 years. My goal is to retire early so that I have the time and energy to be creative, adventurous, and a good husba...
This is a hidden crawlspace access door that I built into my bedroom closet floor. It allows my crawlspace to now serve as a storm shelter, a safe room(a place for my family to hide in case of an intruder), and a storage area.
I built it 2-3 years ago and it has been opened and closed 100's of times with no signs of wear and tear. The door is so well hidden that even I cannot see it when it's closed, and I know exactly where it is. There is no handle needed, you simply pull on the carpet to lift the door.
The scariest part of taking on a project such as this is cutting through a perfectly good floor. Who wants to be the guy who screwed that up, right? In steps 1 & 2 I explain a full proof method for marking & cutting the door opening precisely & accurately.
PARTS LIST
Piano Hinge @ $6
Barrel Bolt latch/lock @ $3
Double Sided Carpet Tape @ $5
Rubber door seal @ optional
Handle for underside @ optional
permanent ladder @ optional
scrap 2x4 @ free
Tools Required
Box knife
circular saw
reciprocating saw
drill
1/8" or smaller drill bit
(2) squares
tape measure
5 BBQ skewer
chisel
duct tape
Protected Contest
Runner Up in the
Protected Contest
Step 1: Mark Opening
1) You need to find a suitable area you would like your secret door to be located. (Your floor joists will ultimately determine precisely where the door can be located)
2) Once you have found a suitable location, drill a very small hole through your floor.(1/8" or smaller) This hole should be roughly in the center of your door location. Slide your BBQ skewer 4-5 inches into the hole and secure it. If the skewer does not slide through completely, you may have hit a floor joist. Drill another hole 2" away and try again. Warning! Do not allow the carpet to twist around your drill bit. Don't worry about the hole, the carpet will hide it. Trust me; if you pull out the skewer, you may never find the hole again.
3) Go into the crawlspace and find the skewer. Now that you know which floor joists your secret door will be located between, drill 4 holes up through the subfloor.
- Measure out 1 1/2 inches from the joist and drill a hole up through the subfloor and carpet. Drill a 2nd hole 1 1/2 inches away from the same floor joist 10 inches away from the first. Both of these holes should be inside the area of your access door location.
Repeat this process with the opposite floor joist.
Now slide a skewer into each hole and duct tape it into place.
4) Head back upstairs and place the fat(2") side of your square along the outside edge of 2 of the skewers (parallel to your floor joists). The 2" side of your square will overlap 1/2" with your floor joists. Do the same with your other square and skewers. If you measured correctly, your squares should form a perfect rectangle. You can adjust the length of your door to your needs, but the width is predetermined by the spacing between your floor joists.
Step 2: Cut Opening
1) It is time to cut out your opening. Using your sharp box knife, cut the carpet and padding along the outside edge of your square, leaving the carpet on the hinge side of your door intact. Only cut 3 sides! Do not rush through this step or your door may be visible after completion. Take your time and be precise.
2) Fold the carpet and padding back and cut all 4 sides of your subfloor using your circular and reciprocating saw. (the carpet will hide any imperfections in your subfloor cuts)
3) You should now be able to pull the door out of your floor completely. If not, your subfloor may be glued in place. If this is the case you will need to go back into the crawlspace, slice between the subfloor and joists with your box knife and pry it up with a crow bar.
Step 3: Prepare Opening and Door
Your door should already be the perfect size for the opening. Now you can install the 2x4 cross braces, the piano hinge, locking barrel bolt, handle(optional), and rubber seal(optional).
1) Add a 2x4 support between the floor joists at each end of your door opening. It should only extend 1/2 inch into the door opening to support the door when it is closed.
2) If you are going to install an adhesive rubber door seal, a recess needs to be cut around the underside perimeter of your door to account for the extra thickness. install the seal on your floor joists, put the door into place, and measure the difference in height to find your recess depth.
2) Install hinge. The hinge needs to be recessed so there is no visible bulge in your carpet. Line up your door in the opening and put the hinge in place, mark the outline onto the door and subfloor. Use a chisel or router to cut a recess for your hinge. reposition your door and attach the hinge. (I used a gate style hinge, but a piano hinge will be much easier and just as strong) Make sure the door is aligned with the opening properly.
4) Install barrel bolt lock and handle. Drill a hole into the side of your floor joist to accept the barrel bolt.
Step 4: Attach Carpet
1) The carpet around the perimeter of the door opening needs to be secured to the subfloor. First apply double sided carpet tape to the subfloor on all sides of the door except the hinge side. Secure the padding to this tape. Then apply tape to the top of the carpet padding in the same areas and secure the carpet to this tape.
2) The padding and carpet need to be secured to the secret door. Only apply carpet tape to the side of the door opposite the hinge. This will allow the carpet and padding to flex when the door is opened. Since I pull on the carpet to open the secret door, I decided to also use wood screws every 4 inches to secure the carpet to this side of the door. Do not screw them in too far, you don't want suck the carpet down and leave a visible indention.
3) Clean up the edge of your carpet and padding with your box knife so the door closes easily.
I installed a permanent ladder and light switch to make the space more accessible and useable.
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    53 Comments
    Your crawl space is much larger than mine and mine has a dirt floor. It is only 2 cinder blocks high in the back of the house and 3 in the front. I'd love to do this to hide valuables, etc. Just wouldn't know how to keep moisture away from what I would place down there. Any suggestions?
    I'd forget the steps and make or buy a plastic bin that you could hang in the hole.
    That's a good idea! Although it wouldn't solve the moisture issue. I guess I could vacum seal.
    Sure it would. The plastic tub is waterproof by nature. Secure it with screws or nails and seal edges with silicone. Unless you're talking about from above then you would just have to use the matching cover or invent one of your own
    Unless the tub seals like a tupperware container, it will breath with diurnal changes in barometric pressure. In many climates this will result in significant condensation inside. Ziplock bags are better, because with soft flexible walls, they are not as prone to breathing as a rigid container.
    If your crawl space wasn't so small, I'd recommend encapsulating your crawl space in regards to the moisture. Though it might still be a good idea so that you do not get mold and rotting floor joists.
    Jack-ee if I was you I would look into purchasing old metal ammo boxes from an army surplus store. They have a gasket to prevent the ammo from getting wet or corroded and are made for military use so you know they are tough. Add some silica gel or another type of desiccant in the box and that is what I would do to keep stuff dry and vermin free.
    you could use a small dehumidifier
    If you want to hide smaller items, then check out my secret drawer lock: https://www.instructables.com/id/Secret-Drawer-Lock
    It can be added to an existing dresser, nightstand, etc... And would be easier than building the secret crawl space door.
    My crawl space is not vented, the exterior walls are insulated, the ground is gravel with plastic, and I installed a back up sump pump. So I don't have moisture issues. You definately don't want to ruin your valuables by sticking them in a crawl space with high humidity or that is prone to flooding issues.
    Thank you I sure will check it out!
    If you do want it less susceptible to brute force like the night stand, which will stop a quiet thief but not a sledge!
    With every lock, once the owner is threatened they are defunct and more useful to a thief because all the valuables are in one spot. That is why concealment works best because if the thief don't know he wont ask. For moisture control, try just wrapping everything in multiple plastic bags, inside a bin or waterproof sack: http://www.wiggle.co.uk/lifeventure-dristore-25l-d...
    Always works when camping...just don't use biodegradable bags!
    could come to someones house and make it for them
    and can you post pics of b underneath the house (in the crawl space)
    It varies by state, but in my state, this wouldn't be up to code, you'd need to replace the 2x4s with at least 2x8s to run between the joists to box it out. Be sure to use pressure treated wood, and galvanized nails for a project like this, as anything else is prone to rot.
    Just my $.02, but if you ever want to sell your home, always have it up to code.
    Seeing as how I found some items in my house after it was bought that were not up to code, I have to agree with you on this one. Its always best to be up to code. Codes were made for a reason after all.
    I agree "codes were made for a reason after all", but it doesnt always have to be a good reason :-)
    Where I live, if you want to make a fawcett on the front of yr house, the attachment plate (not the entire fawcet) needs to be recessed in a metal bowl. For what? god knows. No other country has that and still there are no major disasters around fawcets in surrounding countries. Then ofcourse there is the european rule of a maximum height for doors. A minimum height i can understand, but a maximum?
    I concur. If you're going to do something like that, do it right.
    Didn't see joist hangers either.
    Very cool, however Fire fighters and rescue squads hate hidden rooms, it is difficult to find survivors/victims and there could be danger from collapse in the event of a fire or other catastrophe.
    Firemen are against almost everything. No candles, no lighters, no fireworks. Toaster should be unplugged when not in use. Some I've met seem to want people to sit in a room with no appliances and sit there and do nothing when you are at home.
    I know they have horror stories and live a dangerous life but they need to not worry that everything possibly bad will happen.
